Probabilistic error cancellation with logical noise models
Usage estimate: 28 minutes on a Heron r3 processor (NOTE: This is an estimate only. Your runtime might vary.)
In this tutorial we will evaluate observables of a 22-site Ising model on a hexagonal lattice using a Heron QPU, which has a heavy-hexagonal qubit topology. Many demonstrations on Heron QPUs focus on systems defined on heavy-hexagonal lattices to match the system's connectivity; however, hexagonal models tend to be more interesting to study as they appear more commonly in nature and are more difficult to simulate classically due to their denser connectivity. Since the qubit topology of the QPU cannot directly support the connectivity of a hexagonal lattice, we must decide how to efficiently embed the hexagonal model onto the qubit topology. In this example we represent each site in the Ising model with a qubit lying on a vertex of the heavy-hex QPU lattice. We use the qubits on the edges (mediator qubits) to facilitate entanglement between the Ising qubits on the vertices. Additionally, the mediator qubits implement entanglement in such a way that they are always expected to return to the ground state . If a mediator qubit measures , it indicates that a logical error occurred during circuit execution; postselecting only samples with no detected errors on the mediator qubits yields a smaller distribution of logical samples that might have a higher fidelity than the raw, noisy distribution. Not only can we detect that an error occurred by measuring a mediator qubit, we can also determine exactly which logical errors that qubit is capable of detecting throughout the circuit. Removing the noise generators the mediator qubits' symmetry checks are capable of detecting from a noise model leaves a reduced noise model, which can be mitigated using techniques such as probabilistic error cancellation (PEC).
In this notebook example, we will combine the error detection technique described above with PEC to counteract the quantum noise more effectively than either technique can do alone. We will use 49 qubits to embed the 22-qubit Ising model and use the extra 27 mediator qubits for error detection. We will run PEC on the postselected noise channel to mitigate the noise that evades the symmetry checks. In addition to combining error detection with PEC, we will use techniques such as TREX readout error mitigation and non-Markovian error checks to further combat the effect of quantum noise.
The workflow is as follows:
- Classically simulate observable expectation values for the 22-qubit hex-Ising model
- Implement the 49-qubit error-detecting hex-Ising model with a quantum circuit and transpile to QPU backend
- Specify the entangling layers in the circuit with
samplomatic. We will learn and mitigate the noise affecting these entangling layers. - Add non-Markovian error checks to the circuit
- Learn the gate and readout noise affecting the circuit
- Prune the noise model of terms detected by the symmetry checks
- Sample the error-detecting circuit. Postselect only samples that pass all symmetry and non-Markovian error checks, and use TREX readout mitigation for all expectation value calculations
- Sample the error-detecting circuit with PEC, but do not postselect based on symmetry checks and mitigate the full learned noise channel.
- Sample the error-detecting circuit with PEC. Postselect based on symmetry checks and only mitigate the noise that is undetectable by the checks.
- Calculate expectation values and compare strategies. Observe that QED+PEC more effectively cancels the noise affecting the experiment than either method on its own and produces converged expectation values using far fewer shots than required by PEC alone.
Requirements
Before starting this tutorial, run the following command to get all the required packages:
%pip install networkx numpy "qiskit[visualization]" "qiskit-ibm-runtime[visualization]" samplomatic qiskit-mitigation matplotlib "qiskit-noise-learning @ git+https://github.com/Qiskit/qiskit-noise-learning.git@ieee-demo-2026"
The collapsed cell below defines the figure helpers used throughout this notebook.
# Figure helpers for this notebook (collapsed): all plotting and styling lives here. # The chip maps follow the style of Fig. 30 of arXiv:2607.25998. from math import comb import matplotlib.pyplot as plt from matplotlib import cm from matplotlib.colors import BoundaryNorm from matplotlib.patches import Circle, Rectangle, Wedge # one typography scheme for every figure in the notebook plt.rcParams.update( { "font.size": 13, "axes.titlesize": 15, "axes.labelsize": 13, "xtick.labelsize": 11, "ytick.labelsize": 11, "legend.fontsize": 11, } ) def x_labels(layout, n_data): """Per-observable tick labels carrying the physical qubit indices (site i = qubit i).""" return [f"$X_{{{layout[i]}}}$" for i in range(n_data)] def plot_layout(backend, layout, n_data): """Chip cartoon of the