Simulate neutron scattering in quantum materials with quantum circuits
Usage estimate: 13 minutes on a Heron r2 processor (NOTE: This is an estimate only. Your runtime might vary.)
Which tutorial should I use?
Use this tutorial to learn the implementation step by step, with classical computation running locally on your laptop and hardware execution on an IBM Quantum® QPU. The large-scale example requires substantial memory, and approximate quantum compiling (AQC) can take several hours on typical laptop resources. To offload compression to Qiskit Serverless compute and memory resources, use the companion Serverless tutorial.
Learning outcomes
  • How inelastic neutron scattering (INS) spectra connect to dynamical structure factors (DSFs) of quantum spin models.
  • How to prepare a ground state, apply a local perturbation, and perform Trotter time evolution on a quantum circuit.
  • How to use approximate quantum compiling (AQC) with qiskit-addon-aqc-tensor to compress deep Trotter circuits for hardware execution.
  • How to extract the retarded Green's function (RGF) from qubit expectation values and Fourier-transform it into a DSF.
Background
In this tutorial, we reproduce the results of Lee et al., arXiv:2603.15608.
Neutron scattering helps researchers characterize materials relevant to sustainability, including battery electrodes. This tutorial explores how quantum circuits can simulate magnetic excitations and connect theoretical models to scattering measurements. Its quantum-magnet example develops methods for studying material behavior, contributing to the broader research toolkit for materials discovery.
Inelastic neutron scattering and the dynamical structure factor
Inelastic neutron scattering (INS) is one of the most powerful experimental probes of magnetic excitations in quantum materials. When a beam of thermal or cold neutrons impinges on a crystal, individual neutrons exchange both momentum q\mathbf{q} and energy ω\omega with the magnetic subsystem. The measured scattering intensity is proportional to the dynamical structure factor (DSF),
Sαβ(q,ω)=∑je−iq j∫−∞∞dt  eiωt ⟨S0α(0) Sjβ(t)⟩,S^{\alpha\beta}(q,\omega) = \sum_{j} e^{-iq\,j}\int_{-\infty}^{\infty} dt\; e^{i\omega t}\, \langle S_0^{\alpha}(0)\, S_j^{\beta}(t)\rangle,
which encodes the full space-time correlations of the spin degrees of freedom.
KCuF3_3: a canonical Luttinger-liquid magnet
Potassium copper fluoride (KCuF3_3) is a quasi-one-dimensional antiferromagnet in which chains of spin-12\frac{1}{2} Cu2+^{2+} ions interact via a nearest-neighbor Heisenberg exchange JJ, while the interchain coupling is only ∼2.7%\sim 2.7\% of JJ. At T=6  KT = 6\;\mathrm{K} where INS data are available, the spectrum is dominated by fractionalized spinon excitations characteristic of a Tomonaga-Luttinger liquid. Because the intrachain dynamics are well described by the one-dimensional spin-12\frac{1}{2} XXZ Hamiltonian at the isotropic point (ϵ=1\epsilon = 1),
H=J∑i[SiZSi+1Z+ϵ(SiXSi+1X+SiYSi+1Y)],H = J\sum_{i}\left[S_i^Z S_{i+1}^Z + \epsilon\left(S_i^X S_{i+1}^X + S_i^Y S_{i+1}^Y\right)\right],
KCuF3_3 serves as an ideal benchmark for quantum simulation: the Hamiltonian is simple enough to implement on a quantum processor, yet the ground state is strongly entangled and the excitation spectrum features a broad two-spinon continuum.
Note: this tutorial sets J=1J = 1 as the energy unit and adopts the normalization H=J∑i[…]H = J\sum_i[\ldots], which corresponds to the local Hamiltonian Hloc=J(SXSX+SYSY+SZSZ)H_\mathrm{loc} = J(S^X S^X + S^Y S^Y + S^Z S^Z) used in the paper's circuit implementation (Fig. S3 of the supplementary). The paper's full Hamiltonian (Eq. 3) carries an additional overall factor of 2, so the paper's JJ is twice the JJ used here.
