Informações sobre tradução
Traduções adicionais para esta página em outros idiomas estarão disponíveis em breve.
Configure noise management with Sampler
    qiskit-ibm-runtime~=0.47.0
There are several ways to manage noise, typically by using various error mitigation and error suppression techniques to avoid errors before they happen. These techniques usually cause pre-processing overhead. Therefore, it is important to achieve a balance between perfecting your results and ensuring that your job completes in a reasonable amount of time.
Sampler supports the following noise management techniques. See Error mitigation and suppression techniques for an explanation of each.
Note
Not all options work together on all types of circuits. See the feature compatibility table guide for full details.
Example
# from qiskit_ibm_runtime import Sampler
from qiskit_ibm_runtime.executor_sampler import Sampler
sampler = Sampler(backend)
    f">>> dynamical decoupling sequence to use: "
    f"{sampler.options.dynamical_decoupling.sequence_type}"
Next steps
Recommendations
Esta página foi útil?