embedding: data qubits green, check qubits orange.""" from qiskit.visualization import plot_coupling_map return plot_coupling_map( num_qubits=backend.num_qubits, qubit_coordinates=None, coupling_map=list(backend.coupling_map.get_edges()), figsize=(9, 9), qubit_color=[ "#4CAF50" if q in layout[:n_data] else "#FF9800" if q in layout[n_data:] else "#DDDDDD" for q in range(backend.num_qubits) ], qubit_size=220, line_width=2, font_size=90, ) def plot_exact(obs_exact, tick_labels, title): plt.figure(figsize=(12, 4)) plt.plot(obs_exact, "o-") plt.title(title) plt.xticks(np.arange(len(obs_exact)), tick_labels) plt.xlabel("Observable") plt.ylabel(r"$\langle X \rangle$") plt.grid() def draw_toy_circuit( generate_ed_ising, zz_coeff, x_coeff, include_checks=True ): """The boxing pipeline on a 3-plaquette-ring miniature (1 Trotter step) so the box structure is legible; every box carries the Twirl / InjectNoise annotations, and with ``include_checks`` the terminal xslow non-Markovian error check pattern is appended as in the production pipeline.""" import networkx as nx from qiskit.circuit import ClassicalRegister from qiskit_mitigation.postselection import XSlowGate from samplomatic.transpiler import generate_boxing_pass_manager toy, _, _ = generate_ed_ising(nx.cycle_graph(3), 1, zz_coeff, x_coeff) toy.add_register( ClassicalRegister(3, "data"), ClassicalRegister(3, "check") ) toy.barrier() toy.measure(range(3), range(3)) toy.measure(range(3, 6), range(3, 6)) toy_boxed = generate_boxing_pass_manager( enable_gates=True, enable_measures=True, inject_noise_targets="gates", inject_noise_strategy="individual_modification", inject_noise_site="after", twirling_strategy="active_circuit", measure_annotations="all", ).run(toy) if include_checks: toy_boxed.add_register( ClassicalRegister(3, "data_ps"), ClassicalRegister(3, "check_ps") ) toy_boxed.barrier() for qb in range(6): toy_boxed.append(XSlowGate(), [qb]) toy_boxed.measure(range(3), toy_boxed.cregs[2]) toy_boxed.measure(range(3, 6), toy_boxed.cregs[3]) return toy_boxed.draw("mpl", fold=-1, scale=0.6) # --- chip-level noise maps --------------------------------------------------------- BANDS = [1e-5, 2e-5, 3e-5, 4e-5, 6e-5, 1e-4, 2e-4, 3e-4, 4e-4, 6e-4, 1e-3] CMAP = plt.get_cmap("YlOrBr") NORM = BoundaryNorm(BANDS, CMAP.N, extend="both") def _color(rate): return ( "white" if rate < BANDS[0] else CMAP(NORM(min(rate, BANDS[-1] * 0.999))) ) def _layer_sparse(mit, weights): """Per-layer labelled terms from the saved run, box-local -> physical qubits.""" phys = np.sort(mit["layout"]) return [ [ (p, tuple(int(phys[q]) for q in qs if q >= 0), r) for p, qs, r in zip( mit[f"label_paulis_{i}"], mit[f"label_qubits_{i}"], w, strict=True, ) ] for i, w in enumerate(weights) ] def _aggregate(layers): """w1[qubit][P] and w2[(a,b)][PaPb]: rates summed over the 3 layers.""" w1, w2 = {}, {} for terms in layers: for p, qs, r in terms: if len(qs) == 1: w1.setdefault(qs[0], dict.fromkeys("XYZ", 0.0))[p] += r else: (a, pa), (b, pb) = sorted(zip(qs, p, strict=True)) w2.setdefault( (a, b), {x + y: 0.0 for x in "XYZ" for y in "XYZ"} )[pa + pb] += r return w1, w2 def draw_noise_map(mit, backend, reduced=False): """Chip map of the learned model: X/Y/Z wheel per qubit, 3x3 two-qubit Pauli grid per coupler, log-banded colors, dashed outlines for unused hardware. With ``reduced=True``, keeps only the error terms the checks cannot see: detectability depends on circuit position, so each layer's 0/1 site scales are averaged over its uses. """ from qiskit_ibm_runtime.visualization.embeddings import Embedding if reduced: scales = [ mit["site_scales"][mit["site_layer"] == i].mean(axis=0) for i in range(3) ] weights = [mit[f"rates_{i}"] * scales[i] for i in range(3)] title = f"Reduced noise model ($\\gamma$ = {mit['gammas'][1]:.1f})" else: weights = [mit[f"rates_{i}"] for i in range(3)] title = f"Full noise model ($\\gamma$ = {mit['gammas'][0]:.0f})" w1, w2 = _aggregate(_layer_sparse(mit, weights)) xy = np.array( [(c, -r) for r, c in Embedding.from_backend(backend).coordinates] ) fig, ax = plt.subplots(figsize=(13, 7)) for a, b in {tuple(sorted(e)) for e in backend.coupling_map.get_edges()}: if ( ( a, b, ) in w2 ): # 3x3 Pauli grid laid along the bond (columns: qubit a, rows: qubit b) d = xy[b] - xy[a] u = d / np.hypot(*d) v = np.array([-u[1], u[0]]) cl, cw = (np.hypot(*d) - 0.6) / 3, 0.17 for i, Pa in enumerate("XYZ"): for j, Pb in enumerate("XYZ"): ax.add_patch( Rectangle( xy[a] + u * (0.3 + i * cl) + v * ((j - 1.5) * cw), cl, cw, angle=np.degrees(np.arctan2(u[1], u[0])), facecolor=_color(w2[a, b][Pa + Pb]), edgecolor="black", lw=0.4, zorder=2, ) ) else: ax.plot( *zip(xy[a], xy[b], strict=True), ls="--", lw=0.7, color="black", alpha=0.5, zorder=1, ) for q, (xq, yq) in enumerate(xy): if q in w1: # three-sector wheel: X top, Y lower left, Z lower right for P, t0 in (("X", 30), ("Y", 150), ("Z", 270)): ax.add_patch( Wedge( (xq, yq), 0.3, t0, t0 + 