What we simulate and measure
The physical quantity we compute is the retarded Green's function (RGF), defined as the time-dependent spin-spin correlation function
Gα,βR(j,jc,t)=−i2 ⟨ψGS∣ Sjα(t) Sjcβ(0)−Sjcβ(0) Sjα(t) ∣ψGS⟩,G^R_{\alpha,\beta}(j, j_c, t) = -\frac{i}{2}\,\langle\psi_{\mathrm{GS}}|\,S_j^\alpha(t)\,S_{j_c}^\beta(0) - S_{j_c}^\beta(0)\,S_j^\alpha(t)\,|\psi_{\mathrm{GS}}\rangle,
where jcj_c is a reference site (the chain center) and Sjα(t)=eiHtSjαe−iHtS_j^\alpha(t) = e^{iHt}S_j^\alpha e^{-iHt} is the Heisenberg-picture spin operator. In this tutorial we focus on the zzzz component (α=β=z\alpha = \beta = z). On a quantum computer the RGF is accessed by preparing the ground state, applying a local perturbation at jcj_c, time-evolving the perturbed state, and measuring the single-qubit expectation value ⟨σjz⟩\langle\sigma_j^z\rangle at every site jj for each time step. The key insight is that each ⟨σjz⟩\langle\sigma_j^z\rangle gives the difference from the ground-state magnetization; because the isotropic Heisenberg antiferromagnet has zero net per-site magnetization (⟨σjz⟩GS=0\langle\sigma_j^z\rangle_\mathrm{GS} = 0), the raw measured value directly yields GR(j,jc,t)G^R(j, j_c, t) without any explicit subtraction.
By collecting GR(j,jc,t)G^R(j, j_c, t) over all sites and time steps, we assemble a two-dimensional dataset that is then Fourier-transformed in both space and time to produce the dynamical structure factor S(q,ω)S(q,\omega). The DSF is the quantity directly measured in an INS experiment: it tells us what magnetic excitations exist at each momentum qq and energy ω\omega. For the isotropic Heisenberg chain the exact excitation spectrum is a two-spinon continuum, a broad band of scattering intensity whose shape serves as a stringent end-to-end benchmark for the quantum simulation: it validates the ground-state preparation, perturbation, Trotter time evolution, and measurement protocol all at once.
Quantum-simulation workflow
The workflow mirrors the physics of an INS event. We (1) prepare the many-body ground state ∣ψGS⟩|\psi_{\mathrm{GS}}\rangle on nn qubits, (2) apply a local spin-flip perturbation Ujc=12(I−iσjcz)U_{j_c} = \frac{1}{\sqrt{2}}(I - i\sigma^z_{j_c}) at the chain center to mimic the neutron's spin transfer, (3) evolve under HH for discrete time steps using second-order Trotterization, and (4) measure ⟨σiz⟩\langle\sigma_i^z\rangle on every qubit at each step to obtain the RGF. A two-dimensional discrete Fourier transform then yields the DSF S(q,ω)S(q,\omega).
The observable we measure at every time step is σiz\sigma_i^z on each qubit ii. In Qiskit this is represented as a list of SparsePauliOp operators: one single-qubit ZZ embedded in the nn-qubit identity string for each site. These observables are constructed once per problem instance during the problem-mapping step (Step 1) and reused for every circuit at that scale.
Approximate quantum compiling (AQC)
Deep Trotter circuits can be compressed with approximate quantum compiling (AQC), which replaces the first several Trotter layers with a shorter parameterized ansatz whose parameters are classically optimized to maximize the MPS-level fidelity with the original deep circuit. The remaining Trotter steps are appended exactly, producing a "mixed" AQC + Trotter circuit with substantially fewer two-qubit gates.
MPS simulation
For a one-dimensional system, matrix-product-state (MPS) methods can efficiently simulate both ground-state preparation (with the density matrix renormalization group, or DMRG) and circuit-level time evolution. By controlling the bond dimension χ\chi, we trade off accuracy against computational cost. In this tutorial we use MPS simulation within qiskit-addon-aqc-tensor to compute high-fidelity AQC ansätze that compress the deep Trotter circuits for hardware execution.
Requirements
  • Qiskit SDK with visualization support
  • Qiskit Runtime (pip install qiskit-ibm-runtime)
  • qiskit-addon-aqc-tensor with quimb and JAX extras (pip install 'qiskit-addon-aqc-tensor[quimb-jax]')
Setup
import timeit
import warnings
from collections.abc import Iterator, Sequence
from functools import partial
import quimb.tensor as qtn
import scipy.optimize
from numpy.typing import NDArray
from qiskit.circuit import CircuitInstruction, ParameterVector, Qubit
from qiskit.circuit.library import PauliEvolutionGate
from qiskit.primitives import StatevectorEstimator
from qiskit_addon_aqc_tensor import generate_ansatz_from_circuit
from qiskit_addon_aqc_tensor.objective import MaximizeStateFidelity
from qiskit_addon_aqc_tensor.simulation import tensornetwork_from_circuit
from qiskit_addon_aqc_tensor.simulation.quimb import QuimbSimulator
from qiskit_quimb import quimb_circuit
from scipy.sparse import SparseEfficiencyWarning
# scipy.sparse.linalg.expm (reached via PauliEvolutionGate.to_matrix) prefers
# CSC and warns when handed the CSR matrix from SparsePauliOp.to_matrix; the
# result is unaffected, so silence the cosmetic warning.
warnings.filterwarnings("ignore", category=SparseEfficiencyWarning)
def xxz_hamiltonian_mpo(
    n_qubits: int, interaction: float = 1.0, anisotropy: float = 1.0
) -> qtn.MatrixProductOperator:
    """1D XXZ Hamiltonian as a quimb MPO.
