title: Migrate from NoiseLearner to NoiseLearnerV3
description: Migrate from using the NoiseLearner helper program to NoiseLearnerV3 in IBM Quantum Compute Service
source: https://quantum.cloud.ibm.com/docs/en/guides/migrate-to-noise-learner-v3
# Migrate from NoiseLearner to NoiseLearnerV3
This guide walks you through migrating from IBM Quantum® `NoiseLearner` to `NoiseLearnerV3`. Both
classes perform experiments that characterize noise processes based on a
[Pauli-Lindblad noise model](https://arxiv.org/abs/2201.09866), but the inputs and
outputs are slightly different.
## Background
The [`NoiseLearner`](/docs/api/qiskit-ibm-runtime/noise-learner-noise-learner)
class was created to allow users to perform explicit noise learning. The resulting
noise model can then be passed to IBM Quantum `Estimator` for applying error mitigation techniques
such as PEA and PEC.
`NoiseLearner` was designed to work with `Estimator`, and therefore it implicitly employs the same
layer finding strategy as `Estimator`. This strategy cannot be changed; otherwise, the subsequent
mitigation steps would not work correctly.
Starting with `qiskit-ibm-runtime` v0.47.0, there is a new
[`NoiseLearnerV3`](/docs/api/qiskit-ibm-runtime/noise-learner-v3-noise-learner-v3)
class that is compatible with the `Executor` primitive and the
[directed execution model](/docs/ibm-quantum-compute/directed-execution-model).
This new model delivers a **white-box** experience by providing the pieces to capture design intent
on the client side, and a single server-side primitive (Executor) processes those inputs exactly as
directed — it makes no implicit decisions on your behalf. Unlike the original `NoiseLearner`,
you control how to stratify your circuits when you use`NoiseLearnerV3`, and the class simply takes a list of boxed circuit instructions
(for example, unique layers) as its input.
`NoiseLearnerV3` also supports measurement noise learning. For each instruction in the input list, it runs the
Pauli-Lindblad learning protocol if the box contains one- and two-qubit gates, and the
[TREX](/docs/guides/error-mitigation-and-suppression-techniques#twirled-readout-error-extinction-trex)
protocol if the box contains measurements.
## Should you migrate?
`NoiseLearner` only works with the legacy server-side `Estimator`, and `NoiseLearnerV3` only works with
`Executor` and the client-side `Estimator`. **You must migrate to `NoiseLearnerV3` if you are using
`Executor` or client-side `Estimator`**. The legacy server-side `Estimator` is deprecated and replaced by the client-side equivalent in `qiskit-ibm-runtime` v0.50.0.
> **Note**
> If you are using `qiskit-ibm-runtime` v0.50.0 or later, read the [Migrate from server-side to client-side Sampler and Estimator](/docs/guides/migrate-to-client-side-primitives) guide to migrate to client-side primitives first.
## Migration steps
### Step 1: Change the imports
**`NoiseLearner`:**
from qiskit_ibm_runtime.noise_learner import NoiseLearner
**`NoiseLearnerV3`:**
from qiskit_ibm_runtime import NoiseLearnerV3
### Step 2: Update the inputs
The `NoiseLearner` `run()` method takes a list of circuits or PUBs, whereas the `NoiseLearnerV3` `run()` method takes a list of instructions, each of which must be a twirling-annotated [`BoxOp`](/docs/api/qiskit/qiskit.circuit.BoxOp) containing ISA operations.
Convenience methods are available for generating the annotated boxes, depending on which
primitive you plan to use.