120, facecolor=_color(w1[q][P]), edgecolor="black", lw=0.6, zorder=3, ) ) ax.annotate( str(q), (xq + 0.39, yq - 0.39), fontsize=9, color="gray", ha="left", va="top", zorder=4, ) # southeast, clear of the bond grids else: ax.add_patch( Circle( (xq, yq), 0.24, facecolor="none", edgecolor="black", ls="--", lw=0.7, alpha=0.5, zorder=3, ) ) ux = xy[sorted(w1)] ax.set_xlim(ux[:, 0].min() - 2.2, ux[:, 0].max() + 2.2) ax.set_ylim(ux[:, 1].min() - 1.6, ux[:, 1].max() + 1.6) ax.set_aspect("equal") ax.axis("off") ax.set_title(title, fontsize=15) cb = fig.colorbar( cm.ScalarMappable(norm=NORM, cmap=CMAP), ax=ax, fraction=0.035, pad=0.02, extend="both", ticks=BANDS, ) cb.set_label("coefficient (log bands; white < 1e-05)", fontsize=11) cb.ax.set_yticklabels( [f"{b:.0e}".replace("e-0", "e-") for b in BANDS], fontsize=10 ) _noise_map_legends(fig, ax) def _noise_map_legends(fig, ax): """Weight-1 wheel and weight-2 grid keys, in a reserved band left of the lattice.""" fig.subplots_adjust(left=0.17) axl = ax.inset_axes([-0.185, 0.70, 0.13, 0.24]) for P, t0 in (("X", 30), ("Y", 150), ("Z", 270)): axl.add_patch( Wedge( (0.5, 0.45), 0.38, t0, t0 + 120, facecolor="white", edgecolor="black", lw=0.8, ) ) axl.annotate( P, ( 0.5 + 0.2 * np.cos(np.radians(t0 + 60)), 0.45 + 0.2 * np.sin(np.radians(t0 + 60)), ), ha="center", va="center", fontsize=9, ) axl.set_title("weight-1", fontsize=10) axl.set_xlim(0, 1) axl.set_ylim(0, 1) axl.set_aspect("equal") axl.axis("off") axm = ax.inset_axes([-0.185, 0.32, 0.14, 0.30]) for i, Pa in enumerate("XYZ"): for j, Pb in enumerate("XYZ"): axm.add_patch( Rectangle( (i / 3, 1 - (j + 1) / 3), 1 / 3, 1 / 3, facecolor="white", edgecolor="black", lw=0.6, ) ) axm.annotate( Pa + Pb, ((i + 0.5) / 3, 1 - (j + 0.5) / 3), ha="center", va="center", fontsize=7.5, ) axm.annotate(Pa, ((i + 0.5) / 3, 1.08), ha="center", fontsize=8.5) axm.annotate( "XYZ"[i], (-0.13, 1 - (i + 0.5) / 3), ha="center", va="center", fontsize=8.5, ) axm.annotate("qubit a", (0.5, 1.27), ha="center", fontsize=9) axm.annotate( "qubit b", (-0.33, 0.5), rotation=90, va="center", fontsize=9 ) axm.set_xlim(-0.35, 1.05) axm.set_ylim(-0.05, 1.35) axm.set_aspect("equal") axm.axis("off") # --- run diagnostics --------------------------------------------------------------- def plot_trex(trex_rescale, tick_labels): _fig, axt = plt.subplots(figsize=(12, 3)) axt.stem(np.arange(len(trex_rescale)), (trex_rescale - 1) * 100) axt.set_xticks(np.arange(len(trex_rescale)), tick_labels) axt.set_xlabel("Observable") axt.set_ylabel("Readout correction (%)") axt.set_title("TREX rescale factors") plt.tight_layout() def plot_postselection(mit): """Accepted shots per PEC randomization against a single binomial at the mean acceptance rate: agreement means acceptance is independent of the sampled circuit instance, the condition under which pooling accepted shots across randomizations is a consistent estimator.""" _fig, ax = plt.subplots(figsize=(7.5, 3.8)) counts = mit["acc_counts_post"] K, p = 64, counts.mean() / 64 ks = np.arange(K + 1) pmf = np.array([comb(K, k) * p**k * (1 - p) ** (K - k) for k in ks]) ax.hist( counts, bins=np.arange(-0.5, K + 1.5), density=True, alpha=0.6, color="#da1e28", label="measured", ) ax.plot(ks, pmf, "k-", lw=1.5, label=f"Binomial(64, {p:.3f})") ax.set_xlim(-0.5, max(int(counts.max()) + 3, 20)) ax.set_xlabel("Accepted shots per randomization") ax.set_ylabel("Probability") ax.legend() ax.grid(alpha=0.4) plt.tight_layout() def plot_convergence(mit, obs_exact, n_data): """Running site-averaged estimate vs. randomizations for both PEC arms (the S5-consistent signed-ratio estimator, evaluated on growing prefixes of the sweep).""" def running(prefix): bits = np.squeeze( np.unpackbits(mit[f"data_{prefix}"], axis=-1)[..., :n_data] ^ mit[f"flips_{prefix}"] ) mask = np.squeeze(mit[f"mask_{prefix}"]) signs = 1 - 2 * (np.squeeze(mit[f"signs_{prefix}"]).sum(axis=-1) % 2) qv = (1 - 2 * bits.astype(int)) * mit["trex_rescale"] u = ( (signs[:, None, None] * mask[..., None] * qv) .sum(axis=1) .mean(axis=1) ) v = signs * mask.sum(axis=1) Rs = np.arange(500, len(u) + 1, 500) est, err = [], [] for R in Rs: e = u[:R].sum() / v[:R].sum() est.append(e) err.append( np.sqrt(((u[:R] - e * v[:R]) ** 2).sum()) / abs(v[:R].sum()) ) return Rs, np.array(est), np.array(err) _fig, ax = plt.subplots(figsize=(12, 5)) ideal_avg = float(np.mean(obs_exact)) ax.axhline(ideal_avg, color="black", label="ideal") ax.fill_between( [-400, 24000], ideal_avg - 0.025, ideal_avg + 0.025, color="grey", alpha=0.22, label=r"$\pm 0.025$", ) for prefix, label, color in ( ("van", "vanilla PEC", "#8a3ffc"), ("post", "PEC + error detection", "#da1e28"), ): Rs, est, err = running(prefix) ax.errorbar( Rs, est, yerr=err, marker="o", linestyle="", markerfacecolor="none", color=color, alpha=0.85, capsize=3, label=label, ) ax.set_xlim(-400, 24000) ax.set_ylim(ideal_avg - 0.08, ideal_avg + 0.08) ax.set_xlabel("# randomizations") ax.set_ylabel(r"Site-averaged $\langle X \rangle$") ax.legend(ncols=2) def plot_final( obs_exact, baseline, ed, pec, post, gammas, tick_labels, title ): """Per-site <X> for every method, with an rms-deviation inset. baseline/ed/pec/post are (values, errors) pairs; gammas is (gamma, gamma_post).""" x = np.arange(len(obs_exact)) _fig, ax = plt.subplots(figsize=(13, 5)) h_ideal = ax.errorbar( x, obs_exact, fmt="-", capsize=4, label="ideal", color="black" ) h_base = ax.errorbar( x, baseline[0], yerr=baseline[1], fmt=".