Solve the Sherrington-Kirkpatrick model with the ParityQC Parity Twine Optimizer
Usage estimate: 10 seconds on a Nighthawk r2 processor. (NOTE: This is an estimate only. Your runtime may vary.)
Learning outcomes
  • Use the Parity Twine Optimizer to solve the Sherrington-Kirkpatrick model.
  • Learn which options for the Parity Twine Optimizer are available and what results are output.
Background
This tutorial demonstrates how to solve the Sherrington-Kirkpatrick model using the ParityQC Parity Twine Optimizer.
It provides code to formulate the problem entirely locally in a form that can interface with the Parity Twine Optimizer.
The Sherrington-Kirkpatrick model
The Sherrington-Kirkpatrick (SK) model is a foundational model in statistical mechanics, specifically within the study of spin glasses. Unlike the standard Ising model, where interactions are usually limited to nearest neighbors, the SK model is an infinite-range model, meaning every spin interacts with every other spin in the system. This leads to a highly complex, "rugged", energy landscape characterized by many local minima, which is the hallmark of glassy behavior.
The core feature of the SK model lies in frustration. In the model, interaction strengths JijJ_ij between spins are randomly distributed between positive and negative values. This leads to situations (for example, in triangular arrangements) where spins cannot be arranged to minimize all interactions simultaneously. In the SK model, because every spin interacts with every other spin, this frustration is compounded globally, leading to a web of conflicting constraints.
Mathematical formulation
The state of the system is defined by a set of NN Ising spins, si{+1,1}s_i \in \{+1, -1 \} . The energy of a specific configuration is given by the Hamiltonian:
H=1ijNJijsisjH = - \sum_{1 \leq i \leq j \leq N} J_{ij} s_i s_j
where JijJ_{ij} is the coupling strength between spin ii and spin jj.
In the SK model, the couplings JijJ_{ij} are independent and identically distributed random variables. To ensure that the energy remains extensive (proportional to NN) as NN \rightarrow \infty, the variance of the couplings must scale with the number of particles:
JijN(0,J2N)J_{ij} \sim \mathcal{N} \left( 0, \frac{J^2}{N} \right)
The ground state for a given HH is the specific configuration of spins (s1,s2,...sns_1, s_2, ...s_n), which minimizes the energy. Finding the ground state is an NP-hard optimization problem.
Requirements
Before starting this tutorial, ensure the following are installed:
  • Qiskit Functions Catalog IBM Client (pip install qiskit-ibm-catalog)
  • Qiskit addon Optimization Mapper (pip install qiskit_addon_opt_mapper)
  • NumPy (pip install numpy)
You also need permission to access the ParityQC Twine Optimizer function. To request access, complete this form.
Setup
(This code assumes you've already saved your account to your local environment.)
First, import all required packages for this tutorial.
Load the Parity Twine Optimizer from the Qiskit Functions catalog:
function = catalog.load("parityqc/parity-twine-optimizer")
Step 1: Define the problem as an objective function
Instead of obtaining the SK problem from a library as we do for the Market Split problem, you formulate it directly.
The generate_sk_problem function formulates the SK problem directly in the required dictionary format. The only input required is n, the number of spins in the model.
def generate_sk_problem(
    n: int,
    coupling_mean: float = 0.0,
    coupling_std: float = 1.0,
    local_fields_mean: float = 0.0,
    local_fields_std: float = 0.0,
    edge_density: float = 1.0,
    ensure_extensivity: bool = False,
    seed: int | None = None,
) -> dict:
    """Generate the Sherrington-Kirkpatrick (SK) model with varying
     edge density.
    Samples couplings and local fields via :func:`generate_couplings_sk_model`
    and assembles the corresponding Ising Hamiltonian
        H = -∑_{i<j} J_ij z_i z_j - ∑_i h_i z_i,
    where z_i ∈ {-1, +1}.
    Args:
        n: Number of spins (>= 2).
        coupling_mean: Mean coupling before optional SK scaling.
        coupling_std: Coupling std before optional SK scaling.
        local_fields_mean: Mean longitudinal field.
        local_fields_std: Std of the longitudinal fields.
        edge_density: Fraction of non-zero couplings, in ``[2/n, 1]``.
        ensure_extensivity: Whether to apply the SK 1/n scaling.
        seed: random number generator seed.
