AddPostSelectionMeasures
class AddPostSelectionMeasures(*args, **kwargs)
Bases: TransformationPass
Add a post selection measurement after every terminal measurement.
A post selection measurement is a measurement that follows a regular measurement on a given qubit. It consists of a narrowband X-pulse followed by a regular measurement operation. In the absence of noise, it is expected to return (b + 1) % 2, where b is the outcome of the original measurement.
This pass adds post selection measurements after every terminal measurement, i.e., after every measurement that is not followed by another operation on the same wire. The added measurements are placed after a barrier, and write to new classical registers that are copies of the DAG’s registers, with modified names.
When this pass encounters a control flow operation, it iterates through all of its blocks. It marks as “terminated” only those qubits that are terminated in every one of the blocks, and it treats as unterminated every other qubit.
Initialize the pass.
Parameters
- x_pulse_type – The type of X-pulse to apply for the post-selection measurements.
- post_selection_suffix – A fixed suffix to append to the names of the classical registers when copying them.
Attributes
is_analysis_pass
is_transformation_pass
Methods
execute
execute(passmanager_ir, state, callback=None)
Parameters
- passmanager_ir (Any) – Qiskit IR to optimize.
- state (PassManagerState) – State associated with workflow execution by the pass manager itself.
- callback (Callable | None) – A callback function which is caller per execution of optimization task.
Returns
Return type
name
run
run(dag)
Parameters
dag (DAGCircuit) – the dag on which the pass is run.
Raises
NotImplementedError – when this is left unimplemented for a pass.
update_status
update_status(state, run_state)
Update workflow status.
Parameters
- state (PassManagerState) – Pass manager state to update.
- run_state (RunState) – Completion status of current task.
Returns
Updated pass manager state.
Return type
