title: Compilation methods for Hamiltonian simulation circuits
description: Compare SABRE, AI-powered transpiler, and Rustiq compilation methods on Hamiltonian simulation circuits from Hamlib.
source: https://quantum.cloud.ibm.com/docs/en/tutorials/compilation-methods-for-hamiltonian-simulation-circuits
# Compilation methods for Hamiltonian simulation circuits
*Usage estimate: under 1 minute on an IBM Heron processor (NOTE: This is an estimate only. Your runtime might vary.)*
## Learning outcomes
After going through this tutorial, you will understand:
- How to use the Qiskit transpiler with SABRE for layout and routing optimization
- How to leverage the AI-powered transpiler for advanced circuit optimization
- How to use the Rustiq plugin for synthesizing `PauliEvolutionGate` operations in Hamiltonian simulation circuits
- How to benchmark and compare compilation methods using two-qubit depth, total gate count, and runtime
## Prerequisites
We suggest that you are familiar with the following topics before going through this tutorial:
- [Transpilation concepts](/docs/guides/transpile)
- [Transpiler stages](/docs/guides/transpiler-stages)
- [Transpile with pass managers](/docs/guides/transpile-with-pass-managers)
## Background
Quantum circuit compilation transforms a high-level quantum algorithm into a physical circuit that respects the constraints of the target hardware. Effective compilation can significantly reduce circuit depth and gate count, both of which directly impact the quality of results on near-term quantum devices.
This tutorial benchmarks three compilation methods on Hamiltonian simulation circuits built with `PauliEvolutionGate`. These circuits model pairwise qubit interactions (such as $ZZ$, $XX$, and $YY$ terms) and are common in quantum chemistry, condensed matter physics, and materials science.
The benchmark circuits come from the [Hamlib](https://github.com/SRI-International/QC-App-Oriented-Benchmarks/tree/master/qedcbench/hamlib#hamlib-simulation---benchmark-program) collection, accessed through the [Benchpress](https://github.com/Qiskit/benchpress) repository. Hamlib provides a standardized set of representative Hamiltonians, making it possible to compare compilation strategies on realistic simulation workloads.
### Compilation methods overview
#### Qiskit transpiler with SABRE
The Qiskit transpiler uses the SABRE (SWAP-based BidiREctional heuristic search) algorithm to optimize circuit layout and routing. SABRE focuses on minimizing SWAP gates and their impact on circuit depth while respecting hardware connectivity constraints. It is a general-purpose method that provides a good balance between performance and compilation time. For more details, see [\[1\]](https://arxiv.org/abs/2409.08368). The advantages and parameter exploration of SABRE are covered in-depth in a separate [tutorial](/docs/tutorials/transpilation-optimizations-with-sabre).
#### AI-powered transpiler
The AI-powered transpiler uses machine learning to predict optimal transpilation strategies by analyzing patterns in circuit structure and hardware constraints. It can also apply the `AIPauliNetworkSynthesis` pass, which targets Pauli network circuits using a reinforcement learning-based synthesis approach. For more information, see [\[2\]](https://arxiv.org/abs/2405.13196) and [\[3\]](https://arxiv.org/abs/2503.14448).
#### Rustiq plugin
The Rustiq plugin provides advanced synthesis techniques specifically for `PauliEvolutionGate` operations, which represent Pauli rotations commonly used in Trotterized dynamics. It is designed to produce low-depth circuit decompositions for Hamiltonian simulation workloads. For more details, see [\[4\]](https://arxiv.org/abs/2404.03280).
### Key metrics
We compare the three methods on the following metrics:
- **Two-qubit depth**: The depth of the circuit counting only two-qubit gates. This is often the bottleneck for fidelity on real hardware.
- **Circuit size (total gate count)**: The total number of gates in the transpiled circuit.
- **Runtime**: The wall-clock time for transpilation.
## Requirements
- Qiskit Aer (`pip install qiskit-aer`)
- Qiskit IBM Transpiler (`pip install qiskit-ibm-transpiler`)
- Qiskit AI Transpiler local mode (`pip install qiskit_ibm_ai_local_transpiler`)
- Networkx (`pip install networkx`)
## Setup
from qiskit.circuit.library import PauliEvolutionGate
from qiskit_ibm_transpiler import generate_ai_pass_manager
from qiskit.transpiler.passes.synthesis.high_level_synthesis import HLSConfig
from qiskit_aer.noise import NoiseModel, depolarizing_error
from collections import Counter
from statistics import mean, stdev
from scipy.sparse import SparseEfficiencyWarning
import time
import warnings
import matplotlib.ticker as ticker
import json
import requests
import logging
# Suppress noisy loggers and warnings
logging.getLogger(
    "qiskit_ibm_transpiler.wrappers.ai_local_synthesis"
).setLevel(logging.ERROR)
warnings.filterwarnings("ignore", category=FutureWarning)
warnings.filterwarnings("ignore", category=SparseEfficiencyWarning)
seed = 42  # Seed for reproducibility
### Connect to a backend
Select a backend that will be used for both the small-scale and large-scale examples. The backend determines the coupling map and basis gates that the transpiler targets.
# QiskitRuntimeService.save_account(channel="ibm_quantum_platform",
# token="<YOUR-API-KEY>", overwrite=True, set_as_default=True)
service = QiskitRuntimeService(channel="ibm_quantum_platform")
Using backend: ibm_pittsburgh
### Define pass managers
Set up the three compilation methods.
# SABRE pass manager (Qiskit default at optimization level 3)
pm_sabre = generate_preset_pass_manager(
# AI transpiler pass manager (local mode)
pm_ai = generate_ai_pass_manager(
    backend=backend, optimization_level=3, ai_optimization_level=3
Fetching 127 files:   0%|          | 0/127 [00:00<?, ?it/s]
# Rustiq pass manager for PauliEvolutionGate synthesis
hls_config = HLSConfig(
    PauliEvolution=[
            "rustiq",
                "nshuffles": 400,
                "upto_phase": True,
                "fix_clifford": True,
                "preserve_order": False,
                "metric": "depth",
pm_rustiq = generate_preset_pass_manager(
    backend=backend,
    hls_config=hls_config,
    seed_transpiler=seed,
### Define helper functions
The following function transpiles a list of circuits using a given pass manager, and records the key metrics (two-qubit depth, circuit size, and runtime) for each circuit.
def capture_transpilation_metrics(
    results, pass_manager, circuits, method_name
    Transpile circuits and append one metrics record per circuit to
    ``results``.
    Args:
        results (list): List of dicts to append the metrics records to.
        pass_manager: Pass manager used for transpilation.
        circuits (list): List of quantum circuits to transpile.
        method_name (str): Name of the transpilation method.