    Returns:
        A ``ProblemRepresentation`` encoding the SK Hamiltonian.
    Raises:
        ValueError: If ``n < 2``, ``coupling_std < 0``, ``local_fields_std < 0``,
            or ``edge_density`` is outside ``[2/n, 1]``.
    couplings, local_fields = _generate_couplings_sk_model(
        n=n,
        coupling_mean=coupling_mean,
        coupling_std=coupling_std,
        local_fields_mean=local_fields_mean,
        local_fields_std=local_fields_std,
        edge_density=edge_density,
        ensure_extensivity=ensure_extensivity,
        seed=seed,
    # Handle quadratic terms: coupling[i, j] * zj[i] * zj[j]
    # Only iterate over the upper triangle (i < j)
    sk_problem = {
        str((i, j)): float(couplings[i, j])
        for i in range(n)
        for j in range(i + 1, n)
        if couplings[i, j] != 0
    # Handle linear terms: local_fields[i] * zj[i]
    sk_problem.update(
            str((i,)): float(local_fields[i])
            for i in range(n)
            if local_fields[i] != 0
    return sk_problem
Use the function _generate_couplings_sk_model to calculate the random coupling terms in the SK model. For more control over the couplings, you can use optional arguments, which are explained in the function's docstring.
def _generate_couplings_sk_model(
    n: int,
) -> tuple[np.ndarray, np.ndarray]:
    """Generate random couplings and local fields for an Ising / SK model.
    Couplings are Gaussian. With ``ensure_extensivity=True`` they follow the
    Sherrington-Kirkpatrick scaling ``J_ij ~ N(coupling_mean/n, coupling_std^2/n)``
    (extensive energy, O(n)); otherwise ``J_ij ~ N(coupling_mean, coupling_std^2)``
    (energy O(n^2)). Fields are ``h_i ~ N(local_fields_mean, local_fields_std^2)``.
    ``edge_density`` sets the fraction of the ``n*(n-1)/2`` possible couplings that
    are non-zero (1 = fully dense). The kept edges always include a random spanning
    tree, so the interaction graph is guaranteed connected. This requires at least
    ``n-1`` edges, so ``edge_density`` must be at least ``2/n``.
    Args:
    Returns:
        Tuple ``(couplings, fields)``: a symmetric ``(n, n)`` matrix with zero
        diagonal, and an ``(n,)`` field vector.
    Raises:
    if n < 2:
        raise ValueError(f"n must be >= 2, got {n}")
    if coupling_std < 0 or local_fields_std < 0:
        raise ValueError(
            "coupling_std and local_fields_std must be non-negative"
    # A connected graph on n nodes needs at least n-1 of the n*(n-1)/2 possible
    # edges, so edge_density has a hard lower bound of 2/n.
    min_edge_density = 2.0 / n
    if not min_edge_density <= edge_density <= 1.0:
        raise ValueError(
            f"edge_density must be in [{min_edge_density:.4g}, 1] for n={n} "
            f"(at least n-1 edges are needed to keep the graph connected), "
            f"got {edge_density}"
    j_loc, j_scale = (
        (coupling_mean / n, coupling_std / np.sqrt(n))
        if ensure_extensivity
        else (coupling_mean, coupling_std)
    upper_idx = np.triu_indices(n, k=1)
    n_edges = len(upper_idx[0])
    # Select which edges are present.
    if edge_density < 1.0:
        n_keep = int(round(edge_density * n_edges))
        # Map each (i, j) node pair to its position in the flat upper-triangle list.
        pair_to_flat = {
            (int(i), int(j)): idx
            for idx, (i, j) in enumerate(
                zip(upper_idx[0], upper_idx[1], strict=False)
