Configure noise management with Sampler
The code on this page was developed using the following requirements. We recommend using these versions or newer.
qiskit-ibm-runtime~=0.46.1
There are several ways to manage noise, typically by using various error mitigation and error suppression techniques to avoid errors before they happen. These techniques usually cause pre-processing overhead. Therefore, it is important to achieve a balance between perfecting your results and ensuring that your job completes in a reasonable amount of time.
Sampler supports the following noise management techniques. See Error mitigation and suppression techniques for an explanation of each.
Not all options work together on all types of circuits. See the feature compatibility table guide for full details.
Example
sampler = Sampler(backend)
f">>> dynamical decoupling sequence to use: "
f"{sampler.options.dynamical_decoupling.sequence_type}"
)Output:
Next steps
- Learn more about error mitigation and error suppression techniques.
- Explore Sampler options.
- Decide what execution mode to run your job in.