    Returns:
        list: List of transpiled circuits.
    transpiled_circuits = []
    for i, qc in enumerate(circuits):
        start_time = time.time()
        transpiled_qc = pass_manager.run(qc)
        end_time = time.time()
        # Decompose swaps for consistency across methods
        transpiled_qc = transpiled_qc.decompose(gates_to_decompose=["swap"])
        transpilation_time = end_time - start_time
        two_qubit_depth = transpiled_qc.depth(
            lambda x: x.operation.num_qubits == 2
        circuit_size = transpiled_qc.size()
        results.append(
                "method": method_name,
                "qc_name": qc.name,
                "qc_index": i,
                "num_qubits": qc.num_qubits,
                "two_qubit_depth": two_qubit_depth,
                "size": circuit_size,
                "runtime": transpilation_time,
        transpiled_circuits.append(transpiled_qc)
            f"[{method_name}] Circuit {i} ({qc.name}): "
            f"2Q depth={two_qubit_depth}, size={circuit_size}, "
            f"time={transpilation_time:.2f}s"
    return transpiled_circuits
def _method_order(results):
    """Return the distinct method names in their first-seen order."""
    order = []
    for r in results:
        if r["method"] not in order:
            order.append(r["method"])
    return order
def print_summary_table(results):
    Print the mean and standard deviation of each metric per compilation
    method, followed by the mean percent improvement relative to SABRE.
    metrics = [
        ("two_qubit_depth", "2Q Depth"),
        ("size", "Gate Count"),
        ("runtime", "Runtime (s)"),
    methods = _method_order(results)
    by_method = {m: [r for r in results if r["method"] == m] for m in methods}
    sabre_by_index = {r["qc_index"]: r for r in by_method.get("SABRE", [])}
    col_w = 22
    name_w = max(len(m) for m in methods)
    header = f"{'Method':<{name_w}}" + "".join(
        f"  {label:>{col_w}}" for _, label in metrics
    print("Mean +/- std per compilation method")
    print(header)
    print("-" * len(header))
    for method in methods:
        cells = []
        for key, _ in metrics:
            values = [r[key] for r in by_method[method]]
            std = stdev(values) if len(values) > 1 else 0.0
            cells.append(f"{mean(values):,.1f} +/- {std:,.1f}")
            f"{method:<{name_w}}" + "".join(f"  {c:>{col_w}}" for c in cells)
    others = [m for m in methods if m != "SABRE"]
    if others and sabre_by_index:
        print()
        print("Mean % improvement vs SABRE (positive = better than SABRE)")
        print(header)
        for method in others:
            cells = []
                pct = [
                    (sabre_by_index[r["qc_index"]][key] - r[key])
                    / sabre_by_index[r["qc_index"]][key]
                    * 100
                    if sabre_by_index.get(r["qc_index"])
                    and sabre_by_index[r["qc_index"]][key]
                if pct:
                    std = stdev(pct) if len(pct) > 1 else 0.0
                    cells.append(f"{mean(pct):+.1f}% +/- {std:.1f}%")
                    cells.append("n/a")
def print_per_circuit_comparison(results, num_rows=5):
    Print a per-metric comparison of the compilation methods for the
    first ``num_rows`` circuits (sorted by qubit count). The best
    (lowest) value for each metric is marked with an asterisk.
    metrics = [
    by_index = {}
    for r in results:
        by_index.setdefault(r["qc_index"], {})[r["method"]] = r
    ordered = sorted(
        by_index.items(),
        key=lambda kv: (next(iter(kv[1].values()))["num_qubits"], kv[0]),
    )[:num_rows]
    for key, label in metrics:
        print(f"{label} (first {num_rows} circuits by qubit count); * = best")
        header = f"{'Idx':>3}  {'Circuit':<16} {'Q':>3}" + "".join(
            f"{m:>9}" for m in methods
        print(header)
        for idx, method_map in ordered:
            any_record = next(iter(method_map.values()))
            present = {
                m: method_map[m][key] for m in methods if m in method_map
            best = min(present.values())
            line = (
                f"{idx:>3}  {any_record['qc_name'][:16]:<16} "
                f"{any_record['num_qubits']:>3}"
            for m in methods:
                value = method_map[m][key]
                text = f"{value:.2f}" if key == "runtime" else f"{int(value)}"
                if value == best:
                    text += "*"
                line += f"{text:>9}"
            print(line)
        print()
### Load Hamiltonian circuits from Hamlib
We load a representative set of Hamiltonians from the Benchpress repository and construct `PauliEvolutionGate` circuits. Circuits that exceed the backend's qubit count are removed, along with circuits whose decomposed size exceeds 1,500 gates (to keep transpilation times reasonable).
# Obtain the Hamiltonian JSON from the benchpress repository
url = (
    "https://raw.githubusercontent.com/Qiskit/benchpress/"
    "e7b29ef7be4cc0d70237b8fdc03edbd698908eff/"
    "benchpress/hamiltonian/hamlib/100_representative.json"
response = requests.get(url)
response.raise_for_status()
ham_records = json.loads(response.text)
# Remove circuits that are too large for the backend
ham_records = [
    h for h in ham_records if h["ham_qubits"] <= backend.num_qubits
# Build PauliEvolutionGate circuits
qc_ham_list = []
for h in ham_records:
    terms = h["ham_hamlib_hamiltonian_terms"]
    coeff = h["ham_hamlib_hamiltonian_coefficients"]
    num_qubits = h["ham_qubits"]
    name = h["ham_problem"]
    evo_gate = PauliEvolutionGate(SparsePauliOp(terms, coeff))
    qc.name = name
    qc.append(evo_gate, range(num_qubits))
    qc_ham_list.append(qc)
# Remove circuits whose decomposed size exceeds 1500 gates so that
# transpilation completes in a reasonable time frame
qc_ham_list = [qc for qc in qc_ham_list if qc.decompose().size() <= 1500]
print(f"Total Hamiltonian circuits loaded: {len(qc_ham_list)}")
min_qubits = min(qc.num_qubits for qc in qc_ham_list)
max_qubits = max(qc.num_qubits for qc in qc_ham_list)
print(f"Qubit range: {min_qubits} to {max_qubits}")
Total Hamiltonian circuits loaded: 42
Qubit range: 2 to 112
Split circuits into small-scale (fewer than 20 qubits) and large-scale (20 or more qubits) groups.
qc_small = [qc for qc in qc_ham_list if qc.num_qubits < 20]
qc_large = [qc for qc in qc_ham_list if qc.num_qubits >= 20]
print(f"Small-scale circuits (<20 qubits): {len(qc_small)}")
print(f"Large-scale circuits (>=20 qubits): {len(qc_large)}")
Small-scale circuits (<20 qubits): 20
Large-scale circuits (>=20 qubits): 22
Preview one of the small-scale Hamiltonian circuits before transpilation.
# We decompose the circuit here, otherwise it would just be a PauliEvolutionGate box,
# which isn't very informative to look at!
qc_small[0].decompose().draw("mpl", fold=-1)
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/b4c5d6e7-0.avif)
## Small-scale example
In this section, we benchmark the three compilation methods on Hamiltonian circuits with fewer than 20 qubits. These circuits transpile quickly and provide a clear view of how each method handles circuits of moderate complexity.
Each Hamiltonian is encoded as a `PauliEvolutionGate` circuit. The circuits were already constructed in the setup section from the Hamlib benchmark data.
