Compute dissociation curves for strong coupling systems with QunaSys QSCI
Usage estimate (NOTE: This is an estimate only. Your runtime may vary.)
  • 5 minutes QPU time on ibm_strasbourg
  • 2.5 minutes QPU time on ibm_torino
Background
Finding the ground state energy of molecules is a common step in material science, drug discovery and various other fields. Solving the ground state energy for strong coupling system in the dissociation process is particularly known to be difficult with classical methods such as Hartree-Fock (HF), CISD and CCSD. While FCI produces the exact ground state of the given Hamiltonian, diagonalizing the Hamiltonian using the full subspace basis vectors and is usually computationally costly. In this tutorial, you will learn how to use QURI Chemistry to produce the dissociation curve of N2N_2.
Requirements
Install the following dependencies to run the code in this tutorial.
!pip install qiskit-ibm-catalog
!pip install pyscf
Setup
To use QURI Chemistry, select the function via QiskitFunctionCatalog. You need an IBM Quantum Premium Plan account with a license from Qunasys to run this function.
catalog = QiskitFunctionsCatalog()
qsci = catalog.load("qunasys/qsci")
Construct the molecule in json format. As an illustration, we assume the separation between the 2 nitrogen atoms to be 1 angstrom apart from each other.
parameters = {}
parameters["mole"] = {"atom": "N 0 0 0; N 0 0 1.0"}
Next, configure the QSCI algorithm by selecting the ansatz. Double excitation ansatz is recommended. CCSD parameter is used to prepare the ansatz.
parameters["ansatz"] = "DoubleExcitation"
parameters["ansatz_setting"] = {"n_amplitudes": 20}
parameters["state_prep_method"] = "CCSD"
Discretion is required to select the subspace size RR to run the QSCI algorithm. A space too small cannot capture enough important configurations. However, a space too large would correspond to FCI and the use of quantum computers become redundant. In the sto-3g basis, N2N_2 contains 10 spatial orbitals and 14 electrons. This thus maps to a 20-qubit problem. The FCI space contains 14400 basis vectors, so the selected subspace size should not approach this value. We choose half of this size as the subspace size for demonstration.
parameters["qsci_setting"] = {
    "n_shots": 100000,
    "number_of_states_pick_out": 7200,
from pprint import pprint
pprint(parameters)
{'ansatz': 'DoubleExcitation',
 'ansatz_setting': {'n_amplitudes': 20},
 'mole': {'atom': 'N 0 0 0; N 0 0 1.0'},
 'qsci_setting': {'n_shots': 100000, 'number_of_states_pick_out': 7200},
 'state_prep_method': 'CCSD'}
To improve the performance, it is recommended to turn on configuration recovery. For 20 qubit system with R=7200R = 7200, using the default configuration recovery setting is sufficient.
parameters["mitigation_setting"] = {"configuration_recovery": True}
Step 3: Execute using Qiskit Primitives
Now, pick the backend to submit the job to the function
result = qsci.run(
    method="QSCI",
    parameters=parameters,
    backend="ibm_torino",
qsci_energy = result["qsci_energy"]
state_vector = result["state_vector"].copy()
FCI computation is still feasible at the scale of 20-qubit. We use PySCF to perform several classical computations and compare the energies against the QSCI energy.
Step 4: Compare with classical methods
from pyscf import gto, scf, cc, ci, fci
mole = gto.M(atom="N 0 0 0; N 0 0 1.0")
mf = scf.RHF(mole).run(verbose=0)
cisd = ci.CISD(mf).run(verbose=0)
ccsd = cc.CCSD(mf).run(verbose=0)
fci_solver = fci.FCI(mf).run()
    f"HF energy   : {mf.e_tot: .4f} Ha, error: {(mf.e_tot - fci_solver.e_tot) * 1000: .2f} mHa"
    f"CISD energy : {cisd.e_tot: .4f} Ha, error: {(cisd.e_tot - fci_solver.e_tot) * 1000: .2f} mHa"
    f"CCSD energy : {ccsd.e_tot: .4f} Ha, error: {(ccsd.e_tot - fci_solver.e_tot) * 1000: .2f} mHa"
    f"QSCI energy : {qsci_energy: .4f} Ha, error: {(qsci_energy - fci_solver.e_tot) * 1000: .2f} mHa"
print(f"FCI energy  : {fci_solver.e_tot: .4f} Ha")
HF energy   : -107.4195 Ha, error:  129.77 mHa
CISD energy : -107.5414 Ha, error:  7.91 mHa
CCSD energy : -107.5467 Ha, error:  2.58 mHa
QSCI energy : -107.5492 Ha, error:  0.09 mHa
FCI energy  : -107.5493 Ha
You can see that QSCI is the only method that falls into the chemical accuracy region where energy error needs to be less than 1.6 mHa, and this is done by diagonalizing the subspace Hamiltonian half the size of the FCI space.