    Builds the Hamiltonian using ``qtn.SpinHam1D``.
    Args:
        n_qubits: Number of sites.
        interaction: Overall interaction strength (J in the paper).
        anisotropy: XY/Z anisotropy (ε in the paper). ``ε = 1`` is the
            isotropic Heisenberg point; ``ε = 0`` is the Ising limit.
    Returns:
        The Hamiltonian as a matrix product operator.
    builder = qtn.SpinHam1D(S=1 / 2)
    builder += interaction * anisotropy * 0.5, "+", "-"
    builder += interaction * anisotropy * 0.5, "-", "+"
    builder += interaction, "Z", "Z"
    return builder.build_mpo(L=n_qubits)
def build_ground_state_ansatz(n_qubits: int, n_layers: int) -> QuantumCircuit:
    """Hamiltonian variational ansatz (HVA) circuit for ground-state preparation.
    Starts from a product of singlet pairs and applies alternating
    odd/even layers of parameterized XXZ pair-evolution gates.
    The returned circuit is parameterized: it carries a ``ParameterVector``
    named ``"theta"`` of length ``2 * n_layers`` whose values must be
    assigned (e.g. via ``circuit.assign_parameters``) before simulation.
    Element ``2 * r`` is the odd-layer angle and element ``2 * r + 1`` is the
    even-layer angle of layer ``r``.
    Args:
        n_qubits: Number of qubits (must be even).
        n_layers: Number of HVA layers.
    Returns:
        The parameterized HVA preparation circuit.
    theta = ParameterVector("theta", 2 * n_layers)
    circuit = QuantumCircuit(n_qubits)
    # Initial singlet product state
    for i in range(n_qubits // 2):
        circuit.x(2 * i)
        circuit.x(2 * i + 1)
        circuit.h(2 * i + 1)
        circuit.cx(2 * i + 1, 2 * i)
    # Variational layers: each pair gate is exp(-i theta (XX+YY+ZZ)/2)
    pair_ham = SparsePauliOp(
        ["XX", "YY", "ZZ"], coeffs=[0.5, 0.5, 0.5]
    )  # H_pair (HVA form)
    for r in range(n_layers):
        for i in range(1, (n_qubits + 1) // 2):  # odd layer
            circuit.append(
                PauliEvolutionGate(pair_ham, time=theta[2 * r]),
                [2 * i - 1, 2 * i],
        for i in range(n_qubits // 2):  # even layer
            circuit.append(
                PauliEvolutionGate(pair_ham, time=theta[2 * r + 1]),
                [2 * i, 2 * i + 1],
    return circuit
def optimize_ground_state_ansatz(
    ansatz: QuantumCircuit,
    x0: NDArray[np.floating],
    target_mps: qtn.MatrixProductState,
    max_bond: int | None = None,
    cutoff: float = 1e-10,
    method: str = "COBYQA",
    options: dict | None = None,
) -> scipy.optimize.OptimizeResult:
    """Optimize HVA parameters by maximizing fidelity with a target MPS.
    The HVA circuit is simulated as a matrix product state with the given
    bond-dimension truncation, and the parameters are optimized to maximize
    the state fidelity ``|<psi_HVA | target_mps>|**2`` with the DMRG ground
    state. Both states are normalized, so the minimized objective is the
    infidelity ``1 - |<psi_HVA | target_mps>|**2``.
    Args:
        ansatz: Parameterized HVA circuit from ``build_ground_state_ansatz``.
            The length of ``x0`` must equal ``ansatz.num_parameters``.
        x0: Initial parameters.
        target_mps: Target MPS (DMRG ground state) to maximize fidelity with.
        max_bond: Maximum MPS bond dimension during gate application.
        cutoff: Singular-value cutoff during gate application.
        method: ``scipy.optimize.minimize`` method.
        options: Options dict forwarded to ``scipy.optimize.minimize``.