We transpile all small-scale circuits using each of the three pass managers, then collect the metrics.
results_small = []
tqc_sabre_small = capture_transpilation_metrics(
    results_small, pm_sabre, qc_small, "SABRE"
tqc_ai_small = capture_transpilation_metrics(
    results_small, pm_ai, qc_small, "AI"
tqc_rustiq_small = capture_transpilation_metrics(
    results_small, pm_rustiq, qc_small, "Rustiq"
[SABRE] Circuit 0 (all-vib-bh): 2Q depth=3, size=30, time=2.09s
[SABRE] Circuit 1 (all-vib-c2h): 2Q depth=18, size=111, time=0.01s
[SABRE] Circuit 2 (all-vib-o3): 2Q depth=6, size=58, time=0.00s
[SABRE] Circuit 3 (all-vib-c2h): 2Q depth=2, size=37, time=0.01s
[SABRE] Circuit 4 (graph-gnp_k-2): 2Q depth=24, size=126, time=0.01s
[SABRE] Circuit 5 (LiH): 2Q depth=66, size=285, time=0.01s
[SABRE] Circuit 6 (all-vib-fccf): 2Q depth=66, size=339, time=0.01s
[SABRE] Circuit 7 (all-vib-ch2): 2Q depth=88, size=413, time=0.01s
[SABRE] Circuit 8 (all-vib-f2): 2Q depth=180, size=1000, time=0.02s
[SABRE] Circuit 9 (all-vib-bhf2): 2Q depth=18, size=223, time=0.03s
[SABRE] Circuit 10 (graph-gnp_k-4): 2Q depth=122, size=675, time=0.02s
[SABRE] Circuit 11 (Be2): 2Q depth=343, size=1628, time=0.03s
[SABRE] Circuit 12 (all-vib-fccf): 2Q depth=14, size=134, time=0.00s
[SABRE] Circuit 13 (uf20-ham): 2Q depth=50, size=341, time=0.01s
[SABRE] Circuit 14 (TSP_Ncity-4): 2Q depth=118, size=615, time=0.01s
[SABRE] Circuit 15 (graph-complete_bipart): 2Q depth=232, size=1420, time=0.03s
[SABRE] Circuit 16 (all-vib-cyclo_propene): 2Q depth=18, size=354, time=0.93s
[SABRE] Circuit 17 (all-vib-hno): 2Q depth=6, size=174, time=0.14s
[SABRE] Circuit 18 (all-vib-fccf): 2Q depth=30, size=286, time=0.01s
[SABRE] Circuit 19 (tfim): 2Q depth=31, size=232, time=0.03s
[AI] Circuit 0 (all-vib-bh): 2Q depth=3, size=30, time=0.01s
Fetching 4 files:   0%|          | 0/4 [00:00<?, ?it/s]
[AI] Circuit 1 (all-vib-c2h): 2Q depth=18, size=101, time=0.18s
[AI] Circuit 2 (all-vib-o3): 2Q depth=6, size=58, time=0.01s
[AI] Circuit 3 (all-vib-c2h): 2Q depth=2, size=37, time=0.01s
[AI] Circuit 4 (graph-gnp_k-2): 2Q depth=24, size=133, time=0.07s
[AI] Circuit 5 (LiH): 2Q depth=62, size=267, time=8.00s
[AI] Circuit 6 (all-vib-fccf): 2Q depth=65, size=300, time=0.18s
[AI] Circuit 7 (all-vib-ch2): 2Q depth=79, size=353, time=0.16s
[AI] Circuit 8 (all-vib-f2): 2Q depth=176, size=998, time=0.43s
[AI] Circuit 9 (all-vib-bhf2): 2Q depth=18, size=194, time=0.11s
[AI] Circuit 10 (graph-gnp_k-4): 2Q depth=114, size=668, time=0.18s
[AI] Circuit 11 (Be2): 2Q depth=292, size=1382, time=0.88s
[AI] Circuit 12 (all-vib-fccf): 2Q depth=14, size=134, time=0.01s
[AI] Circuit 13 (uf20-ham): 2Q depth=40, size=330, time=0.16s
[AI] Circuit 14 (TSP_Ncity-4): 2Q depth=96, size=600, time=0.29s
[AI] Circuit 15 (graph-complete_bipart): 2Q depth=231, size=1531, time=0.46s
[AI] Circuit 16 (all-vib-cyclo_propene): 2Q depth=18, size=309, time=0.25s
[AI] Circuit 17 (all-vib-hno): 2Q depth=10, size=198, time=0.15s
[AI] Circuit 18 (all-vib-fccf): 2Q depth=34, size=402, time=0.02s
[AI] Circuit 19 (tfim): 2Q depth=44, size=311, time=0.15s
[Rustiq] Circuit 0 (all-vib-bh): 2Q depth=3, size=30, time=0.01s
[Rustiq] Circuit 1 (all-vib-c2h): 2Q depth=13, size=69, time=0.00s
[Rustiq] Circuit 2 (all-vib-o3): 2Q depth=13, size=82, time=0.01s
[Rustiq] Circuit 3 (all-vib-c2h): 2Q depth=2, size=40, time=0.01s
[Rustiq] Circuit 4 (graph-gnp_k-2): 2Q depth=31, size=132, time=0.01s
[Rustiq] Circuit 5 (LiH): 2Q depth=59, size=285, time=0.01s
[Rustiq] Circuit 6 (all-vib-fccf): 2Q depth=34, size=193, time=0.00s
[Rustiq] Circuit 7 (all-vib-ch2): 2Q depth=49, size=302, time=0.01s
[Rustiq] Circuit 8 (all-vib-f2): 2Q depth=141, size=807, time=0.02s
[Rustiq] Circuit 9 (all-vib-bhf2): 2Q depth=13, size=146, time=0.02s
[Rustiq] Circuit 10 (graph-gnp_k-4): 2Q depth=129, size=683, time=0.02s
[Rustiq] Circuit 11 (Be2): 2Q depth=220, size=1101, time=0.02s
[Rustiq] Circuit 12 (all-vib-fccf): 2Q depth=53, size=333, time=0.01s
[Rustiq] Circuit 13 (uf20-ham): 2Q depth=63, size=425, time=0.01s
[Rustiq] Circuit 14 (TSP_Ncity-4): 2Q depth=123, size=767, time=0.02s
[Rustiq] Circuit 15 (graph-complete_bipart): 2Q depth=309, size=2107, time=0.05s
[Rustiq] Circuit 16 (all-vib-cyclo_propene): 2Q depth=16, size=283, time=0.32s
[Rustiq] Circuit 17 (all-vib-hno): 2Q depth=19, size=291, time=0.32s
[Rustiq] Circuit 18 (all-vib-fccf): 2Q depth=44, size=546, time=0.02s
[Rustiq] Circuit 19 (tfim): 2Q depth=24, size=416, time=0.01s
The table below summarizes the average and standard deviation of each metric across all small-scale circuits, along with the percent improvement relative to SABRE. Because circuit sizes vary widely, the standard deviation provides important context for interpreting the averages.
print_summary_table(results_small)
Method                2Q Depth              Gate Count             Runtime (s)
SABRE            71.8 +/- 89.6         424.1 +/- 446.0             0.2 +/- 0.5
AI               67.3 +/- 80.2         416.8 +/- 426.7             0.6 +/- 1.8
Rustiq           67.9 +/- 80.0         451.9 +/- 484.7             0.0 +/- 0.1
AI             -2.1% +/- 19.8%         -0.6% +/- 14.7%   -5635.1% +/- 20725.2%
Rustiq        -25.3% +/- 85.4%        -16.3% +/- 50.4%         -7.0% +/- 60.6%
The per-circuit table shows how each method compares on individual circuits. The best value for each metric is marked with an asterisk. Notice that for the simplest circuits, all three methods often converge to the same result.
