XPulseType
class XPulseType(value)
The type of X-pulse to apply for a bit-flip check measurement.
Attributes
XSLOW
Default value: 'xslow'
An xslow gate.
RX
Default value: 'rx'
Twenty rx gates with angles pi/20.
Methods
encode
encode(encoding='utf-8', errors='strict')
Encode the string using the codec registered for encoding.
encoding
The encoding in which to encode the string.
errors
The error handling scheme to use for encoding errors. The default is ‘strict’ meaning that encoding errors raise a UnicodeEncodeError. Other possible values are ‘ignore’, ‘replace’ and ‘xmlcharrefreplace’ as well as any other name registered with codecs.register_error that can handle UnicodeEncodeErrors.
replace
replace(old, new, count=-1, /)
Return a copy with all occurrences of substring old replaced by new.
count
Maximum number of occurrences to replace. -1 (the default value) means replace all occurrences.
If the optional argument count is given, only the first count occurrences are replaced.
split
split(sep=None, maxsplit=-1)
Return a list of the substrings in the string, using sep as the separator string.
sep
The separator used to split the string.
When set to None (the default value), will split on any whitespace character (including \n \r \t \f and spaces) and will discard empty strings from the result.
maxsplit
Maximum number of splits (starting from the left). -1 (the default value) means no limit.
Note, str.split() is mainly useful for data that has been intentionally delimited. With natural text that includes punctuation, consider using the regular expression module.
rsplit
rsplit(sep=None, maxsplit=-1)
sep
maxsplit
Splitting starts at the end of the string and works to the front.
join
join(iterable, /)
Concatenate any number of strings.
The string whose method is called is inserted in between each given string. The result is returned as a new string.
Example: ‘.’.join([‘ab’, ‘pq’, ‘rs’]) -> ‘ab.pq.rs’
capitalize
capitalize()
Return a capitalized version of the string.
More specifically, make the first character have upper case and the rest lower case.
casefold
casefold()
Return a version of the string suitable for caseless comparisons.
title
title()
Return a version of the string where each word is titlecased.
More specifically, words start with uppercased characters and all remaining cased characters have lower case.
center
center(width, fillchar=' ', /)
Return a centered string of length width.
Padding is done using the specified fill character (default is a space).
count
count(sub[, start[, end]]) → int
Return the number of non-overlapping occurrences of substring sub in string S[start:end]. Optional arguments start and end are interpreted as in slice notation.
expandtabs
expandtabs(tabsize=8)
Return a copy where all tab characters are expanded using spaces.
If tabsize is not given, a tab size of 8 characters is assumed.
find
find(sub[, start[, end]]) → int
Return the lowest index in S where substring sub is found, such that sub is contained within S[start:end]. Optional arguments start and end are interpreted as in slice notation.
Return -1 on failure.
partition
partition(sep, /)
Partition the string into three parts using the given separator.
This will search for the separator in the string. If the separator is found, returns a 3-tuple containing the part before the separator, the separator itself, and the part after it.
If the separator is not found, returns a 3-tuple containing the original string and two empty strings.
index
index(sub[, start[, end]]) → int
Raises ValueError when the substring is not found.
ljust
ljust(width, fillchar=' ', /)
Return a left-justified string of length width.
lower
lower()
Return a copy of the string converted to lowercase.
lstrip
lstrip(chars=None, /)
Return a copy of the string with leading whitespace removed.
If chars is given and not None, remove characters in chars instead.
rfind
rfind(sub[, start[, end]]) → int
Return the highest index in S where substring sub is found, such that sub is contained within S[start:end]. Optional arguments start and end are interpreted as in slice notation.
rindex
rindex(sub[, start[, end]]) → int
rjust
rjust(width, fillchar=' ', /)
Return a right-justified string of length width.
rstrip
rstrip(chars=None, /)
Return a copy of the string with trailing whitespace removed.
rpartition
rpartition(sep, /)
This will search for the separator in the string, starting at the end. If the separator is found, returns a 3-tuple containing the part before the separator, the separator itself, and the part after it.
If the separator is not found, returns a 3-tuple containing two empty strings and the original string.
splitlines
splitlines(keepends=False)
Return a list of the lines in the string, breaking at line boundaries.