    Returns:
        The Scipy OptimizeResult.
    def infidelity(params: NDArray[np.floating]) -> float:
        circuit = ansatz.assign_parameters(params)
        circuit_mps = quimb_circuit(
            circuit.decompose(["PauliEvolution"]),
            quimb_circuit_class=qtn.CircuitMPS,
            max_bond=max_bond,
            cutoff=cutoff,
        return 1 - abs(circuit_mps.psi.H @ target_mps) ** 2
    return scipy.optimize.minimize(
        infidelity, np.asarray(x0), method=method, options=options
def trotter_evolution(
    qubits: Sequence[Qubit],
    interaction: float,
    anisotropy: float,
    time_step: float,
    n_steps: int,
) -> Iterator[CircuitInstruction]:
    """Second-order Trotter steps of the XXZ pair Hamiltonian.
    While the paper used a hand-optimized circuit for the Trotter steps, we use
    PauliEvolutionGate here for simplicity and generality. The final two-qubit gate
    count and gate depth are equivalent when transpiled with ``optimization_level=3``.
    Args:
        qubits: Qubits to act on (length ``n_qubits``).
        time_step: Per-step Trotter time.
        n_steps: Number of Trotter steps.
    Yields:
        ``CircuitInstruction``s implementing the Trotter steps.
    if n_steps == 0:
        return
    n_qubits = len(qubits)
        ["XX", "YY", "ZZ"],
        coeffs=[
            0.25 * interaction * anisotropy,
            0.25 * interaction,
    half_evo = PauliEvolutionGate(pair_ham, time=time_step / 2)
    full_evo = PauliEvolutionGate(pair_ham, time=time_step)
    for i in range(n_qubits // 2):  # half even layer
        yield CircuitInstruction(half_evo, (qubits[2 * i], qubits[2 * i + 1]))
    for i in range(n_qubits // 2 - 1):  # full odd layer
            full_evo, (qubits[2 * i + 1], qubits[2 * i + 2])
    for _ in range(n_steps - 1):  # interior steps
                full_evo, (qubits[2 * i], qubits[2 * i + 1])
def get_dsf(
    n_qubits: int,
    rgf_mat: NDArray[np.floating],
    time_step: float,
    n_steps: int,
    n_points_momentum: int,
    n_points_frequency: int,
) -> NDArray[np.floating]:
    """Compute the dynamical structure factor from the retarded Green's function.
    Uses the center-site approximation and a discrete Fourier transform.
    The result is symmetrized about the momentum axis and clipped to
    non-negative values, ready for plotting.
    Args:
        n_qubits: Number of qubits (sites).
        rgf_mat: RGF matrix of shape ``(n_steps, n_qubits)``.
        time_step: Trotter time-step size.
        n_steps: Number of time steps.
        n_points_momentum: Number of momentum points.
        n_points_frequency: Number of frequency points.
    Returns:
        DSF array of shape ``(n_points_frequency, n_points_momentum)``,
        symmetrized about the momentum axis and clipped to non-negative values.
    max_frequency = np.pi / time_step
    momentum_range = np.linspace(0, 2 * np.pi, n_points_momentum)
    frequency_range = np.linspace(0, max_frequency, n_points_frequency)
    result = np.zeros((frequency_range.shape[0], momentum_range.shape[0]))
    center = n_qubits // 2 - 1
    for iw, w in enumerate(frequency_range):
        exponent = np.exp(1j * w * time_step * np.arange(1, n_steps + 1))
        # S = sigma/2, so two spin operators contribute a factor of (1/2)(1/2) = 1/4.
        rgf_omega = (
            np.dot(rgf_mat.T, exponent) * time_step / 4
        )  # S(omega): time Fourier slice of the Green's function
        for iq, q in enumerate(momentum_range):
            momentum_phases = np.exp(
                -1j * q * np.arange(-center, center + 2, 1)
            result[iw, iq] = np.imag(np.dot(rgf_omega, momentum_phases))
    result = -(result + result[:, ::-1]) / 2
    result = np.clip(result, a_min=0, a_max=None)
    return result
def plot_dsf(
    dsf: NDArray[np.floating],
    time_step: float,
    title: str | None = None,
) -> None:
    """Heat-map of the dynamical structure factor.
    Args:
        dsf: DSF array of shape ``(n_points_frequency, n_points_momentum)``.
        title: Optional plot title.
    x, y = np.meshgrid(momentum_range, frequency_range)
    c = ax.pcolormesh(x, y, dsf / np.max(dsf), cmap="viridis", shading="auto")
    fig.colorbar(c, ax=ax, label="Normalized intensity")
    ax.set_ylim(0, 3.6)
    ax.set_xlim(0, 2 * np.pi)
    ax.set_xlabel(r"$q$", fontsize=16)
    ax.set_ylabel(r"$\tilde{\omega} = \omega / J$", fontsize=16)
    ax.set_xticks([0, np.pi / 2, np.pi, 3 * np.pi / 2, 2 * np.pi])
    ax.set_xticklabels(["0", r"$\pi/2$", r"$\pi$", r"$3\pi/2$", r"$2\pi$"])
    if title:
        ax.set_title(title, fontsize=14)
    plt.tight_layout()
def plot_rgf(
    n_qubits: int,
    time_step: float,
    n_steps: int,
) -> None:
    """Heat-map of the retarded Green's function in real space and time.