        # Random spanning tree: node perm[k] links to a random earlier node.
        perm = rng.permutation(n)
        keep = np.zeros(n_edges, dtype=bool)
        for k in range(1, n):
            child, parent = perm[k], perm[rng.integers(0, k)]
            i, j = min(child, parent), max(child, parent)
            keep[pair_to_flat[(int(i), int(j))]] = True
        # Fill the remaining budget with random non-tree edges.
        remaining = n_keep - (n - 1)
        if remaining > 0:
            keep[
                rng.choice(
                    np.flatnonzero(~keep), size=remaining, replace=False
            ] = True
        keep = np.ones(n_edges, dtype=bool)
    n_present = int(keep.sum())
    if j_scale == 0.0:
        vals = np.full(n_present, j_loc)
        vals = rng.normal(loc=j_loc, scale=j_scale, size=n_present)
    couplings = np.zeros((n, n))
    couplings[upper_idx[0][keep], upper_idx[1][keep]] = vals
    couplings += couplings.T  # symmetrize; diagonal stays zero
    fields = (
        np.full(n, local_fields_mean)
        if local_fields_std == 0.0
        else rng.normal(loc=local_fields_mean, scale=local_fields_std, size=n)
    return couplings, fields
Step 2: Solve the problem using the Parity Twine Optimizer
With the functions above, you can set up the SK problem and a find solution by using the Twine Optimizer and a chosen IBM Quantum® backend.
To run the function, choose a suitable backend; for example, ibm_phoenix.
Optionally, use options for additional control over the submission:
options = {
    "shots": 100000,
    "postprocessing_level": 1,
    "transpile_only": False,
    "job_tags": ["sk"],
where shots is an integer that specifies the number of circuit executions, postprocessing_level determines if post-processing is applied to the result, transpile_only chooses if the problem is only transpiled to a circuit (and not solved), and job_tags is label to identify the job on IBM Quantum Platform.
The size of the SK model is defined by NN, the number of interacting spins. Once you choose NN, the code above generates the problem for n_spins.
Run the optimizer:
n_spins = 50
sk_problem = generate_sk_problem(n_spins)
function_job = function.run(
    problem=sk_problem,
    variable_type="spin",
    backend_name="ibm_phoenix",
    options=options,
print(f"Job ID: {function_job.job_id}")
Check the job status:
# Monitor the job status
function_job.status()
Retrieve results:
result = function_job.result()
result
The result is of form:
    'solution': {'0': 1, '1': 1, '10': 1, '11': 1, ... },
    'objective_value':  -240.5425312543882,
    'solution_bitstring': '00001101110100100111001110101001101111111011001110',
    'metadata': {
        'circuit_metrics': {
            'depth': 523,
            'gate_count': 10118,
            'two_qubit_gate_depth': 196,
            'two_qubit_gate_count': 2499,
            'num_qubits': 50,
            'operations': {'sx': 3353, 'rz': 3320, 'cz': 2499, 'delay': 894, 'measure': 50, 'x': 2},
        'solver_info': {
            'variable_mapping': {'0': 0, '1': 1, '10': 2, '11': 3, ... },
            'bitstring_distributions': {
                'before_postprocessing': {'011101110010110111001110011000': 1, ... },
                'after_postprocessing': {'011011110000110101001111011000': 1, ... }
            'best_parameters': {
                'beta': [-0.4602084830507902],
                'gamma': [1.8500357096574955]
        'resource_usage': {
            'RUNNING: MAPPING': {'CPU_TIME': 290.272},
            'RUNNING: OPTIMIZING_FOR_HARDWARE': {'CPU_TIME': 0.494},
            'RUNNING: WAITING_FOR_QPU': {'CPU_TIME': 8.775},
            'RUNNING: EXECUTING_QPU': {'QPU_TIME': 31.0},
            'RUNNING: POST_PROCESSING': {'CPU_TIME': 162.96},
where the solution dictionary corresponds to the qubits defined in the problem and gives their optimized spin values for the SK model Hamiltonian. This specific sequence of spins in the optimal solution represents the configuration that minimizes the total system energy based on the given random interaction strengths. In the SK model, this can be regarded as the lowest energy state of a disordered magnetic system.
metadata gives information on the transpilation (two qubit gates counts/depth, gates used, active qubits) and various runtimes.
Next steps
Recommendations
Was this page helpful?