print_per_circuit_comparison(results_small, num_rows=8)
2Q Depth (first 8 circuits by qubit count); * = best
Idx  Circuit            Q    SABRE       AI   Rustiq
  0  all-vib-bh         2       3*       3*       3*
  1  all-vib-c2h        3       18       18      13*
  2  all-vib-o3         4       6*       6*       13
  3  all-vib-c2h        4       2*       2*       2*
  4  graph-gnp_k-2      4      24*      24*       31
  5  LiH                4       66       62      59*
  6  all-vib-fccf       4       66       65      34*
  7  all-vib-ch2        4       88       79      49*
Gate Count (first 8 circuits by qubit count); * = best
  0  all-vib-bh         2      30*      30*      30*
  1  all-vib-c2h        3      111      101      69*
  2  all-vib-o3         4      58*      58*       82
  3  all-vib-c2h        4      37*      37*       40
  4  graph-gnp_k-2      4     126*      133      132
  5  LiH                4      285     267*      285
  6  all-vib-fccf       4      339      300     193*
  7  all-vib-ch2        4      413      353     302*
Runtime (s) (first 8 circuits by qubit count); * = best
  0  all-vib-bh         2     2.09     0.01    0.01*
  1  all-vib-c2h        3     0.01     0.18    0.00*
  2  all-vib-o3         4    0.00*     0.01     0.01
  3  all-vib-c2h        4     0.01     0.01    0.01*
  4  graph-gnp_k-2      4    0.01*     0.07     0.01
  5  LiH                4    0.01*     8.00     0.01
  6  all-vib-fccf       4     0.01     0.18    0.00*
  7  all-vib-ch2        4     0.01     0.16    0.01*
#### Visualize results
The plots below compare the three methods across each metric on a per-circuit basis. Circuits are sorted by qubit count and labeled by index on the x-axis, since multiple circuits can share the same number of qubits.
def plot_transpilation_comparison(results, title_prefix):
    Create a three-panel figure comparing compilation methods on
    two-qubit depth, circuit size, and runtime.
    Circuits are sorted by qubit count and plotted by circuit index.
    palette = {"SABRE": "#1f77b4", "AI": "#ff7f0e", "Rustiq": "#2ca02c"}
    markers = {"SABRE": "o", "AI": "^", "Rustiq": "s"}
    # Order circuits by qubit count (then index) and map to plot positions
    ref = sorted(
        [r for r in results if r["method"] == methods[0]],
        key=lambda r: (r["num_qubits"], r["qc_index"]),
    pos_map = {r["qc_index"]: pos for pos, r in enumerate(ref)}
    tick_positions = [pos_map[r["qc_index"]] for r in ref]
    tick_labels = [
        f"{pos_map[r['qc_index']]} ({r['num_qubits']}q)" for r in ref
    metrics = [
        ("two_qubit_depth", "Two-Qubit Depth"),
        ("size", "Total Gate Count (Circuit Size)"),
        ("runtime", "Transpilation Runtime (s)"),
    fig, axes = plt.subplots(1, 3, figsize=(20, 5.5))
    fig.suptitle(title_prefix, fontsize=15, fontweight="bold", y=1.02)
    for ax, (metric, ylabel) in zip(axes, metrics):
            subset = sorted(
                [r for r in results if r["method"] == method],
                key=lambda r: pos_map[r["qc_index"]],
            ax.plot(
                [pos_map[r["qc_index"]] for r in subset],
                [r[metric] for r in subset],
                marker=markers.get(method, "o"),
                label=method,
                color=palette.get(method, None),
                linewidth=1.5,
                markersize=6,
                alpha=0.85,
        ax.set_xlabel("Circuit Index (num qubits)", fontsize=11)
        ax.set_ylabel(ylabel, fontsize=11)
        ax.legend(frameon=True, fontsize=9)
        ax.grid(True, linestyle="--", alpha=0.4)
        step = max(1, len(tick_positions) // 15)
        ax.set_xticks(tick_positions[::step])
        ax.set_xticklabels(
            [tick_labels[i] for i in range(0, len(tick_labels), step)],
            fontsize=7,
            rotation=45,
            ha="right",
    plt.tight_layout()
def plot_pct_improvement_vs_sabre(results, title_prefix):
    Plot the per-circuit percent improvement of each non-SABRE method
    relative to SABRE, for each metric. A positive value means the
    method improved on SABRE; negative means SABRE was better.
    metrics = [
        ("runtime", "Runtime"),
    palette = {"AI": "#ff7f0e", "Rustiq": "#2ca02c"}
    markers = {"AI": "^", "Rustiq": "s"}
    sabre = sorted(
        [r for r in results if r["method"] == "SABRE"],
    other_methods = [m for m in methods if m != "SABRE"]
    tick_positions = list(range(len(sabre)))
    tick_labels = [
        f"{i} ({sabre[i]['num_qubits']}q)" for i in range(len(sabre))
    fig.suptitle(
        f"{title_prefix}: % Improvement over SABRE",
        fontsize=15,
        fontweight="bold",
        y=1.02,
    for ax, (metric, label) in zip(axes, metrics):
        ax.axhline(0, color="#1f77b4", linewidth=2, label="SABRE (baseline)")
        for method in other_methods:
            data = sorted(
            pct = [
                (sabre[i][metric] - data[i][metric]) / sabre[i][metric] * 100
            ax.plot(
                tick_positions,
                pct,
                label=method,
                linewidth=1.5,
                markersize=6,
                alpha=0.85,
        ax.set_ylabel(f"% Improvement ({label})", fontsize=11)
        ax.set_xticklabels(
            fontsize=7,
            rotation=45,
            ha="right",
        ylims = ax.get_ylim()
        ax.axhspan(0, max(ylims[1], 1), alpha=0.04, color="green")
        ax.axhspan(min(ylims[0], -1), 0, alpha=0.04, color="red")
    plt.tight_layout()
    results_small,
    "Small-Scale Hamiltonian Circuits: Compilation Comparison",
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/d5e6f7a8-0.avif)
    results_small,
    "Small-Scale Hamiltonian Circuits",
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/pct_improvement_small-0.avif)
At this scale, all three pass managers perform well, and their average results are close to each other. This is largely because small circuits leave limited room for further optimization, so the methods tend to converge on similar solutions.
In this example, Rustiq produces the most variable results, with the largest outliers in both two-qubit depth and gate count. While this variability means it sometimes falls behind, it also means Rustiq occasionally finds better solutions than the other two methods. The AI transpiler is more stable in its results relative to SABRE and Rustiq, tracking closely on most circuits without many outliers.
For runtime, SABRE and Rustiq are both fast, while the AI-powered transpiler is noticeably slower on certain circuits.
#### Best-performing method by metric
The chart below shows how often each method achieved the best (lowest) value for each metric. Ties are possible: for simpler circuits, multiple methods can reach the same optimal two-qubit depth or gate count. When a tie occurs, all tied methods receive credit, so the percentages for a given metric may sum to more than 100%.
def plot_best_method_bars(results, metrics_list=None):
    Plot a grouped bar chart showing the percentage of circuits
    where each method achieved the best (lowest) value for each metric.