    Args:
    fig, ax = plt.subplots(figsize=(8, 6))
    qubit_axis = np.arange(n_qubits)
    t_axis = np.arange(1, n_steps + 1) * time_step
    x, y = np.meshgrid(qubit_axis, t_axis)
    c = ax.pcolormesh(
        x,
        y,
        np.real(rgf_mat),
        cmap="RdBu",
        vmax=0.5,
        vmin=-0.5,
        shading="auto",
    fig.colorbar(c, ax=ax, label=r"Re $G^R(j, j_c, t)$")
    ax.set_xlabel("Qubit", fontsize=16)
    ax.xaxis.set_major_locator(
        plt.matplotlib.ticker.MaxNLocator(integer=True)
    ax.set_ylabel(r"Time", fontsize=16)
    if title:
    plt.tight_layout()
def uniform_2q_depth(circuit: QuantumCircuit) -> int:
    """Two-qubit gate depth in a standardized basis."""
        optimization_level=0, basis_gates=["cz", "id", "rz", "sx", "x"]
    return pass_manager.run(circuit).depth(
        lambda inst: inst.operation.num_qubits == 2
Small-scale simulator example
We first demonstrate the full workflow on 10 qubits, optimizing the HVA ground-state ansatz by using MPS simulation and using the Qiskit statevector simulator for time evolution. DMRG gives a reference ground-state energy and a reference MPS. This small-scale example lets us validate every step before scaling up.
We begin by defining the physical model and constructing the quantum circuits.
Hamiltonian. KCuF3_3 is modeled by the 1D XXZ Hamiltonian at the isotropic point (J=1J = 1, ϵ=1\epsilon = 1, setting J=1J = 1 as the energy unit).
Ground state. We use a Hamiltonian variational ansatz (HVA) circuit, build_ground_state_ansatz, as the ground-state preparation circuit. The HVA parameters are optimized classically by maximizing the state fidelity ∣⟨ψHVA(θ)∣ψDMRG⟩∣2|\langle\psi_{\mathrm{HVA}}(\theta)|\psi_{\mathrm{DMRG}}\rangle|^2 with the DMRG ground-state MPS, where the HVA state is evaluated by simulating the circuit as a matrix product state with quimb's CircuitMPS. We use scipy.optimize.minimize for the optimization. The energy ⟨H⟩\langle H \rangle of the optimized ansatz is also computed for reference.
Trotter gates. Each nearest-neighbor interaction term e−iΔt Hpaire^{-i\Delta t\, H_{\mathrm{pair}}} with Hpair=(J/4)(XX+YY+ZZ)H_{\mathrm{pair}} = (J/4)(XX + YY + ZZ) is constructed with PauliEvolutionGate(H_pair, time=time_step). Qiskit synthesizes this into the optimal three-CNOT decomposition during transpilation.
Perturbation. An Rz(π/2)R_z(\pi/2) gate on the center qubit implements Ujc=12(I−iσjcz)U_{j_c} = \frac{1}{\sqrt{2}}(I - i\sigma^z_{j_c}), mimicking the local spin-flip produced by a scattered neutron.
Observables. We construct a σz\sigma^z observable for each qubit site. These SparsePauliOp objects are passed to the Estimator primitive in Step 3 to extract ⟨σiz⟩\langle\sigma_i^z\rangle at every time step.
# -- Physical parameters --
n_qubits = 10
interaction = 1.0  # J
anisotropy = 1.0  # ε (isotropic point)
time_step = 0.6
n_steps = 10
mps_max_bond = 32
mps_cutoff = 1e-8
# -- Hamiltonian MPO --
ham_mpo = xxz_hamiltonian_mpo(n_qubits, interaction, anisotropy)
# -- Reference ground-state energy via DMRG --
dmrg = qtn.DMRG2(ham_mpo)
dmrg.solve(tol=1e-8)
print(f"Ground-state energy (DMRG): {dmrg.energy:.6f}")
# -- Build ground state ansatz circuit --
gs_n_layers = 3
gs_ansatz = build_ground_state_ansatz(n_qubits, gs_n_layers)
# -- Optimize ground state ansatz parameters to maximize fidelity with the DMRG MPS --
# Initialize odd-layer angles near 0 (where the inter-pair gate is the
# identity) and even-layer angles near pi/2 (where the intra-pair gate
# is a SWAP, since 0.5*(XX + YY + ZZ) = SWAP - I/2).
rng = np.random.default_rng(12345)
x0 = np.tile([0, np.pi / 2], gs_n_layers) + rng.normal(
    scale=0.1, size=2 * gs_n_layers
print("Optimizing ground state ansatz...")
