title: Quantum kernel training
description: Build a Qiskit pattern for evaluating entries into a quantum kernel matrix used for binary classification.
source: https://quantum.cloud.ibm.com/docs/en/tutorials/quantum-kernel-training
# Quantum kernel training
*Usage estimate: under one minute on a Heron r3 processor (NOTE: This is an estimate only. Your runtime might vary.)*
## Learning outcomes
- Kernel methods and their uses
- Quantum kernels and how they can provide enhanced feature spaces
- Quantum kernel circuit construction
- How to train a quantum kernel using a [Qiskit pattern](/docs/guides/intro-to-patterns): map, optimize, execute, and post-process
## Prerequisites
It is recommended that you familiarize yourself with quantum kernels, why they are important, and how they are used in practice.
- [Covariant quantum kernels for data with group structure](https://arxiv.org/abs/2105.03406) (paper)
- [Introduction to Quantum Kernels and Support Vector Machines](https://www.youtube.com/watch?v=GVhCOTzAkCM) (video)
- [Quantum Kernels in Practice](https://www.youtube.com/watch?v=LmQcSxgINis) (video)
It is also useful to have a basic understanding of group theory.
## Background
Kernel methods are commonplace in machine learning applications.
In this context, "kernel" refers to the kernel matrix or individual entries therein.
In general, a kernel is a similarity measure between data encoded in a high-dimensional *feature space* and can be utilized, for example, in classification tasks with support vector machines.
Quantum kernel methods are those which use quantum computers to estimate a kernel.
It is known that quantum computers can encode data in quantum-enhanced feature spaces, effectively replacing classical analogs.
For $\vec{x} \in \mathbb{R}$ and $\Psi(\vec{x}) \in \mathbb{R}^{d'}$, typically with $d' >d$, $\Psi(\vec{x})$ is a feature map, $\vec{x} \mapsto \Psi(\vec{x})$.
The goal of $\Psi(\vec{x})$ is to make categories of data separated by a hyperplane.
Taking the vectors in the feature-mapped space as arguments, kernel function $K(\vec{x}, \vec{y}) = \langle{\Psi(\vec{x}) | \Psi(\vec{y}) \rangle{}}$ returns their inner product: $K: \mathbb{R}^d \rightarrow$ $\mathbb{R}^d$.
Classically, feature maps of interest are those in which the kernel function can be easily evaluated;
as in, when the inner product in the feature-mapped space can be written in terms of the original data vectors and $\Psi(\vec{x})$ and $\Psi(\vec{y})$ do not need to be constructed.
In the case of quantum kernels, feature mapping is performed by a quantum circuit, and the kernel is estimated using the measurement probabilities sampled from the circuit.
This tutorial shows how to build a Qiskit pattern for evaluating entries into a quantum kernel matrix used for binary classification.
## Requirements
- Qiskit SDK v2.3.1 or later, with [visualization](/docs/api/qiskit/visualization) support
- Qiskit Runtime v0.44.0 or later (`pip install qiskit-ibm-runtime`)
## Setup
# General Imports and helper functions
import urllib.request
import pandas as pd
from qiskit.circuit import Parameter, ParameterVector, QuantumCircuit
from qiskit.circuit.library import unitary_overlap
from qiskit_ibm_runtime import QiskitRuntimeService, Sampler
# Download the dataset (portable across platforms)
urllib.request.urlretrieve(
    "https://raw.githubusercontent.com/qiskit-community/prototype-quantum-kernel-training/main/data/dataset_graph7.csv",
    "dataset_graph7.csv",
def visualize_counts(res_counts, num_qubits, num_shots):
    """Visualize the outputs from the Qiskit Sampler primitive."""
    zero_prob = res_counts.get(0, 0.0)
    top_10 = dict(
        sorted(res_counts.items(), key=lambda item: item[1], reverse=True)[
            :10
    top_10.update({0: zero_prob})
    by_key = dict(sorted(top_10.items(), key=lambda item: item[0]))
    x_vals, y_vals = list(zip(*by_key.items()))
    x_vals = [bin(x_val)[2:].zfill(num_qubits) for x_val in x_vals]
    y_vals_prob = []
    for t in range(len(y_vals)):
        y_vals_prob.append(y_vals[t] / num_shots)
    y_vals = y_vals_prob
    plt.bar(x_vals, y_vals)
    plt.xticks(rotation=75)
    plt.title("Results of sampling")
    plt.xlabel("Measured bitstring")
    plt.ylabel("Probability")
def get_training_data():
    """Read the training data."""