**`NoiseLearner`:**
learner = NoiseLearner(mode=backend)
# `circuits_to_learn` is a list of ISA QuantumCircuit
learner_job = learner.run(circuits_to_learn)
**`NoiseLearnerV3`, when working with client-side Estimator:**
If you are planning to use client-side Estimator for circuit execution, you can use the `find_unique_layers` method from Estimator to create annotated boxes (layers):
pubs = [...]  # Your PUBs
estimator.options.resilience.pec_mitigation = True  # or zne_mitigation + pea amplifier
# Identify the unique layers to learn.
layers = estimator.find_unique_layers(pubs)
# Learn the noise model for those layers (runs as a separate job).
learner = NoiseLearnerV3(backend)
learner_job = learner.run(layers)
**`NoiseLearnerV3`, when working with Executor:**
If you are planning to use Executor for circuit execution, consider using the [generate\_boxing\_pass\_manager](/docs/api/samplomatic/auto/transpiler-generate-boxing-pass-manager#samplomatic.transpiler.generate_boxing_pass_manager) function from [Samplomatic](https://github.com/Qiskit/samplomatic/) to create annotated boxes:
from qiskit_ibm_runtime.noise_learner_v3 import NoiseLearnerV3
# Run the boxing pass manager to group instructions into annotated boxes.
# `isa_circuit` is an ISA QuantumCircuit.
boxing_pm = generate_boxing_pass_manager(
    enable_gates=True,
    enable_measures=False,
    inject_noise_targets="gates",  # no measurement mitigation
boxed_circuit = boxing_pm.run(isa_circuit)
# Find unique boxed instructions.
unique_box_instructions = find_unique_box_instructions(boxed_circuit.data)
# Instantiate a NoiseLearnerV3 object and execute the noise learning program.
learner_job = learner.run(unique_box_instructions)
### Step 3: Convert the options
Most [`NoiseLearnerOptions`](/docs/api/qiskit-ibm-runtime/options-noise-learner-options) fields map directly to [`NoiseLearnerV3Options`](/docs/api/qiskit-ibm-runtime/options-models-noise-learner-v3-options), except the following:
- `max_layers_to_learn`: With `NoiseLearnerV3`, the number of layers to learn is based on the number of layers passed in.
- `twirling_strategy`: With `NoiseLearnerV3`, the twirling strategy is defined by how the instructions are boxed and annotated (such as when using `generate_boxing_pass_manager()`).
**`NoiseLearner`:**
from qiskit_ibm_runtime.options import NoiseLearnerOptions
# Instantiate a NoiseLearnerOptions object
learner_options = NoiseLearnerOptions(
    max_layers_to_learn=3, num_randomizations=32, twirling_strategy="all"
learner = NoiseLearner(mode=backend, options=learner_options)
set the `twirling.strategy` Estimator option:
from qiskit_ibm_runtime.options_models import NoiseLearnerV3Options
estimator.options.twirling.strategy = "all"  # set twirling strategy here
learner_options = NoiseLearnerV3Options(num_randomizations=32)
learner = NoiseLearnerV3(backend, options=learner_options)
# Learn just the first 3 layers.
learner_job = learner.run(layers[:3])
If you are planning to use Executor for circuit execution, you can pass the `twirling_strategy` option to the [generate\_boxing\_pass\_manager](/docs/api/samplomatic/auto/transpiler-generate-boxing-pass-manager#samplomatic.transpiler.generate_boxing_pass_manager) function.
Note that with `generate_boxing_pass_manager()`, the `twirling_strategy` values use underscores
(`"active_accum"`, `"active_circuit"`), whereas `NoiseLearnerOptions.twirling_strategy` values use hyphens (`"active-accum"`, `"active-circuit"`).
    enable_gates=True,
    twirling_strategy="all",  # twirling strategy can be specified here
learner_job = learner.run(unique_box_instructions[:3])
### Step 4: Inspect the results
The outputs of `NoiseLearner` and `NoiseLearnerV3` contain similar information but are in different formats. Update your code if it inspects the output explicitly.
