NoiseLearnerV3
class NoiseLearnerV3(mode=None, options=None)
GitHub
Bases: object
The noise learner allows characterizing the noise processes affecting target instructions, based on the Pauli-Lindblad noise model described in [1]. The instructions provided to the run() method must contain a twirled-annotated BoxOp containing ISA operations. The result of a noise learner job contains a list of NoiseLearnerV3Result objects, one for each given instruction.
Parameters
References
  1. E. van den Berg, Z. Minev, A. Kandala, K. Temme, Probabilistic error cancellation with sparse Pauli–Lindblad models on noisy quantum processors, Nature Physics volume 19, pages 1116–1121 (2023). arXiv:2201.09866 [quant-ph]
Attributes
mode
Return the execution mode used by this primitive.
Returns
Mode used by this primitive, or None if an execution mode is not used.
options
Type: NoiseLearnerV3Options
Methods
backend
backend()
GitHub
Return type
BackendV2
run
run(instructions, dry_run=False)
GitHub
Parameters
  • instructions (Iterable[CircuitInstruction]) – The instructions to learn the noise of.
  • dry_run (bool) – If True, performs a dry run without executing the job on a QPU. This mode can be used to validate the job, estimate usage consumption, and retrieve circuit timing metadata. Returned results preserve the expected schema but contain randomized mock data rather than actual or simulated measurement results. Unlike the fake backends, the processing of this dry run happens on the server-side, so the job may not finish immediately and access to this feature may be restricted.
Returns
The submitted job.
Return type
RuntimeJobV2 | LocalRuntimeJob
Was this page helpful?