--", capsize=4, label="baseline", color="#0f62fe", ) h_ed = ax.errorbar( x, ed[0], yerr=ed[1], fmt="^", capsize=4, label="error detection", color="#009d9a", alpha=0.8, ) h_pec = ax.errorbar( x, pec[0], yerr=pec[1], fmt="x", capsize=4, label=f"PEC ($\\gamma$={gammas[0]:.0f})", color="#8a3ffc", alpha=0.7, ) h_post = ax.errorbar( x, post[0], yerr=post[1], fmt="d", capsize=4, label=f"PEC + error detection ($\\gamma$={gammas[1]:.0f})", color="#da1e28", ) ax.set_xticks(x, tick_labels) ax.set_xlabel("Observable") ax.set_ylabel("Expectation value") # Set the y-axis range using the ideal, baseline, error detection, and PEC + error # detection curves, including error bars. Exclude PEC-only values when setting the # range so large fluctuations do not make the other curves difficult to distinguish. # PEC-only values may fall outside the visible range. Leave room above for the inset. series = [np.asarray(obs_exact)] + [ np.asarray(v) + s * np.asarray(e) for v, e in (baseline, ed, post) for s in (-1, 1) ] lo, hi = min(a.min() for a in series), max(a.max() for a in series) span = max(hi - lo, 0.1) ax.set_ylim(lo - 0.1 * span, hi + 1.05 * span) # legend ordered to match the curves' vertical positions in the chart ax.legend( handles=[h_ideal, h_pec, h_post, h_ed, h_base], ncols=5, loc="lower center", bbox_to_anchor=(0.5, 1.02), frameon=False, ) ax.set_title(title, pad=44) # inset: rows bottom-to-top so it reads top-to-bottom: PEC, PEC+ED, ED, baseline axi = ax.inset_axes([0.36, 0.68, 0.28, 0.26]) methods = [ ("baseline", baseline[0], "#0f62fe"), ("QED", ed[0], "#009d9a"), ("PEC+QED", post[0], "#da1e28"), ("PEC", pec[0], "#8a3ffc"), ] for k, (_nm, vals, color) in enumerate(methods): axi.barh( k, np.sqrt(np.mean((vals - np.array(obs_exact)) ** 2)), color=color, alpha=0.9, ) axi.set_yticks(range(4), [m[0] for m in methods], fontsize=10) axi.set_title("RMS deviation from ideal", fontsize=11) axi.tick_params(labelsize=10) axi.patch.set_alpha(1.0) axi.set_zorder(5)
Classically simulate for each site in the 22-qubit hex-Ising model
First, we use the Qiskit Statevector class to simulate the exact target values for our experiment. While the 22-qubit problem we're solving is tractable classically, the Qiskit statevector simulator will not scale to demos much larger than this one, and to scale up past 50 qubits or so, we would need to use inexact simulation techniques, such as Pauli propagation. This 49-qubit experiment allows us to investigate combining error detection with error mitigation at larger scales while maintaining access to the ideal expectation values.
import warnings
from qiskit.quantum_info import Pauli, Statevector
# Silence two harmless upstream warnings (a Samplomatic default-change notice and a
# numpy datetime timezone notice from the noise-learning circuit generator)
warnings.filterwarnings(
"ignore", message="The default of the 'inject_noise_site'"
"ignore", message="no explicit representation of timezones"
# Hexagonal lattice
data_graph = nx.convert_node_labels_to_integers(
nx.hexagonal_lattice_graph(2, 3)
# Number of Trotter steps and rotation angles
depth = 4
zz_coeff = -np.pi / 4
x_coeff = 3 * np.pi / 8
n_data = data_graph.order()
n_checks = data_graph.size()
n_qubits = n_data + n_checks
qc_data = QuantumCircuit(n_data)
qc_data.h(range(n_data))
for _ in range(depth):
for edge in data_graph.edges:
qc_data.rzz(zz_coeff, *edge)
qc_data.rx(x_coeff, range(n_data))
psi_exact = Statevector(qc_data)
# X on site i = qubit i
observables = ["I" * (n_data - 1 - i) + "X" + "I" * i for i in range(n_data)]
obs_exact = [psi_exact.expectation_value(Pauli(o)).real for o in observables]
plot_exact(
obs_exact,
x_labels(range(n_data), n_data),
f"Statevector simulation, {n_data} qubit hex-Ising, {depth} Trotter steps",
)Output:
This circuit simulates 4 Trotter steps of a 22-qubit transverse-field Ising Hamiltonian on a hexagonal lattice. The 22 data qubits are embedded in a 49-qubit heavy-hex subgraph of the Heron r3 QPU, ibm_boston. The 27 ancilla qubits are used for two purposes: mediating entanglement between the Ising qubits and detecting logical errors during circuit execution. The circuit's entangling layers are implemented such that the mediator qubits return to the ground state before their terminal measurements. One or more mediator qubits measuring indicates that the sample was corrupted by a logical error. Discarding these samples can improve the fidelity of the sampled distribution.
