This page is from an old version of Qiskit SDK and does not exist in the latest version. We recommend you migrate to the latest version. See the release notes for more information.
EuropeanCallExpectedValue
class EuropeanCallExpectedValue(uncertainty_model, strike_price, c_approx, i_state=None, i_compare=None, i_objective=None)
GitHub
The European Call Option Expected Value.
Evaluates the expected payoff for a European call option given an uncertainty model. The payoff function is f(S, K) = max(0, S - K) for a spot price S and strike price K.
Constructor.
Parameters
  • uncertainty_model (UnivariateDistribution) – uncertainty model for spot price
  • strike_price (float) – strike price of the European option
  • c_approx (float) – approximation factor for linear payoff
  • i_state (Union[List[int], ndarray, None]) – indices of qubits representing the uncertainty
  • i_compare (Optional[int]) – index of qubit for comparing spot price to strike price (enabling payoff or not)
  • i_objective (Optional[int]) – index of qubit for objective function
Attributes
num_target_qubits
Returns the number of target qubits
Methods
build
EuropeanCallExpectedValue.build(qc, q, q_ancillas=None, params=None)
Adds corresponding sub-circuit to given circuit
Parameters
  • qc (QuantumCircuit) – quantum circuit
  • q (list) – list of qubits (has to be same length as self._num_qubits)
  • q_ancillas (list) – list of ancilla qubits (or None if none needed)
  • params (list) – parameters for circuit
build_controlled
EuropeanCallExpectedValue.build_controlled(qc, q, q_control, q_ancillas=None, use_basis_gates=True)
Adds corresponding controlled sub-circuit to given circuit
Parameters
  • q_control (Qubit) – control qubit
  • use_basis_gates (bool) – use basis gates for expansion of controlled circuit
build_controlled_inverse
EuropeanCallExpectedValue.build_controlled_inverse(qc, q, q_control, q_ancillas=None, use_basis_gates=True)
Adds controlled inverse of corresponding sub-circuit to given circuit
Parameters
build_controlled_inverse_power
EuropeanCallExpectedValue.build_controlled_inverse_power(qc, q, q_control, power, q_ancillas=None, use_basis_gates=True)
Adds controlled, inverse, power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_controlled_power
EuropeanCallExpectedValue.build_controlled_power(qc, q, q_control, power, q_ancillas=None, use_basis_gates=True)
Adds controlled power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_inverse
EuropeanCallExpectedValue.build_inverse(qc, q, q_ancillas=None)
Adds inverse of corresponding sub-circuit to given circuit
Parameters
build_inverse_power
EuropeanCallExpectedValue.build_inverse_power(qc, q, power, q_ancillas=None)
Adds inverse power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_power
EuropeanCallExpectedValue.build_power(qc, q, power, q_ancillas=None)
Adds power of corresponding circuit. May be overridden if a more efficient implementation is possible
get_num_qubits
EuropeanCallExpectedValue.get_num_qubits()
returns number of qubits
get_num_qubits_controlled
EuropeanCallExpectedValue.get_num_qubits_controlled()
returns number of qubits controlled
required_ancillas
EuropeanCallExpectedValue.required_ancillas()
returns required ancillas
required_ancillas_controlled
EuropeanCallExpectedValue.required_ancillas_controlled()
returns required ancillas controlled
value_to_estimation
EuropeanCallExpectedValue.value_to_estimation(value)
value to estimate
Was this page helpful?