t0 = timeit.default_timer()
result = optimize_ground_state_ansatz(
    gs_ansatz,
    x0,
    dmrg.state,
    max_bond=mps_max_bond,
    cutoff=mps_cutoff,
    options=dict(maxiter=100),
t1 = timeit.default_timer()
print(f"Finished optimizing ground state ansatz in {t1 - t0} seconds.")
print(f"Ground state ansatz fidelity: {1 - result.fun:.6f}")
gs_circuit = gs_ansatz.assign_parameters(result.x)
gs_circuit_mps = quimb_circuit(
    gs_circuit.decompose(["PauliEvolution"]),
    cutoff=mps_cutoff,
gs_ansatz_energy = qtn.expec_TN_1D(
    gs_circuit_mps.psi.H, ham_mpo, gs_circuit_mps.psi
print(f"Ground state ansatz energy: {gs_ansatz_energy:.6f}")
# -- Build circuits for each time step --
perturbed = gs_circuit.copy()
perturbed.rz(np.pi / 2, center)
circuits = []
for t in range(1, n_steps + 1):
    circuit = perturbed.copy()
    for instr in trotter_evolution(
        circuit.qubits, interaction, anisotropy, time_step, t
        circuit.append(instr)
    circuits.append(circuit)
    f"Built {len(circuits)} circuits, deepest 2q depth (uniform basis) = "
    f"{uniform_2q_depth(circuits[-1])}"
# -- Observables: Z on each qubit site --
observables = [
    SparsePauliOp.from_sparse_list([("Z", [i], 1)], num_qubits=n_qubits)
    for i in range(n_qubits)
print(f"Defined {len(observables)} Z observables.")
Ground-state energy (DMRG): -4.258035
Finished optimizing ground state ansatz in 8.850687621976249 seconds.
Ground state ansatz fidelity: 0.984277
Ground state ansatz energy: -4.232565
Built 10 circuits, deepest 2q depth (uniform basis) = 163
Defined 10 Z observables.
For real hardware, the Trotter circuits above would be too deep. Approximate quantum compiling (AQC) addresses this by replacing the first kk Trotter layers (including the ground-state circuit) with a shorter parameterized ansatz optimized to maximize the MPS-level fidelity with the original deep circuit. The remaining Trotter steps are appended exactly, producing a shallower "AQC + Trotter" circuit.
To balance expressibility against circuit depth, two ansätze are used: a one-layer ansatz (generated from a single Trotter step) compresses the earliest time steps, and a deeper two-layer ansatz (generated from two Trotter steps) compresses the next few steps where higher fidelity is needed.
The AQC workflow has four sub-steps:
  1. Build target circuits — the first k1+k2k_1 + k_2 circuits from Step 1 serve directly as AQC targets.
  2. Compute target MPS — simulate each target circuit as a matrix-product state using quimb.tensor.CircuitMPS.
  3. Generate and optimize ansätze — generate_ansatz_from_circuit creates a one-layer and a two-layer parameterized ansatz; parameters are optimized by using L-BFGS-B with JAX-accelerated gradients to minimize 1−∣⟨ψansatz∣ψtarget⟩∣21 - |\langle\psi_{\mathrm{ansatz}}|\psi_{\mathrm{target}}\rangle|^2. The first k1k_1 steps use the one-layer ansatz and the next k2k_2 steps use the two-layer ansatz; within each stage, each step warm-starts from the previous step's optimized parameters, and parameters are reset to the stage defaults at the stage boundary.
  4. Assemble mixed circuits — for time steps beyond the AQC checkpoint, append exact Trotter layers to the optimized two-layer AQC circuit using trotter_evolution.