Line breaks are not included in the resulting list unless keepends is given and true.
strip
Return a copy of the string with leading and trailing whitespace removed.
swapcase
swapcase()
Convert uppercase characters to lowercase and lowercase characters to uppercase.
translate
translate(table, /)
Replace each character in the string using the given translation table.
table
Translation table, which must be a mapping of Unicode ordinals to Unicode ordinals, strings, or None.
The table must implement lookup/indexing via __getitem__, for instance a dictionary or list. If this operation raises LookupError, the character is left untouched. Characters mapped to None are deleted.
upper
upper()
Return a copy of the string converted to uppercase.
startswith
startswith(prefix[, start[, end]]) → bool
Return True if S starts with the specified prefix, False otherwise. With optional start, test S beginning at that position. With optional end, stop comparing S at that position. prefix can also be a tuple of strings to try.
endswith
endswith(suffix[, start[, end]]) → bool
Return True if S ends with the specified suffix, False otherwise. With optional start, test S beginning at that position. With optional end, stop comparing S at that position. suffix can also be a tuple of strings to try.
removeprefix
removeprefix(prefix, /)
Return a str with the given prefix string removed if present.
If the string starts with the prefix string, return string[len(prefix):]. Otherwise, return a copy of the original string.
removesuffix
removesuffix(suffix, /)
Return a str with the given suffix string removed if present.
If the string ends with the suffix string and that suffix is not empty, return string[:-len(suffix)]. Otherwise, return a copy of the original string.
isascii
isascii()
Return True if all characters in the string are ASCII, False otherwise.
ASCII characters have code points in the range U+0000-U+007F. Empty string is ASCII too.
islower
islower()
Return True if the string is a lowercase string, False otherwise.
A string is lowercase if all cased characters in the string are lowercase and there is at least one cased character in the string.
isupper
isupper()
Return True if the string is an uppercase string, False otherwise.
A string is uppercase if all cased characters in the string are uppercase and there is at least one cased character in the string.
istitle
istitle()
Return True if the string is a title-cased string, False otherwise.
In a title-cased string, upper- and title-case characters may only follow uncased characters and lowercase characters only cased ones.
isspace
isspace()
Return True if the string is a whitespace string, False otherwise.
A string is whitespace if all characters in the string are whitespace and there is at least one character in the string.
isdecimal
isdecimal()
Return True if the string is a decimal string, False otherwise.
A string is a decimal string if all characters in the string are decimal and there is at least one character in the string.
isdigit
isdigit()
Return True if the string is a digit string, False otherwise.
A string is a digit string if all characters in the string are digits and there is at least one character in the string.
isnumeric
isnumeric()
Return True if the string is a numeric string, False otherwise.
A string is numeric if all characters in the string are numeric and there is at least one character in the string.
isalpha
isalpha()
Return True if the string is an alphabetic string, False otherwise.
A string is alphabetic if all characters in the string are alphabetic and there is at least one character in the string.
isalnum
isalnum()
Return True if the string is an alpha-numeric string, False otherwise.
A string is alpha-numeric if all characters in the string are alpha-numeric and there is at least one character in the string.
isidentifier
isidentifier()
Return True if the string is a valid Python identifier, False otherwise.
Call keyword.iskeyword(s) to test whether string s is a reserved identifier, such as “def” or “class”.
isprintable
isprintable()
Return True if the string is printable, False otherwise.
A string is printable if all of its characters are considered printable in repr() or if it is empty.
zfill
zfill(width, /)
Pad a numeric string with zeros on the left, to fill a field of the given width.
The string is never truncated.
format
format(*args, **kwargs) → str
Return a formatted version of S, using substitutions from args and kwargs. The substitutions are identified by braces (‘{’ and ‘}’).
format_map
format_map(mapping) → str
Return a formatted version of S, using substitutions from mapping. The substitutions are identified by braces (‘{’ and ‘}’).
maketrans
static maketrans()
Return a translation table usable for str.translate().
If there is only one argument, it must be a dictionary mapping Unicode ordinals (integers) or characters to Unicode ordinals, strings or None. Character keys will be then converted to ordinals. If there are two arguments, they must be strings of equal length, and in the resulting dictionary, each character in x will be mapped to the character at the same position in y. If there is a third argument, it must be a string, whose characters will be mapped to None in the result.
