This page is from an old version of Qiskit SDK and does not exist in the latest version. We recommend you migrate to the latest version. See the release notes for more information.
qiskit.finance.components.uncertainty_problems.EuropeanCallExpectedValue
class EuropeanCallExpectedValue(uncertainty_model, strike_price, c_approx, i_state=None, i_compare=None, i_objective=None)
GitHub
The European Call Option Expected Value.
Evaluates the expected payoff for a European call option given an uncertainty model. The payoff function is f(S, K) = max(0, S - K) for a spot price S and strike price K.
Constructor.
Parameters
  • uncertainty_model (UnivariateDistribution) – uncertainty model for spot price
  • strike_price (float) – strike price of the European option
  • c_approx (float) – approximation factor for linear payoff
  • i_state (Union[List[int], ndarray, None]) – indices of qubits representing the uncertainty
  • i_compare (Optional[int]) – index of qubit for comparing spot price to strike price (enabling payoff or not)
  • i_objective (Optional[int]) – index of qubit for objective function
__init__
__init__(uncertainty_model, strike_price, c_approx, i_state=None, i_compare=None, i_objective=None)
Constructor.
Parameters
Methods
__init__(uncertainty_model, strike_price, …)Constructor.
build(qc, q[, q_ancillas, params])Adds corresponding sub-circuit to given circuit
build_controlled(qc, q, q_control[, …])Adds corresponding controlled sub-circuit to given circuit
build_controlled_inverse(qc, q, q_control[, …])Adds controlled inverse of corresponding sub-circuit to given circuit
build_controlled_inverse_power(qc, q, …[, …])Adds controlled, inverse, power of corresponding circuit.
build_controlled_power(qc, q, q_control, power)Adds controlled power of corresponding circuit.
build_inverse(qc, q[, q_ancillas])Adds inverse of corresponding sub-circuit to given circuit
build_inverse_power(qc, q, power[, q_ancillas])Adds inverse power of corresponding circuit.
build_power(qc, q, power[, q_ancillas])Adds power of corresponding circuit.
get_num_qubits()returns number of qubits
get_num_qubits_controlled()returns number of qubits controlled
required_ancillas()returns required ancillas
required_ancillas_controlled()returns required ancillas controlled
value_to_estimation(value)value to estimate
Attributes
num_target_qubitsReturns the number of target qubits
build
build(qc, q, q_ancillas=None, params=None)
Parameters
  • qc (QuantumCircuit) – quantum circuit
  • q (list) – list of qubits (has to be same length as self._num_qubits)
  • q_ancillas (list) – list of ancilla qubits (or None if none needed)
  • params (list) – parameters for circuit
build_controlled
build_controlled(qc, q, q_control, q_ancillas=None, use_basis_gates=True)
Parameters
  • q_control (Qubit) – control qubit
  • use_basis_gates (bool) – use basis gates for expansion of controlled circuit
build_controlled_inverse(qc, q, q_control, q_ancillas=None, use_basis_gates=True)
Parameters
build_controlled_inverse_power(qc, q, q_control, power, q_ancillas=None, use_basis_gates=True)
Adds controlled, inverse, power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_controlled_power(qc, q, q_control, power, q_ancillas=None, use_basis_gates=True)
Adds controlled power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_inverse
build_inverse(qc, q, q_ancillas=None)
Parameters
build_inverse_power
build_inverse_power(qc, q, power, q_ancillas=None)
Adds inverse power of corresponding circuit. May be overridden if a more efficient implementation is possible
build_power
build_power(qc, q, power, q_ancillas=None)
Adds power of corresponding circuit. May be overridden if a more efficient implementation is possible
get_num_qubits
get_num_qubits()
num_target_qubits
required_ancillas
required_ancillas()
value_to_estimation
value to estimate
Was this page helpful?