# Number of time steps to compress into an AQC ansatz with one layer
aqc_n_steps_1 = 3
# Number of time steps to compress into an AQC ansatz with two layers
aqc_n_steps_2 = 2
aqc_n_steps_total = aqc_n_steps_1 + aqc_n_steps_2
# ── Step 2a: Target circuits (first aqc_n_steps_total circuits from Step 1) ──
target_circuits = {
    k: circuits[k - 1] for k in range(1, aqc_n_steps_total + 1)
# ── Step 2b: Compute target MPS ──
# Decompose PauliEvolutionGate to RXX/RYY/RZZ before passing to the AQC MPS
# backend, which does not understand PauliEvolutionGate natively.
aqc_sim = QuimbSimulator(
    quimb_circuit_factory=partial(
        qtn.CircuitMPS,
        gate_opts=dict(max_bond=mps_max_bond, cutoff=mps_cutoff),
    autodiff_backend="jax",
print("\nStep 2b — target MPS:")
target_mps = {}
for k in range(1, aqc_n_steps_total + 1):
    target_mps[k] = tensornetwork_from_circuit(
        target_circuits[k].decompose(["PauliEvolution"]), aqc_sim
    print(f"  k={k}: max bond = {target_mps[k].psi.max_bond()}")
# ── Step 2c: Generate ansätze (one-layer and two-layer) and optimize parameters ──
ansatz_1, initial_params_1 = generate_ansatz_from_circuit(
    target_circuits[1].decompose(["PauliEvolution"]),
    qubits_initially_zero=True,
initial_params_1 = np.array(initial_params_1)
ansatz_2, initial_params_2 = generate_ansatz_from_circuit(
    target_circuits[2].decompose(["PauliEvolution"]),
initial_params_2 = np.array(initial_params_2)
    f"\nStep 2c — one-layer ansatz: {ansatz_1.num_parameters} parameters, "
    f"2q depth (uniform basis) = {uniform_2q_depth(ansatz_1)}"
    f"Step 2c — two-layer ansatz: {ansatz_2.num_parameters} parameters, "
    f"2q depth (uniform basis) = {uniform_2q_depth(ansatz_2)}"
aqc_circuits = {}
aqc_params = {}
    if k <= aqc_n_steps_1:
        ansatz, base_params = ansatz_1, initial_params_1
        ansatz, base_params = ansatz_2, initial_params_2
    # Warm-start from the previous step only within the same stage
    same_stage = (k - 1 >= 1) and (
        (k - 1 <= aqc_n_steps_1) == (k <= aqc_n_steps_1)
    x0 = aqc_params[k - 1] if same_stage else base_params
    obj = MaximizeStateFidelity(target_mps[k], ansatz, aqc_sim)
    result = scipy.optimize.minimize(
        obj.loss_function,
        x0,
        method="L-BFGS-B",
        jac=True,
    elapsed = timeit.default_timer() - t0
    aqc_params[k] = result.x
    aqc_circuits[k] = ansatz.assign_parameters(result.x)
        f"  k={k}: fidelity = {1 - result.fun:.4f}, "
        f"2q depth (uniform basis) = "
        f"{uniform_2q_depth(aqc_circuits[k])}, "
        f"{elapsed:.1f}s"
# ── Step 2d: Assemble full circuit set (AQC + Trotter) ──
all_circuits = []
    all_circuits.append(aqc_circuits[k])
base = aqc_circuits[aqc_n_steps_total]
for k in range(1, n_steps - aqc_n_steps_total + 1):
    circuit = base.copy()
        circuit.qubits, interaction, anisotropy, time_step, k
    all_circuits.append(circuit)
full_depths = [
    uniform_2q_depth(circuits[k - 1]) for k in range(1, n_steps + 1)
aqc_depths = [uniform_2q_depth(circuit) for circuit in all_circuits]
full_2q = [
    circuits[k - 1].decompose(["PauliEvolution"]).num_nonlocal_gates()
aqc_2q = [
    circuit.decompose(["PauliEvolution"]).num_nonlocal_gates()
print(f"\nStep 2d — assembled {len(all_circuits)} circuits")
    f"  At step {n_steps} (uniform basis): "
    f"Trotter 2q depth = {full_depths[-1]}, AQC+Trotter 2q depth = {aqc_depths[-1]}; "
    f"2q gates: Trotter = {full_2q[-1]}, AQC+Trotter = {aqc_2q[-1]}"
steps_axis = np.arange(1, n_steps + 1)
fig, ax = plt.subplots(figsize=(7, 4))
ax.plot(steps_axis, full_depths, "-o", color="black", label="Full Trotter")
ax.plot(
    steps_axis, aqc_depths, "-o", color="cadetblue", label="AQC + Trotter"
ax.set_xlabel("Trotter steps", fontsize=13)
ax.xaxis.set_major_locator(plt.matplotlib.ticker.MaxNLocator(integer=True))
ax.set_ylabel("2q gate depth (uniform basis)", fontsize=13)
ax.set_title(f"AQC circuit-depth reduction ({n_qubits} qubits)", fontsize=13)
ax.legend(fontsize=11)
plt.tight_layout()
  k=1: max bond = 22
  k=2: max bond = 22
  k=3: max bond = 26
  k=4: max bond = 27
  k=5: max bond = 30
Step 2c — one-layer ansatz: 389 parameters, 2q depth (uniform basis) = 27
Step 2c — two-layer ansatz: 470 parameters, 2q depth (uniform basis) = 33
  k=1: fidelity = 1.0000, 2q depth (uniform basis) = 27, 11.8s
  k=2: fidelity = 0.9980, 2q depth (uniform basis) = 27, 13.2s
  k=3: fidelity = 0.9890, 2q depth (uniform basis) = 27, 13.7s
  k=4: fidelity = 0.9983, 2q depth (uniform basis) = 33, 16.4s
  k=5: fidelity = 0.9957, 2q depth (uniform basis) = 33, 16.4s
Step 2d — assembled 10 circuits
  At step 10 (uniform basis): Trotter 2q depth = 163, AQC+Trotter 2q depth = 99; 2q gates: Trotter = 371, AQC+Trotter = 200
We simulate each AQC-compiled circuit using the StatevectorEstimator primitive.