    df = pd.read_csv("dataset_graph7.csv", sep=",", header=None)
    training_data = df.values[:20, :]
    ind = np.argsort(training_data[:, -1])
    X_train = training_data[ind][:, :-1]
    return X_train
In this section, we walk through the four steps of the Qiskit pattern on a seven-qubit instance of the labeling-cosets-with-error problem and evaluate a single kernel matrix entry using the `StatevectorSampler` primitive from Qiskit. A statevector simulator is exact (up to shot noise) and shows us the method end-to-end without consuming QPU time. We then repeat the same instance on real hardware in the hardware example section.
- Input: Training dataset.
- Output: Abstract circuit for calculating a kernel matrix entry.
The binary classification problem we aim to solve here is referred to as "[*labeling cosets with error*](https://arxiv.org/abs/2105.03406)." The input training dataset contains a group structure, consisting of two cosets formed by a group and subgroup.
The group is taken to be $G = SU(2)^{\otimes n}$ for qubits, which is the special unitary group of
$2 \times 2$ matrices and has wide applicability in nature; e.g., the Standard Model of particle physics.
We take the (graph-stabilizer) subgroup $S_\text{graph} < G$ with $S_\text{graph} = \langle \{ X_i \otimes _{k:(k,i) \in \mathcal{E}} Z_k\} _{i \in \mathcal{V}} \} \rangle$ for a graph with edges $\mathcal{E}$ and vertices $\mathcal{V}$.
Note that the stabilizers fix a stabilizer state such that $D_s | \psi \rangle = | \psi \rangle,~ \forall s \in S_\text{graph}$.
Finally, we define two left-cosets $C_\pm = c_\pm S_\text{graph}$ by drawing two $c_\pm \in G$ at random.
For more details about the dataset and how it is generated, see [this notebook](https://github.com/qiskit-community/prototype-quantum-kernel-training/blob/main/docs/background/qkernels_and_data_w_group_structure.ipynb) from the [Quantum Kernel Training Toolkit](https://github.com/qiskit-community/prototype-quantum-kernel-training/tree/main).
We create the quantum circuit used to evaluate one entry in the kernel matrix.
The input data is used to determine the rotation angles for the circuit's parametrized gates.
For simplicity, we will use data samples `x1=14` and `x2=19`.
***Note: The dataset used in this tutorial can be downloaded [here](https://github.com/qiskit-community/prototype-quantum-kernel-training/blob/main/data/dataset_graph7.csv).***
# Prepare training data
X_train = get_training_data()
# Empty kernel matrix
num_samples = np.shape(X_train)[0]
kernel_matrix = np.full((num_samples, num_samples), np.nan)
# Prepare feature map for computing overlap
num_features = np.shape(X_train)[1]
num_qubits = int(num_features / 2)
entangler_map = [[0, 2], [3, 4], [2, 5], [1, 4], [2, 3], [4, 6]]
fm = QuantumCircuit(num_qubits)
training_param = Parameter("θ")
feature_params = ParameterVector("x", num_qubits * 2)
fm.ry(training_param, fm.qubits)
for cz in entangler_map:
    fm.cz(cz[0], cz[1])
for i in range(num_qubits):
    fm.rz(-2 * feature_params[2 * i + 1], i)
    fm.rx(-2 * feature_params[2 * i], i)
# Assign tunable parameter to known optimal value and set the data params for
# first two samples
x1 = 14
x2 = 19
unitary1 = fm.assign_parameters(list(X_train[x1]) + [np.pi / 2])
unitary2 = fm.assign_parameters(list(X_train[x2]) + [np.pi / 2])
# Create the overlap circuit
overlap_circ = unitary_overlap(unitary1, unitary2)
overlap_circ.measure_all()
overlap_circ.draw("mpl", scale=0.6, style="iqp")
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/quantum-kernel-training/extracted-outputs/70d6faff-9a56-44bb-b26f-f573a8c90889-0.avif)
- Input: Abstract circuit, not optimized for a particular backend.
- Output: Target circuit, optimized for the selected QPU.