In the graph below, the green qubits represent the 22 Ising qubits, and the orange qubits represent the 27 mediator qubits.
backend_name = "ibm_boston"
def generate_ed_ising(graph, depth, zz_coeff, x_coeff):
"""Build the mediated error-detecting Ising circuit for data-qubit `graph`; returns (circuit, CZ layers, hardware graph)."""
hw_graph = nx.Graph()
for i, (a, b) in enumerate(graph.edges()):
hw_graph.add_edges_from(
[(a, i + graph.order()), (b, i + graph.order())]
coloring = nx.coloring.greedy_color(
nx.line_graph(hw_graph), strategy="DSATUR"
layers_coupling = [
[e for e, c in coloring.items() if c == i]
for i in set(coloring.values())
circuit = QuantumCircuit(hw_graph.order())
circuit.h(range(hw_graph.order()))
for angle, qubits in (
(zz_coeff, range(graph.order(), hw_graph.order())),
(x_coeff, range(graph.order())),
circuit.barrier()
for layer in layers_coupling:
for edge in layer:
circuit.cz(*edge)
circuit.barrier()
circuit.rx(angle, qubits)
circuit.barrier()
circuit.h(range(graph.order(), hw_graph.order()))
return circuit, layers_coupling, hw_graph
backend = service.backend(backend_name)
circuit, layers_coupling, hw_graph = generate_ed_ising(
data_graph, depth, zz_coeff, x_coeff
circ_meas = circuit.copy()
data_reg, check_reg = (
ClassicalRegister(n_data, "data"),
ClassicalRegister(n_checks, "check"),
circ_meas.add_register(data_reg, check_reg)
circ_meas.barrier()
circ_meas.measure(range(n_data), data_reg)
circ_meas.measure(range(n_data, n_qubits), check_reg)
# Physical qubits hosting the 22 Ising sites on ibm_boston, one heavy-hex row per lattice chain;
# the mediator for each edge is the physical qubit sitting between its two data qubits
data_layout = [
*[95, 93, 91, 89, 87],
*[115, 113, 111, 109, 107, 105],
*[135, 133, 131, 129, 127, 125],
*[155, 153, 151, 149, 147],
coupling_graph = nx.Graph(list(backend.coupling_map.get_edges()))
layout = data_layout + [
next(
iter(
nx.common_neighbors(
coupling_graph, data_layout[a], data_layout[b]
for a, b in data_graph.edges()
circ_trans = generate_preset_pass_manager(
backend=backend, optimization_level=1, initial_layout=layout
).run(circ_meas)
plot_layout(backend, layout, n_data)Output:
Specify the entangling layers in the circuit with samplomatic.
The Samplomatic generate_boxing_pass_manager pass groups the circuit's entangling layers into annotated boxes for Pauli twirling and PEC noise injection. The resulting template circuit and samplex (a parametric distribution over the template circuit specifying its twirls and noise injection) are used to define and execute all of the noise learning and sampling QPU experiments. The measurement boxes also carry a ChangeBasis annotation, so the rotations that measure the data qubits in the X basis are supplied to the samplex as an input at sampling time rather than being baked into the circuit.
Below, the same boxing pass is applied to a tiny version of the error-detecting Ising circuit so we can visualize the structure of a boxed circuit.
from samplomatic.builders import build
enable_gates=True,
).run(circ_trans)
template, samplex = build(boxed)
unique_instructions = find_unique_box_instructions(
boxed, normalize_annotations=None, undress_boxes=True
# Measure X on the data qubits and Z on the mediators
basis_key = next(
s.name
for s in samplex.inputs().get_specs()
if s.name.startswith("basis_changes.")
meas_basis = np.array(
[2 if q in set(layout[:n_data]) else 1 for q in sorted(layout)],
dtype=np.uint8,
draw_toy_circuit(generate_ed_ising, zz_coeff, x_coeff, include_checks=False)Output:
Next, we add non-Markovian error checks to the circuit in order to protect against noise that isn't modeled in our learning protocol. These checks work by implementing a long-pulse bit-flip and ensuring the qubit correctly moved from one classical state to another. If both qubits on an edge fail the check, the sample is discarded. Non-Markovian error checks can be used at the beginning or end of the circuit (or both); here we use them only at the end. We also place checks on unused "spectator" qubits adjacent to the circuit, providing more coverage against the noise these checks are designed to detect.