    Ties are counted for all tied methods, so percentages per metric
    can sum to more than 100%.
    if metrics_list is None:
        metrics_list = ["two_qubit_depth", "size", "runtime"]
    labels = {
        "two_qubit_depth": "2Q Depth",
        "size": "Gate Count",
        "runtime": "Runtime",
    by_index = {}
    for r in results:
        by_index.setdefault(r["qc_index"], []).append(r)
    n_circuits = len(by_index)
    win_data = {m: [] for m in methods}
    tie_counts = []
    metric_labels = []
    for metric in metrics_list:
        metric_labels.append(
            labels.get(metric, metric.replace("_", " ").title())
        counts = Counter()
        ties = 0
        for group in by_index.values():
            min_val = min(r[metric] for r in group)
            best = [r["method"] for r in group if r[metric] == min_val]
            if len(best) > 1:
                ties += 1
            counts.update(best)
        tie_counts.append(ties)
        for m in methods:
            win_data[m].append(counts.get(m, 0) / n_circuits * 100)
    x = np.arange(len(metric_labels))
    width = 0.22
    for i, method in enumerate(methods):
        bars = ax.bar(
            x + i * width,
            win_data[method],
            width,
            label=method,
            edgecolor="black",
            linewidth=0.5,
        for bar in bars:
            height = bar.get_height()
            if height > 0:
                ax.text(
                    bar.get_x() + bar.get_width() / 2,
                    height + 1.5,
                    f"{height:.0f}%",
                    ha="center",
                    va="bottom",
                    fontsize=9,
    # Annotate tie counts below each metric label
    for j, ties in enumerate(tie_counts):
        if ties > 0:
            ax.text(
                x[j] + width,
                -8,
                f"({ties} tie{'s' if ties != 1 else ''})",
                ha="center",
                va="top",
                fontsize=8,
                color="gray",
    ax.set_xticks(x + width)
    ax.set_xticklabels(metric_labels, fontsize=11)
    ax.set_ylabel("Circuits with best value (%)", fontsize=11)
    ax.set_title(
        "Best-Performing Method by Metric (ties counted for all tied methods)",
        fontsize=12,
        fontweight="bold",
    ax.legend(frameon=True, fontsize=10)
    ax.set_ylim(-12, 120)
    ax.yaxis.set_major_formatter(ticker.PercentFormatter())
    ax.grid(axis="y", linestyle="--", alpha=0.4)
    plt.tight_layout()
plot_best_method_bars(results_small)
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/a6b7c8d9-0.avif)
In this example, the three methods perform very similarly on the small-scale circuits. On two-qubit depth and gate count, the share of circuits where each method is best is close (roughly 35–55%), and many circuits end in ties because the simplest circuits often have a single optimal solution that multiple methods find. The clearest difference is runtime: SABRE and Rustiq are each fastest on about half the circuits, while the AI-powered transpiler is rarely the quickest. Considering all three metrics together, Rustiq has a slight overall edge   it is the most frequent winner on two-qubit depth and stays competitive on gate count and runtime.
To evaluate how transpilation quality affects execution under noise, we use a **mirror circuit** technique. For each transpiled circuit $U$, we append its inverse $U^\dagger$ so the combined circuit $U^\dagger U$ is theoretically the identity. Starting from the $|0\rangle$ state, a perfect (noiseless) execution would return the all-zeros bitstring with probability 1.
In practice, gate errors accumulate throughout the circuit, so the probability of recovering $|0\rangle^{\otimes n}$ drops. A compilation method that produces a shallower circuit with fewer gates will accumulate less noise.
The mirror circuit approach is appealingly simple and scales to any circuit size, since the expected output is always $|0\rangle^{\otimes n}$ and no classical simulation of the ideal state is required. However, note the following caveats: the mirror circuit is a proxy for the actual circuit (not the circuit itself), it doubles the gate count (which exaggerates the effect of noise), and it can underestimate certain errors when noise cancels symmetrically across the mirror boundary.
We pick circuit index 6 from the small-scale set and run the mirror circuits on an Aer simulator with a simple depolarizing noise model.
# Select circuit index 6 from the small-scale transpiled circuits
test_idx = 6
test_circuit = qc_small[test_idx]
print(f"Test circuit: {test_circuit.name}, {test_circuit.num_qubits} qubits")
# Get the transpiled versions
tqc_methods_small = {
    "SABRE": tqc_sabre_small[test_idx],
    "AI": tqc_ai_small[test_idx],
    "Rustiq": tqc_rustiq_small[test_idx],
# Show transpilation metrics for this circuit
print(f"\nTranspilation metrics for circuit index {test_idx}:")
for method, tqc in tqc_methods_small.items():
    depth_2q = tqc.depth(lambda x: x.operation.num_qubits == 2)
    size = tqc.size()
    print(f"  {method:8s}  2Q depth={depth_2q:5d}  size={size:6d}")
Test circuit: all-vib-fccf, 4 qubits
Transpilation metrics for circuit index 6:
  SABRE     2Q depth=   66  size=   339
  AI        2Q depth=   65  size=   300
  Rustiq    2Q depth=   34  size=   193
Build the mirror circuits (append $U^\dagger$), remap to contiguous qubit indices so the simulator only handles the active qubits, and run on a noisy Aer simulator.
def remap_to_contiguous(tqc):
    """Remap a transpiled circuit to use contiguous qubit indices.
    Transpiled circuits target specific physical qubits (e.g., qubit 45, 67)
    on a large backend. This remaps them to 0, 1, 2, ... so Aer only
    simulates the active qubits.
    active = sorted(
        {tqc.find_bit(q).index for inst in tqc.data for q in inst.qubits}
    qubit_map = {old: new for new, old in enumerate(active)}
    new_qc = QuantumCircuit(len(active))
    for inst in tqc.data:
        old_indices = [tqc.find_bit(q).index for q in inst.qubits]
        new_qc.append(inst.operation, [qubit_map[i] for i in old_indices])
    return new_qc
def build_mirror_circuit(tqc):
    """Build a mirror circuit: U followed by U-dagger, with measurements.
    The combined circuit U-dagger @ U should be the identity, so measuring
    all zeros indicates a noise-free execution.
    tqc_compact = remap_to_contiguous(tqc)
    mirror = tqc_compact.compose(tqc_compact.inverse())
    mirror.measure_all()
    return mirror
# Build a simple depolarizing noise model
noise_model = NoiseModel()
noise_model.add_all_qubit_quantum_error(
    depolarizing_error(0.001, 1),
    ["sx", "x", "rz"],  # ~0.1% per 1Q gate
    depolarizing_error(0.01, 2),
    ["cx", "ecr"],  # ~1% per 2Q gate
aer_sim = AerSimulator(noise_model=noise_model)
shots = 10000
fidelities = {}
    mirror = build_mirror_circuit(tqc)
    sampler = SamplerV2(mode=aer_sim)
    job = sampler.run([mirror], shots=shots)
    result = job.result()
    counts = result[0].data.meas.get_counts()
    # Fidelity = fraction of all-zeros (error-free) outcomes
    n_qubits = mirror.num_qubits - mirror.num_clbits  # active qubits
    all_zeros = "0" * mirror.num_qubits
    fidelity = counts.get(all_zeros, 0) / shots
    fidelities[method] = fidelity
        f"{method:8s}  P(|00...0>) = {fidelity:.4f}  "
        f"({counts.get(all_zeros, 0)}/{shots})"
SABRE     P(|00...0>) = 0.7796  (7796/10000)
AI        P(|00...0>) = 0.8073  (8073/10000)
Rustiq    P(|00...0>) = 0.8923  (8923/10000)
def plot_mirror_results(tqc_methods, fidelities, circuit_name):
    Plot a three-panel comparison: fidelity, 2Q depth,
    and gate count for each compilation method.