Producing the dissociation curve
As mentioned at the beginning of this tutorial, the non-triviality of our method is that it produces the whole N2N_2 dissociation curve with high accuracy. You can reuse the qsci input above with different distance settings.
def get_qsci_json(distance: float) -> None:
    return {
        "mole": {"atom": f"N 0 0 0; N 0 0 {distance}"},
        "ansatz": "DoubleExcitation",
        "state_prep_method": "CCSD",
        "ansatz_setting": {"n_amplitudes": 20},
        "qsci_setting": {
            "n_shots": 100000,
        "mitigation_setting": {"configuration_recovery": True},
With this function, we scan over d=0.7,1.0,1.5,2.0,2.4d = 0.7, 1.0, 1.5, 2.0, 2.4.
d = 0.7 angstrom
input_07 = get_qsci_json(0.7)
result_07 = qsci.run(method="QSCI", parameters=input_07, backend="ibm_torino")
mole = gto.M(atom="N 0 0 0; N 0 0 0.7")
qsci_energy_07 = result_07["qsci_energy"]
    f"QSCI energy : {qsci_energy_07: .4f} Ha, error: {(qsci_energy_07 - fci_solver.e_tot) * 1000: .2f} mHa"
HF energy   : -105.6974 Ha, error:  67.57 mHa
CISD energy : -105.7632 Ha, error:  1.76 mHa
CCSD energy : -105.7642 Ha, error:  0.75 mHa
QSCI energy : -105.7650 Ha, error:  0.01 mHa
FCI energy  : -105.7650 Ha
d = 1.5 angstrom
input_15 = get_qsci_json(1.5)
result_15 = qsci.run(method="QSCI", parameters=input_15, backend="ibm_torino")
mole = gto.M(atom="N 0 0 0; N 0 0 1.5")
qsci_energy_15 = result_15["qsci_energy"]
    f"QSCI energy : {qsci_energy_15: .4f} Ha, error: {(qsci_energy_15 - fci_solver.e_tot) * 1000: .2f} mHa"
HF energy   : -107.2724 Ha, error:  309.19 mHa
CISD energy : -107.5269 Ha, error:  54.69 mHa
CCSD energy : -107.5679 Ha, error:  13.78 mHa
QSCI energy : -107.5810 Ha, error:  0.66 mHa
FCI energy  : -107.5816 Ha
d = 2.0 angstrom
input_20 = get_qsci_json(2.0)
result_20 = qsci.run(method="QSCI", parameters=input_20, backend="ibm_torino")
mole = gto.M(atom="N 0 0 0; N 0 0 2.0")
qsci_energy_20 = result_20["qsci_energy"]
    f"QSCI energy : {qsci_energy_20: .4f} Ha, error: {(qsci_energy_20 - fci_solver.e_tot) * 1000: .2f} mHa"
HF energy   : -106.8715 Ha, error:  583.65 mHa
CISD energy : -107.2857 Ha, error:  169.48 mHa
CCSD energy : -107.5570 Ha, error: -101.83 mHa
QSCI energy : -107.4519 Ha, error:  3.21 mHa
FCI energy  : -107.4552 Ha
d = 2.4 angstrom
input_24 = get_qsci_json(2.4)
result_24 = qsci.run(method="QSCI", parameters=input_24, backend="ibm_torino")
mole = gto.M(atom="N 0 0 0; N 0 0 2.4")
qsci_energy_24 = result_24["qsci_energy"]
    f"QSCI energy : {qsci_energy_24: .4f} Ha, error: {(qsci_energy_24 - fci_solver.e_tot) * 1000: .2f} mHa"
HF energy   : -106.6566 Ha, error:  784.70 mHa
CISD energy : -107.1734 Ha, error:  267.94 mHa
CCSD energy : -107.0828 Ha, error:  358.53 mHa
QSCI energy : -107.4413 Ha, error:  0.01 mHa
FCI energy  : -107.4413 Ha
The dissociation curve
Finally, plot the QSCI energy against the classical methods: HF, CISD, CCSD, and FCI. You can see that all the QSCI points match well with the FCI values.
hf_list = []
cisd_list = []
ccsd_list = []
fci_list = []
for d in np.linspace(0.7, 2.4, 18):
    mole = gto.M(atom=f"N 0 0 0; N 0 0 {d}")
    hf_list.append(mf.e_tot)
    cisd_list.append(cisd.e_tot)
    ccsd_list.append(ccsd.e_tot)
    fci_list.append(fci_solver.e_tot)
ds = np.linspace(0.7, 2.4, 18)
fig, ax = plt.subplots(1, 1)
ax.plot(ds, hf_list, "-o", label="HF")
ax.plot(ds, cisd_list, "-o", label="CISD")
ax.plot(ds, ccsd_list, "-o", label="CCSD")
ax.plot(ds, fci_list, "-o", label="FCI")
ax.plot(
    [0.7, 1.0, 1.5, 2.0, 2.4],
        qsci_energy_07,
        qsci_energy,
        qsci_energy_15,
        qsci_energy_20,
        qsci_energy_24,
    "o",
    color="black",
    markersize=8,
    label="QSCI",
ax.legend(fontsize=20)
ax.tick_params("both", labelsize=16)
ax.set_xlabel("d", size=20)
ax.set_ylabel("Energy (Ha)", size=20)
ax.set_title("$N_2$ dissociation curve", size=20)
fig.set_size_inches(14, 8)
Was this page helpful?