Remember, similar to symmetry checks, this is also a form of postselection, so we need to ensure we are accounting for the drop in postselection rate when combining these techniques. Concretely, if and , then you need approximately noisy samples to recover one logical sample.
from qiskit_mitigation.postselection import PostSelector
from qiskit_mitigation.postselection.passes import (
AddPostCircuitNonMarkovianErrorChecks,
AddSpectatorPostCircuitNonMarkovianErrorChecks,
add_checks = PassManager(
AddPostCircuitNonMarkovianErrorChecks(x_pulse_type="xslow"),
AddSpectatorPostCircuitNonMarkovianErrorChecks(
backend.coupling_map, x_pulse_type="xslow"
template_checked = add_checks.run(template)
selector = PostSelector.from_circuit(template_checked, backend.coupling_map)
draw_toy_circuit(generate_ed_ising, zz_coeff, x_coeff, include_checks=True)Output:
Learn the gate and readout noise for the 49-qubit checked-Ising circuit
To mitigate the noise, we must model how the noise is affecting our entangling gates. Here we learn a Pauli-Lindblad noise model for each of the circuit's three unique entangling layers using qiskit-noise-learning. Later, we will prune this noise model of error generators that are detectable by the symmetry checks and mitigate only the remaining noise channel with PEC. The map below shows the three learned layers on the QPU; each qubit is a wheel of its weight-1 X/Y/Z rates, and each coupler a 3×3 grid of the weight-2 Pauli rates on that pair. The value of implies a sampling overhead of .
The readout (TREX) corrections come directly from the SPAM paths of the noise-learning fit. The stem plot below the QPU noise map shows the per-observable TREX rescale factors.
from qiskit.quantum_info import PauliLindbladMap, QubitSparsePauli
from qiskit_ibm_runtime import Executor, Session
from qiskit_mitigation.trex import TREX
from qiskit_noise_learning.analysis import (
ComputeObservables,
CurveFitObservables,
FlipPostSelect,
LeastSquaresSolve,
from qiskit_noise_learning.circuit_generator import ExecutorCircuitGenerator
from qiskit_noise_learning.experiment_builder import (
BindFragmentDepths,
CompleteSequences,
EvenDepthVanillaPaths,
Experiment,
GenerateInstructionSequences,
IdentifyRelations,
MergeInstructionSequences,
SPAMPaths,
VanillaInstructionSequences,
from qiskit_noise_learning.gate_sets import QiskitGateSet
from qiskit_noise_learning.models import PauliLindbladModel
from qiskit_noise_learning.models.utils import split_pauli_lindblad_model
from samplomatic.utils import get_annotation
gate_set = QiskitGateSet(
target=backend.target,
qubit_subset=sorted(
boxed.find_bit(q).index
for i in unique_instructions
for q in i.qubits
ref_to_qubits = {}
for inst in unique_instructions:
if ann := get_annotation(inst.operation, InjectNoise):
gate_set.add_box_as_gate(inst, name=ann.ref)
ref_to_qubits[ann.ref] = sorted(
boxed.find_bit(q).index for q in inst.qubits
fidelity_model = PauliLindbladModel.k_local(
gate_set, gate_k={**{r: 2 for r in ref_to_qubits}, "M": 1, "P": 1}
experiment = (
EvenDepthVanillaPaths()
+ VanillaInstructionSequences()
+ IdentifyRelations()
+ SPAMPaths()
+ GenerateInstructionSequences()
+ MergeInstructionSequences()
+ CompleteSequences()
+ BindFragmentDepths([2, 4, 8, 12])
).run(Experiment(fidelity_model=fidelity_model, shots=384, randomizations=64))
circuit_generator = ExecutorCircuitGenerator(
gate_set, pass_manager=add_checks
program_learn, data_mapper = circuit_generator.generate(experiment)
session = Session(backend)
fit = circuit_generator.collect(
Executor(session).run(program_learn).result(), data_mapper
fit = (
FlipPostSelect()
+ ComputeObservables()
+ CurveFitObservables()
+ LeastSquaresSolve()
).run(fit)
"learning shots removed by checks:",
f"{float(fit.raw_data.datatree['0']['data_mask'].mean()):.4f}",
# TREX factors from the fit's SPAM paths: the fit only identifies the product of
# state-prep and measurement error, so hand TREX the composition of the two maps
spam = fidelity_model.to_pauli_lindblad_maps(
fit.model_data, include_spam=True
spam_map = spam["P"].compose(spam["M"])
z_terms = [
QubitSparsePauli(("Z", [layout[i]]), num_qubits=backend.num_qubits)
trex_rescale = np.array(
[TREX.calculate_trex_factor(spam_map, z) for z in z_terms]
# learned maps come back in backend qubit indexing; samplex wants box-local order
plm = split_pauli_lindblad_model(fit.model).model
noise_maps = {}
for ref, m in plm.to_pauli_lindblad_maps(fit.model_data).items():
box = ref_to_qubits[ref]
noise_maps[ref] = PauliLindbladMap.from_sparse_list(
(p, tuple(box.index(q) for q in qs), r)
for p, qs, r in m.to_sparse_list()
num_qubits=len(box),
# Full-PEC cost: each learned layer acts twice per Trotter step (compute + uncompute)
gamma = float(
np.exp(2 * depth * sum(2 * sum(m.rates) for m in noise_maps.values()))
# Collect the learned model in the form the figure helpers expect
mit = dict(
f"rates_{i}": np.asarray(m.rates)
for i, m in enumerate(noise_maps.values())
f"label_paulis_{i}": np.array([p for p, _, _ in m.to_sparse_list()])
f"label_qubits_{i}": np.array(
list(qs) + [-1] * (2 - len(qs))
for _, qs, _ in m.to_sparse_list()
layout=np.array(layout),
trex_rescale=trex_rescale,
gammas=np.array([gamma, np.nan]),
draw_noise_map(mit, backend)
plot_trex(mit["trex_rescale"], x_labels(layout, n_data))Output:
learning shots removed by checks: 0.2393
Prune the noise model of terms detectable by the symmetry checks
Each symmetry check is capable of detecting some subset of error generators in the noise model, which means that you don't need to mitigate those errors. Here we create a mask over the detectable noise generators using the create_postselected_noise_mask function from qiskit_mitigation. This mask will be used to prune the noise model of detectable terms before performing PEC. Performing PEC with respect to the pruned noise model can yield converged expectation values for a fraction of the sampling cost required to perform PEC on the full noise model, as illustrated in the noise model maps above.