    methods = list(tqc_methods.keys())
    colors = [palette.get(m, "gray") for m in methods]
    fidelity_vals = [fidelities[m] for m in methods]
    depth_vals = [
        tqc_methods[m].depth(lambda x: x.operation.num_qubits == 2)
        for m in methods
    size_vals = [tqc_methods[m].size() for m in methods]
    fig, axes = plt.subplots(1, 3, figsize=(16, 5))
    fig.suptitle(
        f"Mirror Circuit Results: {circuit_name}",
        fontsize=14,
        fontweight="bold",
        y=1.02,
    def _annotate_bars(ax, bars, values, fmt="{}"):
        ymax = ax.get_ylim()[1]
        for bar, val in zip(bars, values):
            label = fmt.format(val)
            y = val + ymax * 0.03
            ax.text(
                y,
                label,
                ha="center",
                va="bottom",
                fontsize=10,
                fontweight="bold",
    # Panel 1: Survival Probability
    bars = axes[0].bar(
        methods, fidelity_vals, color=colors, edgecolor="black", linewidth=0.5
    axes[0].set_ylabel("Fidelity  P(|00...0>)", fontsize=11)
    axes[0].set_title("Fidelity (higher is better)", fontsize=12)
    axes[0].set_ylim(
        0, max(fidelity_vals) * 1.18 if max(fidelity_vals) > 0 else 1.0
    axes[0].grid(axis="y", linestyle="--", alpha=0.4)
    _annotate_bars(axes[0], bars, fidelity_vals, fmt="{:.4f}")
    # Panel 2: Two-Qubit Depth
    bars = axes[1].bar(
        methods, depth_vals, color=colors, edgecolor="black", linewidth=0.5
    axes[1].set_ylabel("Two-Qubit Depth", fontsize=11)
    axes[1].set_title("2Q Depth (lower is better)", fontsize=12)
    axes[1].set_ylim(0, max(depth_vals) * 1.18)
    axes[1].grid(axis="y", linestyle="--", alpha=0.4)
    _annotate_bars(axes[1], bars, depth_vals)
    # Panel 3: Gate Count
    bars = axes[2].bar(
        methods, size_vals, color=colors, edgecolor="black", linewidth=0.5
    axes[2].set_ylabel("Total Gate Count", fontsize=11)
    axes[2].set_title("Gate Count (lower is better)", fontsize=12)
    axes[2].set_ylim(0, max(size_vals) * 1.18)
    axes[2].grid(axis="y", linestyle="--", alpha=0.4)
    _annotate_bars(axes[2], bars, size_vals)
    plt.tight_layout()
plot_mirror_results(tqc_methods_small, fidelities, test_circuit.name)
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/small_step4_plot-0.avif)
#### Observations
The method with the lowest two-qubit depth and fewest gates achieves the highest fidelity, consistent with the expectation that shorter circuits accumulate less noise. Even modest differences in depth and gate count translate into measurable differences in fidelity under the depolarizing noise model.
Keep in mind that these results are for a single circuit. The relative ranking of the methods can shift from circuit to circuit depending on the Hamiltonian structure.
In this section, we benchmark the same three compilation methods on Hamiltonian circuits with 20 or more qubits. These circuits are more representative of practical Hamiltonian simulation workloads and test how each method scales in terms of circuit quality and compilation time.
### Steps 1-4 combined
The workflow follows the same structure as the small-scale example. We transpile all large-scale circuits with each method, collect metrics, and submit a mirror circuit to real quantum hardware.
results_large = []
tqc_sabre_large = capture_transpilation_metrics(
    results_large, pm_sabre, qc_large, "SABRE"
tqc_ai_large = capture_transpilation_metrics(
    results_large, pm_ai, qc_large, "AI"
tqc_rustiq_large = capture_transpilation_metrics(
    results_large, pm_rustiq, qc_large, "Rustiq"
[SABRE] Circuit 0 (all-vib-hc3h2cn): 2Q depth=2, size=258, time=0.16s
[SABRE] Circuit 1 (ham-graph-gnp_k-5): 2Q depth=345, size=4036, time=0.08s
[SABRE] Circuit 2 (TSP_Ncity-5): 2Q depth=187, size=2045, time=0.04s
[SABRE] Circuit 3 (tfim): 2Q depth=100, size=489, time=0.21s
[SABRE] Circuit 4 (all-vib-h2co): 2Q depth=30, size=570, time=0.18s
[SABRE] Circuit 5 (uuf100-ham): 2Q depth=414, size=4779, time=0.09s
[SABRE] Circuit 6 (uuf100-ham): 2Q depth=523, size=5667, time=0.11s
[SABRE] Circuit 7 (graph-gnp_k-4): 2Q depth=3028, size=24885, time=0.39s
[SABRE] Circuit 8 (uf100-ham): 2Q depth=700, size=8271, time=0.15s
[SABRE] Circuit 9 (uf100-ham): 2Q depth=698, size=8957, time=0.15s
[SABRE] Circuit 10 (TSP_Ncity-7): 2Q depth=432, size=6353, time=0.12s
[SABRE] Circuit 11 (all-vib-cyclo_propene): 2Q depth=30, size=1144, time=0.20s
[SABRE] Circuit 12 (TSP_Ncity-8): 2Q depth=704, size=10287, time=0.18s
[SABRE] Circuit 13 (uf100-ham): 2Q depth=2454, size=30195, time=0.46s
[SABRE] Circuit 14 (tfim): 2Q depth=245, size=3670, time=0.08s
[SABRE] Circuit 15 (flat100-ham): 2Q depth=154, size=3836, time=0.12s
[SABRE] Circuit 16 (graph-regular_reg-4): 2Q depth=863, size=14063, time=0.22s
[SABRE] Circuit 17 (tfim): 2Q depth=581, size=8810, time=0.15s
[SABRE] Circuit 18 (FH_D-1): 2Q depth=1704, size=9528, time=0.35s
[SABRE] Circuit 19 (TSP_Ncity-10): 2Q depth=1091, size=22041, time=0.38s
[SABRE] Circuit 20 (TSP_Ncity-10): 2Q depth=1091, size=22005, time=0.38s
[SABRE] Circuit 21 (ham-unary-color02-queen13_13_k-4): 2Q depth=224, size=8321, time=0.17s
[AI] Circuit 0 (all-vib-hc3h2cn): 2Q depth=2, size=258, time=0.17s
[AI] Circuit 1 (ham-graph-gnp_k-5): 2Q depth=323, size=4418, time=3.13s
[AI] Circuit 2 (TSP_Ncity-5): 2Q depth=161, size=2229, time=1.47s
[AI] Circuit 3 (tfim): 2Q depth=20, size=402, time=0.34s
[AI] Circuit 4 (all-vib-h2co): 2Q depth=38, size=661, time=0.19s
[AI] Circuit 5 (uuf100-ham): 2Q depth=391, size=5130, time=3.27s
[AI] Circuit 6 (uuf100-ham): 2Q depth=463, size=6095, time=4.23s
[AI] Circuit 7 (graph-gnp_k-4): 2Q depth=3207, size=25641, time=15.15s
[AI] Circuit 8 (uf100-ham): 2Q depth=637, size=8267, time=5.87s
[AI] Circuit 9 (uf100-ham): 2Q depth=632, size=9330, time=7.29s
[AI] Circuit 10 (TSP_Ncity-7): 2Q depth=452, size=7418, time=6.02s
[AI] Circuit 11 (all-vib-cyclo_propene): 2Q depth=38, size=1323, time=0.27s
[AI] Circuit 12 (TSP_Ncity-8): 2Q depth=609, size=11131, time=10.07s