For the statevector simulator path used in this section, no backend-specific optimization is required: the abstract circuit can be sampled directly. We exercise this step in the hardware example below, where the circuit is transpiled against a real QPU using `generate_preset_pass_manager` with `optimization_level=3`.
- Input: Abstract circuit.
- Output: Quasi-probability distribution.
Use the `StatevectorSampler` primitive from Qiskit to reconstruct a quasi-probability distribution of states yielded from sampling the circuit. For the task of generating a kernel matrix, we are particularly interested in the probability of measuring the |0> state.
sampler = StatevectorSampler()
# Execute and get counts
num_shots = 10_000
results = sampler.run([overlap_circ], shots=num_shots).result()
counts = results[0].data.meas.get_int_counts()
# Plot counts
visualize_counts(counts, num_qubits, num_shots)
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/quantum-kernel-training/extracted-outputs/step3-small-code-0.avif)
- Input: Probability distribution.
- Output: A single kernel matrix element.
Calculate the probability of measuring $|0 \rangle$ on the overlap circuit, and populate the kernel matrix in the position corresponding to the samples represented by this particular overlap circuit (row 15, column 20).
kernel_matrix[x1, x2] = counts.get(0, 0.0) / num_shots
print(f"Fidelity (simulator): {kernel_matrix[x1, x2]}")
Fidelity (simulator): 0.8261
## Hardware example
A quantum kernel matrix has $\mathcal{O}(N^2)$ entries for $N$ training samples, and each entry requires running an overlap circuit whose two-qubit-gate depth grows with the size of the feature map. As a result, scaling this tutorial to a larger problem has two compounding costs: the QPU time per kernel matrix grows quadratically with $N$, and the depth of `unitary_overlap` (which composes the feature map with its adjoint) erodes fidelity at the system size and connectivity of current hardware. To keep the demo short and to make a clean comparison, we therefore run the **same** seven-qubit instance from the small-scale example on a real QPU and compare the fidelity of a single kernel matrix entry against the simulator value computed above.
# ------------------------------ Step 1 ------------------------------
    fm.cz(cz[0], cz[1])
# set the data params for first two samples
x1 = 14
x2 = 19
# ------------------------------ Step 2 ------------------------------
# backend = service.least_busy(
#    operational=True, simulator=False, min_num_qubits=overlap_circ.num_qubits
backend = service.backend("ibm_pittsburgh")
overlap_ibm = pm.run(overlap_circ)
# ------------------------------ Step 3 ------------------------------
sampler.options.environment.job_tags = ["TUT_QKT"]
num_shots = 10_000
results = sampler.run([overlap_ibm], shots=num_shots).result()
# ------------------------------ Step 4 ------------------------------
print(f"Fidelity (hardware): {kernel_matrix[x1, x2]}")
Using backend: ibm_pittsburgh
![Output of the previous code cell](https://quantum.cloud.ibm.com/docs/images/tutorials/quantum-kernel-training/extracted-outputs/d2f4f6cf-067e-4d53-aa04-7ca9c803d3e1-1.avif)
Fidelity (hardware): 0.7517
To fill out the entire kernel matrix, we would run a quantum experiment for each of its $N(N+1)/2$ unique entries. The figure below shows the resulting matrix for this dataset; darker red indicates fidelities closer to 1.0.
![kernel\_matrix.png](https://quantum.cloud.ibm.com/docs/images/tutorials/quantum-kernel-training/kernel_matrix.avif)
## Next steps
> **Recommendations**
> - [Quantum Kernel Training Toolkit](https://github.com/qiskit-community/prototype-quantum-kernel-training/tree/main) - the prototype repository this tutorial is based on
> - [Quantum Kernel Training for Machine Learning Applications](https://qiskit-community.github.io/qiskit-machine-learning/tutorials/08_quantum_kernel_trainer.html) - a Qiskit Machine Learning tutorial showing how to train the trainable parameter
> - [Introduction to Quantum Machine Learning](/learning/courses/quantum-machine-learning/introduction) - a course on quantum machine learning
> - [Quantum Machine Learning from IBM Research](https://research.ibm.com/topics/quantum-machine-learning) - an overview of QML research at IBM
> - [Covariant quantum kernels for data with group structure](https://arxiv.org/abs/2105.03406) - the paper this tutorial is based on