**Result attribute mapping:**
(`learner_result` is the output of the learner job)
| Attribute                        | NoiseLearner        | NoiseLearnerV3        |
| Result type                      | [NoiseLearnerResult](/docs/api/qiskit-ibm-runtime/results-noise-learner-result#noiselearnerresult) | [NoiseLearnerV3Results](/docs/api/qiskit-ibm-runtime/results-noise-learner-v3-results), a sequence-like container of [NoiseLearnerV3Result](/docs/api/qiskit-ibm-runtime/results-noise-learner-v3-result) |
| Number of learned layers         | len(learner\_result.data)        | len(learner\_result)        |
| Data for the first layer         | layer\_error = learner\_result.data\[0]                                                            | noise\_map = learner\_result\[0].to\_pauli\_lindblad\_map()        |
| Result type of each layer        | [`LayerError`](/docs/api/qiskit-ibm-runtime/results-layer-error) (`type(layer_error)`)             | [`PauliLindbladMap`](/docs/api/qiskit/qiskit.quantum_info.PauliLindbladMap) (`type(noise_map)`)        |
| Generators for the error channel | `layer_error.error.generators`        | `noise_map.generators()`        |
| Error rates                      | `layer_error.error.rates`        | `noise_map.rates`        |
### Step 5: Input noise model to a primitive
`NoiseLearner` only works with the legacy server-side `Estimator`, and `NoiseLearnerV3` only works with `Executor` and the client-side `Estimator`. How a noise model is specified varies slightly based on which primitive is used.
**`NoiseLearner`, when working with legacy server-side Estimator:**
from qiskit_ibm_runtime import Estimator as LegacyEstimator
learner_result = learner_job.result()
# Pass the noise model to the `estimator.options` attribute directly
estimator = LegacyEstimator(mode=backend)
estimator.options.resilience.layer_noise_model = learner_result
job = estimator.run(pubs)
Reuse the same `Estimator` that produced `layers` in step 2. The noise maps returned by the
learner are positionally matched to those layers, so they must be assigned to the Estimator
they came from. PEA/PEC was already enabled on it in step 2.
Note that while `NoiseLearnerV3` supports both Pauli-Lindblad and TREX protocols, `Estimator` only accepts noise models for two-qubit layers learned with the Pauli-Lindblad protocol.
# Convert results to Pauli-Lindblad noise maps.
pauli_lindblad_maps = learner_result.to_pauli_lindblad_maps()
# Assign the learned noise maps so PEA/PEC uses them.
estimator.options.resilience.layer_noise_model = zip(layers, pauli_lindblad_maps)
# Now execute the target PUBs.
from qiskit_ibm_runtime import Executor
# Generate a quantum program
program = QuantumProgram(shots=1000)
# Convert the NoiseLearnerV3 result to a dictionary
noise_maps = learner_result.to_dict(
    instructions=unique_box_instructions, require_refs=False
# Append the samplex item and execute
program.append_samplex_item(
    template_circuit,
    samplex=samplex,
    samplex_arguments={
        "pauli_lindblad_maps": noise_maps,
executor = Executor(backend)
executor_job = executor.run(program)
## Full examples
### NoiseLearnerV3 and client-side Estimator
from qiskit_ibm_runtime import QiskitRuntimeService, NoiseLearnerV3
# 1. Account + backend
# 2. Circuit + observable
circuit = QuantumCircuit(2)
circuit.h(0)
circuit.cx(0, 1)
observable = SparsePauliOp("ZZ")
# 3. Transpile to ISA
pm = generate_preset_pass_manager(backend=backend, optimization_level=1)
isa_circuit = pm.run(circuit)
pubs = [(isa_circuit, isa_observable)]
# 4. Initialize Estimator with options
# 5. Extract the unique boxed layers from PUBs
# 6. Learn the noise model for those layers
# 7. Convert the result to Pauli-Lindblad maps and pass them to Estimator
# 8. Execute the target PUBs
result = job.result()
### NoiseLearnerV3 and Executor
from qiskit_ibm_runtime import QiskitRuntimeService, Executor, NoiseLearnerV3
from samplomatic import build
circuit.h(0)
circuit.cx(0, 1)
circuit.measure_all()
# 4. Run the boxing pass manager to group instructions into annotated boxes
    enable_gates=True,
# 5. Find unique boxed instructions (layers)
# 7. Convert the NoiseLearnerV3 result to a dictionary
# 8. Build the template circuit and samplex pair
template_circuit, samplex = build(boxed_circuit)
# 9. Prepare a quantum program
    template_circuit,
    samplex=samplex,
    samplex_arguments={
## References
- [Directed execution model](/docs/ibm-quantum-compute/directed-execution-model)
- [Noise learning helper](/docs/ibm-quantum-compute/noise-learning)
