NoiseLearnerV3
class NoiseLearnerV3(mode=None, options=None)
GitHub
Bases: object
The noise learner allows characterizing the noise processes affecting target instructions, based on the Pauli-Lindblad noise model described in [1]. The instructions provided to the run() method must contain a twirled-annotated BoxOp containing ISA operations. The result of a noise learner job contains a list of NoiseLearnerV3Result objects, one for each given instruction.
Parameters
References
  1. E. van den Berg, Z. Minev, A. Kandala, K. Temme, Probabilistic error cancellation with sparse Pauli–Lindblad models on noisy quantum processors, Nature Physics volume 19, pages 1116–1121 (2023). arXiv:2201.09866 [quant-ph]
Attributes
options
Type: NoiseLearnerV3Options
Methods
backend
backend()
GitHub
Return type
BackendV2
run
run(instructions)
GitHub
Two protocols are supported:
  • Lindblad: for boxed instructions which content can be cast to
    Clifford and contain a single layer of (up to) two qubit gates.
  • TREX: for boxed instructions which content can contain exactly one measurement per qubit.
Note
To minimize the number of noise learning experiments, call find_unique_box_instructions() before running the noise learning job.
Parameters
instructions (Iterable[CircuitInstruction]) – The instructions to learn the noise of.
Returns
The submitted job.
Raises
IBMInputValueError – If the instructions cannot be used with the noise learner, such as: * If an instruction contains a box without twirl annotation. * If an instruction contains unphysical qubits, i.e., qubits that do not belong to the “physical” register QuantumRegister(backend.num_qubits, 'q') for the backend in use. * If an instruction contains a box with non-ISA gates. * If an instruction cannot be learned by any of the supported learning protocols.
Return type
RuntimeJobV2
Was this page helpful?
