title: NoiseLearnerV3 (latest version)
description: API reference for qiskit_ibm_runtime.executor_noise_learner.NoiseLearnerV3 in the latest version of qiskit-ibm-runtime
source: https://quantum.cloud.ibm.com/docs/en/api/qiskit-ibm-runtime/executor-noise-learner-noise-learner-v3
# NoiseLearnerV3
*class* `NoiseLearnerV3(mode=None, options=None)`
[GitHub](https://github.com/Qiskit/qiskit-ibm-runtime/tree/stable/0.52/qiskit_ibm_runtime/executor_noise_learner/noise_learner_v3.py#L40-L147)
Bases: `object`
The noise learner allows characterizing the noise processes affecting target instructions, based on the Pauli-Lindblad noise model described in \[1]. The instructions provided to the [`run()`](#qiskit_ibm_runtime.executor_noise_learner.NoiseLearnerV3.run "qiskit_ibm_runtime.executor_noise_learner.NoiseLearnerV3.run") method must contain a twirled-annotated [`BoxOp`](/docs/api/qiskit/qiskit.circuit.BoxOp) containing ISA operations. The result of a noise learner job contains a list of [`NoiseLearnerV3Result`](/docs/api/qiskit-ibm-runtime/results-noise-learner-v3-result "qiskit_ibm_runtime.results.NoiseLearnerV3Result") objects, one for each given instruction.
**Parameters**
- **mode** (*BackendV2 |* [*Session*](/docs/api/qiskit-ibm-runtime/session "qiskit_ibm_runtime.Session")  *|*[*Batch*](/docs/api/qiskit-ibm-runtime/batch "qiskit_ibm_runtime.Batch") *| None*) –
  The execution mode used to make the primitive query. It can be:
  - A `Backend` if you are using job mode.
  - A `Session` if you are using session execution mode.
  - A `Batch` if you are using batch execution mode.
  Refer to the [IBM Quantum Compute (formerly Qiskit Runtime) documentation](/docs/ibm-quantum-compute/execution-modes) for more information about the execution modes.
- **options** ([*NoiseLearnerV3Options*](/docs/api/qiskit-ibm-runtime/options-models-noise-learner-v3-options "qiskit_ibm_runtime.options_models.noise_learner_v3.NoiseLearnerV3Options")) – The desired options.
**References**
1. E. van den Berg, Z. Minev, A. Kandala, K. Temme, *Probabilistic error cancellation with sparse Pauli–Lindblad models on noisy quantum processors*, Nature Physics volume 19, pages 1116–1121 (2023). [arXiv:2201.09866 \[quant-ph\]](https://arxiv.org/abs/2201.09866)
## Attributes
### mode
Return the execution mode used by this primitive.
**Returns**
Mode used by this primitive, or `None` if an execution mode is not used.
### options
Type: [`NoiseLearnerV3Options`](/docs/api/qiskit-ibm-runtime/options-models-noise-learner-v3-options "qiskit_ibm_runtime.options_models.noise_learner_v3.NoiseLearnerV3Options")
## Methods
### backend
`backend()`
[GitHub](https://github.com/Qiskit/qiskit-ibm-runtime/tree/stable/0.52/qiskit_ibm_runtime/executor_noise_learner/noise_learner_v3.py#L97-L99)
**Return type**
BackendV2
### run
`run(instructions, dry_run=False)`
[GitHub](https://github.com/Qiskit/qiskit-ibm-runtime/tree/stable/0.52/qiskit_ibm_runtime/executor_noise_learner/noise_learner_v3.py#L110-L147)
**Parameters**
- **instructions** (*Iterable\[CircuitInstruction]*) – The instructions to learn the noise of.
- **dry\_run** (*bool*) – If `True`, performs a dry run without executing the job on a QPU. This mode can be used to validate the job, estimate usage consumption, and retrieve circuit timing metadata. Returned results preserve the expected schema but contain **randomized mock data** rather than actual or simulated measurement results. Unlike the fake backends, the processing of this dry run happens on the server-side, so the job may not finish immediately and access to this feature may be restricted.
**Returns**
The submitted job.
**Return type**
[RuntimeJobV2](/docs/api/qiskit-ibm-runtime/runtime-job-v2 "qiskit_ibm_runtime.RuntimeJobV2") | LocalRuntimeJob