The map below is drawn on the same color scale as the learned model above, keeping only the error generators the checks cannot detect. We see that a large number of error generators have been removed from the model, and the sampling overhead has dropped significantly. The sampling overhead to run PEC on the pruned noise model is , roughly a 16x reduction from the overhead required to mitigate the full noise channel.
from qiskit_mitigation.noise import create_postselected_noise_mask
SHOTS_PER_RAND = 64 # shots per PEC randomization
N_RAND = 23_054 # PEC randomizations per experiment
MAX_PAIR_RATE = 0.02 # Max value of any coupler's summed two-qubit error rate
# The detectors are virtual Pauli-Z's representing the measurements on the mediator qubits
# We can find the set of detectable noise generators in the model for each detector by conjugating
# it backward through the circuit and calculating what generators it anti-commutes with.
detectors = [
Pauli("I" * (boxed.num_qubits - 1 - q) + "Z" + "I" * q)
for q in layout[n_data:]
# Detectable generators are handled by postselection; prune them from the model for PEC
local_scales, gamma2_post = create_postselected_noise_mask(
boxed, noise_maps, detectors
gamma_post = gamma2_post**0.5
print(f"gamma PEC {gamma:.2f} | gamma QED+PEC {gamma_post:.2f}")
# Kill the job if any coupler's summed rate exceeds MAX_PAIR_RATE
pair_lam = {}
for m in noise_maps.values():
for _, qs, r in m.to_sparse_list():
if len(qs) == 2:
pair_lam[tuple(sorted(qs))] = (
pair_lam.get(tuple(sorted(qs)), 0.0) + r
assert (
max(pair_lam.values()) < MAX_PAIR_RATE
), f"kill: degraded coupler {max(pair_lam, key=pair_lam.get)}"
# Detectability depends on circuit position, so record each site's 0/1 scales by layer
site_ref = {
a.modifier_ref: a.ref
for inst in boxed.data
and (a := get_annotation(inst.operation, InjectNoise))
and a.ref
sites = sorted(local_scales, key=lambda s: int(s[1:]))
mit["site_scales"] = np.stack([local_scales[s] for s in sites])
mit["site_layer"] = np.array(
[list(noise_maps).index(site_ref[s]) for s in sites]
mit["gammas"] = np.array([gamma, gamma_post])
draw_noise_map(mit, backend, reduced=True)Output:
gamma PEC 10.08 | gamma QED+PEC 2.52
Here we sample the 49-qubit error-detecting Ising circuit. We enable Pauli twirling and non-Markovian error checks, but we do not perform PEC sampling. We will use these samples to calculate baseline expectation values as well as error-detection-only expectation values.
# Baseline = the ED+PEC template itself at noise scale 0, i.e. twirling only
program_tw = QuantumProgram(shots=100)
program_tw.append_samplex_item(
template_checked,
samplex=samplex,
shape=(1000, 1),
samplex_arguments={
"pauli_lindblad_maps": dict(noise_maps),
basis_key: meas_basis,
**{f"noise_scales.{k}": 0.0 for k in local_scales},
job_tw = Executor(session).run(program_tw)Sample the error-detecting circuit with PEC
Now we sample again and include PEC randomizations to mitigate the noise the symmetry checks can't detect. These samples will be used to calculate expectation values by using error detection in combination with PEC. Below we plot the accepted shots per PEC randomization against a binomial at the mean acceptance rate. We see that acceptance is uncorrelated with the sampled circuit instance because QED+PEC injects only undetectable Paulis, which commute with the measurements of every mediator qubit.
def launch(session, template, samplex, samplex_args, n_rand, shots_per_rand):
"""Sample `n_rand` randomizations of `template` on `session` in <=100k-randomization jobs; returns the jobs."""
jobs = []
for start in range(0, n_rand, 100_000):
program = QuantumProgram(shots=shots_per_rand)
program.append_samplex_item(
template,
samplex=samplex,
samplex_arguments=samplex_args,
shape=(min(100_000, n_rand - start), 1),
jobs.append(Executor(session).run(program))
return jobs
# Reduced PEC
args_post = {
**{f"noise_scales.{k}": -1.0 for k in local_scales},
**{f"local_scales.{k}": v for k, v in local_scales.items()},
# PEC on the full noise model
args_van = {
# Run sampling jobs
jobs = launch(
session, template_checked, samplex, args_post, N_RAND, SHOTS_PER_RAND
jobs_van = launch(
session, template_checked, samplex, args_van, N_RAND, SHOTS_PER_RAND
outs = [j.result()[0] for j in jobs]
outs_van = [j.result()[0] for j in jobs_van]
(out_tw,) = job_tw.result()
session.close()Collect the samples and verify that PEC randomizations commute with the measurements on the mediator qubits and do not affect the postselection statistics.
def bitflip_mask(out, selector):
"""Per-shot True/False for job result `out`: shot passes `selector`'s non-Markovian error checks."""
regs = {
k: np.asarray(out[k])
for k in out
if not k.startswith(("measurement_flips", "pauli_signs"))
return selector.compute_mask(regs, "edge", mode="post")
def symmetry_mask(out):
"""Per-shot True/False for job result `out`: every twirl-corrected symmetry check reads 0."""
