bit_flip_checks_passes
qiskit_addon_utils.noise_management.bit_flip_checks.passes
A submodule with transpilation passes for circuit bit-flip checks.
Column 1 | Column 2 |
AddPostCircuitBitFlipChecks | Add bit-flip checks at the end of the circuit on active qubits terminated by a measurement. |
AddPreCircuitBitFlipChecks | Add bit-flip checks at the beginning of the circuit on active qubits terminated by a measurement. |
AddSpectatorPostCircuitBitFlipChecks | Add bit-flip checks at the end of the circuit on qubits adjacent to active qubits. |
AddSpectatorPreCircuitBitFlipChecks | Add bit-flip checks at the beginning of the circuit on qubits adjacent to active qubits. |
XPulseType | The type of X-pulse to apply for a bit-flip check measurement. |
Was this page helpful?