[AI] Circuit 13 (uf100-ham): 2Q depth=2251, size=31128, time=38.77s
[AI] Circuit 14 (tfim): 2Q depth=165, size=3460, time=1.64s
[AI] Circuit 15 (flat100-ham): 2Q depth=91, size=3497, time=2.49s
[AI] Circuit 16 (graph-regular_reg-4): 2Q depth=664, size=15256, time=12.35s
[AI] Circuit 17 (tfim): 2Q depth=583, size=9157, time=6.28s
[AI] Circuit 18 (FH_D-1): 2Q depth=1193, size=7754, time=4.54s
[AI] Circuit 19 (TSP_Ncity-10): 2Q depth=1134, size=22577, time=25.64s
[AI] Circuit 20 (TSP_Ncity-10): 2Q depth=1172, size=23851, time=28.97s
[AI] Circuit 21 (ham-unary-color02-queen13_13_k-4): 2Q depth=219, size=8600, time=8.85s
[Rustiq] Circuit 0 (all-vib-hc3h2cn): 2Q depth=2, size=257, time=0.16s
[Rustiq] Circuit 1 (ham-graph-gnp_k-5): 2Q depth=640, size=5831, time=0.13s
[Rustiq] Circuit 2 (TSP_Ncity-5): 2Q depth=408, size=3985, time=0.08s
[Rustiq] Circuit 3 (tfim): 2Q depth=31, size=688, time=0.07s
[Rustiq] Circuit 4 (all-vib-h2co): 2Q depth=65, size=1058, time=2.91s
[Rustiq] Circuit 5 (uuf100-ham): 2Q depth=633, size=6757, time=0.14s
[Rustiq] Circuit 6 (uuf100-ham): 2Q depth=795, size=8495, time=0.17s
[Rustiq] Circuit 7 (graph-gnp_k-4): 2Q depth=13768, size=139793, time=2.92s
[Rustiq] Circuit 8 (uf100-ham): 2Q depth=1099, size=11878, time=0.25s
[Rustiq] Circuit 9 (uf100-ham): 2Q depth=911, size=11111, time=0.22s
[Rustiq] Circuit 10 (TSP_Ncity-7): 2Q depth=1183, size=13197, time=0.27s
[Rustiq] Circuit 11 (all-vib-cyclo_propene): 2Q depth=67, size=2491, time=13.56s
[Rustiq] Circuit 12 (TSP_Ncity-8): 2Q depth=1615, size=21358, time=0.48s
[Rustiq] Circuit 13 (uf100-ham): 2Q depth=2920, size=40465, time=0.91s
[Rustiq] Circuit 14 (tfim): 2Q depth=489, size=6552, time=0.15s
[Rustiq] Circuit 15 (flat100-ham): 2Q depth=378, size=5906, time=0.14s
[Rustiq] Circuit 16 (graph-regular_reg-4): 2Q depth=12163, size=168679, time=2.94s
[Rustiq] Circuit 17 (tfim): 2Q depth=1208, size=17042, time=0.36s
[Rustiq] Circuit 18 (FH_D-1): 2Q depth=1061, size=24000, time=0.47s
[Rustiq] Circuit 19 (TSP_Ncity-10): 2Q depth=2565, size=41340, time=1.38s
[Rustiq] Circuit 20 (TSP_Ncity-10): 2Q depth=2565, size=41275, time=1.38s
[Rustiq] Circuit 21 (ham-unary-color02-queen13_13_k-4): 2Q depth=808, size=17548, time=0.42s
print_summary_table(results_large)
SABRE          709.1 +/- 783.8     9,100.5 +/- 8,493.1             0.2 +/- 0.1
AI             656.6 +/- 777.5     9,435.6 +/- 8,853.0            8.5 +/- 10.2
Rustiq     2,062.5 +/- 3,631.1   26,804.8 +/- 43,403.1             1.3 +/- 2.9
AI             +9.6% +/- 22.8%          -3.4% +/- 9.4%    -3620.0% +/- 2405.5%
Rustiq      -154.5% +/- 273.9%      -137.1% +/- 233.2%     -527.0% +/- 1405.5%
print_per_circuit_comparison(results_large, num_rows=8)
  0  all-vib-hc3h2cn   24       2*       2*       2*
  1  ham-graph-gnp_k-  24      345     323*      640
  2  TSP_Ncity-5       25      187     161*      408
  3  tfim              26      100      20*       31
  4  all-vib-h2co      32      30*       38       65
  5  uuf100-ham        40      414     391*      633
  6  uuf100-ham        40      523     463*      795
  7  graph-gnp_k-4     40    3028*     3207    13768
  0  all-vib-hc3h2cn   24      258      258     257*
  1  ham-graph-gnp_k-  24    4036*     4418     5831
  2  TSP_Ncity-5       25    2045*     2229     3985
  3  tfim              26      489     402*      688
  4  all-vib-h2co      32     570*      661     1058
  5  uuf100-ham        40    4779*     5130     6757
  6  uuf100-ham        40    5667*     6095     8495
  7  graph-gnp_k-4     40   24885*    25641   139793
  0  all-vib-hc3h2cn   24     0.16     0.17    0.16*
  1  ham-graph-gnp_k-  24    0.08*     3.13     0.13
  2  TSP_Ncity-5       25    0.04*     1.47     0.08
  3  tfim              26     0.21     0.34    0.07*
  4  all-vib-h2co      32    0.18*     0.19     2.91
  5  uuf100-ham        40    0.09*     3.27     0.14
  6  uuf100-ham        40    0.11*     4.23     0.17
  7  graph-gnp_k-4     40    0.39*    15.15     2.92
    results_large,
    "Large-Scale Hamiltonian Circuits: Compilation Comparison",
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/c7d8e9f0-0.avif)
    results_large,
    "Large-Scale Hamiltonian Circuits",
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/pct_improvement_large-0.avif)
plot_best_method_bars(results_large)
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/d7e8f9a0-0.avif)
# Select circuit index 3 from the large-scale transpiled circuits
test_idx_large = 3
test_circuit_large = qc_large[test_idx_large]
    f"Test circuit: {test_circuit_large.name}, {test_circuit_large.num_qubits} qubits"
tqc_methods_large = {
    "SABRE": tqc_sabre_large[test_idx_large],
    "AI": tqc_ai_large[test_idx_large],
    "Rustiq": tqc_rustiq_large[test_idx_large],
print(f"\nTranspilation metrics for circuit index {test_idx_large}:")
for method, tqc in tqc_methods_large.items():
    size = tqc.size()
Test circuit: tfim, 26 qubits
Transpilation metrics for circuit index 3:
  SABRE     2Q depth=  100  size=   489
  AI        2Q depth=   20  size=   402
  Rustiq    2Q depth=   31  size=   688
pm_mirror = generate_preset_pass_manager(
    optimization_level=0, backend=backend
    # print the count ops for each circuit
    mirror = tqc.copy()
    mirror.compose(tqc.inverse(), inplace=True)
    mirror = pm_mirror.run(mirror)
    print(f"\n{method} transpiled circuit:")
    print(tqc.count_ops())
    print(f"{method} mirror circuit count ops:")
    print(mirror.count_ops())
SABRE transpiled circuit:
OrderedDict({'sx': 211, 'rz': 163, 'cz': 104, 'x': 11})
SABRE mirror circuit count ops:
OrderedDict({'rz': 1170, 'sx': 422, 'cz': 208, 'measure': 156, 'x': 22, 'barrier': 1})
AI transpiled circuit:
OrderedDict({'sx': 165, 'rz': 162, 'cz': 68, 'x': 7})
AI mirror circuit count ops:
OrderedDict({'rz': 984, 'sx': 330, 'measure': 156, 'cz': 136, 'x': 14, 'barrier': 1})
Rustiq transpiled circuit:
OrderedDict({'sx': 316, 'rz': 225, 'cz': 140, 'x': 7})
Rustiq mirror circuit count ops:
OrderedDict({'rz': 1714, 'sx': 632, 'cz': 280, 'measure': 156, 'x': 14, 'barrier': 1})