return ~(
np.asarray(out["check"]) ^ np.asarray(out["measurement_flips.check"])
).any(axis=-1)
def keep_mask(out, selector):
"""Per-shot True/False for job result `out`: shot passes both check types."""
return symmetry_mask(out) & bitflip_mask(out, selector)
def fracs(out_list, selector):
"""Fractions of shots across the job results in `out_list` passing [no, non-Markovian error, symmetry, both] checks."""
bf = np.concatenate([bitflip_mask(o, selector) for o in out_list])
sy = np.concatenate([symmetry_mask(o) for o in out_list])
return [1.0, bf.mean(), sy.mean(), (bf & sy).mean()]
mask_post = np.concatenate([keep_mask(o, selector) for o in outs])
# Collect the sampled data alongside the learned model, in the form the figure helpers expect
mit.update(
ps_fracs=np.array(
fracs([out_tw], selector),
fracs(outs_van, selector),
fracs(outs, selector),
acc_counts_post=np.squeeze(mask_post).sum(axis=-1),
data_tw=np.asarray(out_tw["data"]),
flips_tw=np.asarray(out_tw["measurement_flips.data"]),
mask_tw=keep_mask(out_tw, selector),
data_post=np.packbits(
np.concatenate([np.asarray(o["data"]) for o in outs]), axis=-1
flips_post=np.concatenate(
[np.asarray(o["measurement_flips.data"]) for o in outs]
signs_post=np.concatenate([np.asarray(o["pauli_signs"]) for o in outs]),
mask_post=mask_post,
data_van=np.packbits(
np.concatenate([np.asarray(o["data"]) for o in outs_van]), axis=-1
flips_van=np.concatenate(
[np.asarray(o["measurement_flips.data"]) for o in outs_van]
signs_van=np.concatenate(
[np.asarray(o["pauli_signs"]) for o in outs_van]
mask_van=np.concatenate([bitflip_mask(o, selector) for o in outs_van]),
# Plot the PEC bias check
plot_postselection(mit)Output:
Finally, we calculate all of the expectation values with the executor_expectation_values helper function from qiskit-mitigation, which applies the measurement flips, the postselection masks, the TREX rescale factors, and the quasi-probability signs for us.
Top chart: We see that both PEC variants converge, but QED+PEC reaches the band with fewer randomizations and tighter error bars. The residual bias in the QED+PEC calculation is below 0.01 and can be attributed to some combination of noise model disagreement, qubit drift over time, and effects from unmodeled noise sources.
Bottom chart: The running estimate of the site-averaged as randomizations accumulate using identical shots per randomization for both PEC variants. PEC + error detection settles into the band within a few thousand randomizations; PEC-only, paying the full sampling overhead, requires many more randomizations to converge.
from qiskit_mitigation.utils import executor_expectation_values
gamma, gamma_post = mit["gammas"]
basis_map = {Pauli("X" * n_data): [SparsePauliOp(o) for o in observables]}
rescale = dict(zip(observables, mit["trex_rescale"], strict=True))
def evs(bits, basis_map, **kwargs):
"""Per-site (means, standard errors) from boolean shot data `bits` of shape (rands, 1, shots, n_data)."""
out = executor_expectation_values(
bits, basis_map, None, avg_axis=(0, 1), **kwargs
return np.array([m for m, _ in out]).ravel(), np.sqrt(
[v for _, v in out]
).ravel()
def unpack(mit, prefix, n_data):
"""Restore `mit[f"data_{prefix}"]` from packed bytes to booleans of shape (rands, 1, shots, n_data)."""
return np.unpackbits(mit[f"data_{prefix}"], axis=-1)[..., :n_data].astype(
bool
unmit_tw, unmit_tw_err = evs(
mit["data_tw"], basis_map, measurement_flips=mit["flips_tw"]
ed_tw, ed_tw_err = evs(
mit["data_tw"],
basis_map,
measurement_flips=mit["flips_tw"],
postselect_mask=mit["mask_tw"],
rescale_factors=rescale,
post, post_err = evs(
unpack(mit, "post", n_data),
basis_map,
measurement_flips=mit["flips_post"],
pauli_signs=mit["signs_post"],
postselect_mask=mit["mask_post"],
pec, pec_err = evs(
unpack(mit, "van", n_data),
basis_map,
measurement_flips=mit["flips_van"],
pauli_signs=mit["signs_van"],
postselect_mask=mit["mask_van"],
# effective ED+PEC overhead measured from the data: accepted shots per signed accepted shot
signs_post = 1 - 2 * (np.squeeze(mit["signs_post"]).sum(axis=-1) % 2)
gamma_eff = (
mit["mask_post"].sum()
/ (signs_post * np.squeeze(mit["mask_post"]).sum(axis=-1)).sum()
f"gamma PEC {gamma:.2f} | gamma QED+PEC {gamma_post:.2f} (model) / {gamma_eff:.2f} (data) | "
f"QED survival {mit['mask_tw'].mean():.3f} | QED+PEC survival {mit['mask_post'].mean():.3f} | "
f"mean QED+PEC err {post_err.mean():.4f}"
plot_final(
obs_exact,
(unmit_tw, unmit_tw_err),
(ed_tw, ed_tw_err),
(pec, pec_err),
(post, post_err),
(gamma, gamma_post),
x_labels(layout, n_data),
)Output:
gamma PEC 10.08 | gamma QED+PEC 2.52 (model) / 2.51 (data) | QED survival 0.304 | QED+PEC survival 0.305 | mean QED+PEC err 0.0037
plot_convergence(mit, obs_exact, n_data)Output:
