This page is from an old version of Qiskit SDK and does not exist in the latest version. We recommend you migrate to the latest version. See the release notes for more information.
qiskit_aer.noise.device.basic_device_gate_errors
basic_device_gate_errors(properties=None, gate_error=True, thermal_relaxation=True, gate_lengths=None, gate_length_units='ns', temperature=0, warnings=None, target=None)
GitHub
Return QuantumErrors derived from either of a devices BackendProperties or Target.
If non-default values are used gate_lengths should be a list of tuples (name, qubits, value) where name is the gate name string, qubits is either a list of qubits or None to apply gate time to this gate one any set of qubits, and value is the gate time in nanoseconds.
The resulting errors may contains two types of errors: gate errors and relaxation errors. The gate errors are generated only for Gate objects while the relaxation errors are generated for all Instruction objects. Exceptionally, no QuantumError s are generated for Measure since ReadoutError s are generated separately instead.
Parameters
  • properties (BackendProperties) – device backend properties.
  • gate_error (bool) – Include depolarizing gate errors (Default: True).
  • thermal_relaxation (Bool) – Include thermal relaxation errors (Default: True).
  • gate_lengths (list) – Override device gate times with custom values. If None use gate times from backend properties. (Default: None).
  • gate_length_units (str) – Time units for gate length values in gate_lengths. Can be ‘ns’, ‘ms’, ‘us’, or ‘s’ (Default: ‘ns’).
  • temperature (double) – qubit temperature in milli-Kelvin (mK) (Default: 0).
  • warnings (bool) – DEPRECATED, Display warnings (Default: None).
  • target (Target) – device backend target (Default: None). When this is supplied, several options are disabled: properties, gate_lengths and gate_length_units are not used during the construction of gate errors. Default values are always used for warnings.
Returns
A list of tuples (label, qubits, QuantumError), for gates with non-zero quantum error terms, where label is the label of the noisy gate, qubits is the list of qubits for the gate.
Return type
list
Raises
NoiseError – If invalid arguments are supplied.
Was this page helpful?