# Build mirror circuits and submit to real hardware
# The inverse may introduce gates (e.g., sxdg) not in the backend's
# basis gate set, so we re-transpile the mirror circuit.
shots_hw = 10000
hw_jobs = {}
    mirror = tqc.copy()
    # Re-transpile at opt level 0 to decompose into basis gates
    # without changing the layout or routing
    sampler.options.environment.job_tags = ["TUT_CMHSC"]
    job = sampler.run([mirror], shots=shots_hw)
    hw_jobs[method] = job
    print(f"{method}: submitted job {job.job_id()}")
SABRE: submitted job d8gvgq66983c73dqe5og
AI: submitted job d8gvgqe6983c73dqe5pg
Rustiq: submitted job d8gvgqm6983c73dqe5q0
# Retrieve results and compute fidelities
fidelities_large = {}
for method, job in hw_jobs.items():
    n_qubits = backend.num_qubits
    all_zeros = "0" * n_qubits
    fidelity = counts.get(all_zeros, 0) / shots_hw
    fidelities_large[method] = fidelity
        f"({counts.get(all_zeros, 0)}/{shots_hw})"
SABRE     P(|00...0>) = 0.0005  (5/10000)
AI        P(|00...0>) = 0.3267  (3267/10000)
Rustiq    P(|00...0>) = 0.1845  (1845/10000)
    tqc_methods_large, fidelities_large, test_circuit_large.name
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/compilation-methods-for-hamiltonian-simulation-circuits/extracted-outputs/large_hw_plot-0.avif)
## Analysis of compilation results
The benchmarks above compare SABRE, the AI-powered transpiler, and Rustiq on Hamiltonian simulation circuits from the Hamlib collection at both small and large scale.
### Two-qubit depth and gate count
At large scale, SABRE and the AI-powered transpiler are the two strongest performers, and each leads on a different metric. As the *best-performing method by metric* chart shows, SABRE produces the lowest gate count on the large majority of circuits and is the fastest method on almost all of them, consistent with a heuristic designed to minimize inserted SWAP gates, and with recent optimizations to its layout and routing. The AI-powered transpiler produces the lowest two-qubit depth on most circuits, consistent with the part of its reinforcement learning objective that targets circuit depth. The summary table reflects the same split: SABRE has the lower mean gate count, while the AI transpiler has the lower mean two-qubit depth. Both methods are consistent and reliable across the full range of circuits.
Rustiq, which is purpose-built for `PauliEvolutionGate` synthesis, produces the single best result on only a small fraction of the large-scale circuits. Its average metrics are heavily skewed by a handful of significant outliers, visible as large spikes in the compilation comparison plot, where Rustiq produces substantially higher depth and gate count than the other methods. Without these outliers, its average performance would be much closer to SABRE and the AI-powered transpiler.
The key observation is that no single method dominates on every circuit. Each method outperforms the others in specific cases, which makes it worthwhile to try all available tools and select the best result for each circuit.
### Runtime
SABRE is consistently the fastest method. Rustiq generally runs at a similar speed, but it can produce outliers where the compilation takes significantly longer. This is especially visible in the large-scale results, where a few circuits cause Rustiq's runtime to spike. These outliers heavily impact the average runtime, so the median may be a more representative summary for Rustiq. The AI-powered transpiler is the slowest of the three, with runtime that grows notably on larger and more complex circuits.
### Mirror circuit results
The mirror circuit experiments confirm the expected trend: methods that produce lower two-qubit depth and fewer gates achieve higher fidelity under noise. This holds on both the noisy simulator (small-scale) and real hardware (large-scale).
Keep in mind that each mirror-circuit plot reflects a single circuit, not the aggregate. The hardware example above uses one 26-qubit `tfim` circuit, which happens to be a case where SABRE produces a much higher two-qubit depth than the AI-powered transpiler and Rustiq, so its fidelity is correspondingly much lower. This is not representative of the broader results: across the full set of large-scale circuits, SABRE's two-qubit depth is usually close to that of the AI-powered transpiler, and the two methods each lead on different metrics (the AI-powered transpiler on two-qubit depth, SABRE on gate count and runtime). A single mirror result tests a doubled version of one circuit rather than the full workload, so it should not be read as a verdict on overall method quality.
### Recommendations
There is no single best transpilation strategy for all circuits. The best choice depends on the circuit structure, the optimization goal, and the available compilation time budget:
- **SABRE** is the recommended default. It is fast and reliable, and produces strong results across a wide range of circuits. For further tuning, users can increase layout and routing trials (see the [SABRE optimization tutorial](/docs/tutorials/transpilation-optimizations-with-sabre)).
- **The AI-powered transpiler** is worth trying when compilation time is not a constraint, especially when minimizing two-qubit depth is the priority: it produced the lowest two-qubit depth on most of the large-scale circuits in this benchmark.
- **Rustiq** is purpose-built for `PauliEvolutionGate` circuits and can find very low-depth, low-gate-count solutions, particularly on smaller circuits. On larger circuits it can occasionally produce much larger results, so it is best used as one of several methods to try rather than as a default.
In practice, the best approach is to run all available methods and pick the best result for each circuit. The compilation overhead of trying multiple methods is small compared to the potential improvement in execution quality on real hardware.
## Next steps
If you found this tutorial useful, you might be interested in the following:
> **Recommendations**
> - [Transpilation optimizations with SABRE](/docs/tutorials/transpilation-optimizations-with-sabre)
> - [AI-powered transpiler passes](/docs/guides/ai-transpiler-passes)
> - [Create a transpiler plugin](/docs/guides/create-transpiler-plugin)
## References
\[1] "LightSABRE: A Lightweight and Enhanced SABRE Algorithm". H. Zou, M. Treinish, K. Hartman, A. Ivrii, J. Lishman et al. [https://arxiv.org/abs/2409.08368](https://arxiv.org/abs/2409.08368)
\[2] "Practical and efficient quantum circuit synthesis and transpiling with Reinforcement Learning". D. Kremer, V. Villar, H. Paik, I. Duran, I. Faro, J. Cruz-Benito et al. [https://arxiv.org/abs/2405.13196](https://arxiv.org/abs/2405.13196)
\[3] "Pauli Network Circuit Synthesis with Reinforcement Learning". A. Dubal, D. Kremer, S. Martiel, V. Villar, D. Wang, J. Cruz-Benito et al. [https://arxiv.org/abs/2503.14448](https://arxiv.org/abs/2503.14448)
\[4] "Faster and shorter synthesis of Hamiltonian simulation circuits". T. Goubault de Brugiere, S. Martiel et al. [https://arxiv.org/abs/2404.03280](https://arxiv.org/abs/2404.03280)