estimator = StatevectorEstimator()
pubs = [(circuit, observables) for circuit in all_circuits]
job = estimator.run(pubs)
result = job.result()
We now extract the expectation value ⟨σiz⟩\langle\sigma_i^z\rangle for every qubit ii at each time step tt. These values form the retarded Green's function matrix GR(j,jc,t)G^R(j, j_c, t). Then, we Fourier-transform the RGF into the dynamical structure factor S(q,ω)S(q, \omega) and plot both the RGF and the DSF. get_dsf applies mirror symmetry and clips negative values internally.
rgf_mat = np.stack([pub_result.data.evs for pub_result in result])
# -- Compute DSF --
n_points_momentum, n_points_frequency = 100, 100
spectrum = get_dsf(
    n_qubits,
    rgf_mat,
    time_step,
    n_steps,
    n_points_momentum,
    n_points_frequency,
# -- Plot retarded Green's function --
plot_rgf(
    n_qubits,
    rgf_mat,
    time_step,
    n_steps,
    title=f"Retarded Green's function — {n_qubits} qubits (simulation)",
# -- Plot DSF --
plot_dsf(
    spectrum,
    time_step,
    n_points_momentum,
    n_points_frequency,
    title=f"Dynamical structure factor — {n_qubits} qubits (simulation)",
Large-scale hardware execution
We now scale up to 50 qubits. At this scale, the optimizations reach lower fidelities than in the small-scale example: the ground-state ansatz fidelity drops to roughly 0.65, and the AQC fidelities decrease to roughly 0.7 at the later checkpoints. This is expected, and you can improve these fidelities by increasing the number of ground-state ansatz layers (gs_n_layers) or the number of optimization iterations (maxiter) at additional classical cost. Note also that the two-layer AQC fidelities come out lower than the one-layer ones. This is not a regression: later time steps generate more entanglement and are simply harder to compress, which is why the more expressive two-layer ansatz is used for them.
The AQC optimization can also take several hours of classical compute time (roughly six hours in the run shown here, most of it spent on the two-layer checkpoints in Step 2c). To reduce the wall-clock time, consider running this notebook on more powerful classical hardware, such as a high-performance computing (HPC) system. Alternatively, you can scale down to a smaller problem instance (for example, fewer qubits or fewer time steps); your results will then differ from the ones shown here.
The code below follows the same four-step structure as the small-scale example. The HVA ground-state parameters are again optimized by using MPS simulation. On the QPU, we enable dynamical decoupling (DD), Pauli twirling, and twirled readout error extinction (TREX) for error suppression and mitigation. The following table summarizes how the large-scale experiment differs from the small-scale one:
Small scale
Large scale
Qubits1050
Time steps1020
AQC checkpoints (1-layer + 2-layer)3 + 2 = 56 + 4 = 10
Ground state ansatz layers35
MPS max bond dimension32128
EstimatorStatevectorEstimatorQPU with DD, Pauli twirling, and TREX
XLA slow-compile messages
During the AQC optimization (Step 2c below) you might see stderr messages such as:
[Compiling module jit_MakeArrayFn for CPU] Very slow compile? ...
The operation took 2m14s
These are benign diagnostics from XLA, the compiler that backs qiskit-addon-aqc-tensor's JAX autodiff. At 50 qubits with MPS bond dimension 128, XLA spends a couple of minutes compiling the gradient function the first time it is traced. The compilation succeeds, and the optimization results are unaffected.
# ── Parameters ──────────────────────────────────────────────────────────────
n_qubits = 50  # 10 → 50
time_step = 0.6
n_steps = 20  # 10 → 20
aqc_n_steps_1 = 6  # 3 → 6
aqc_n_steps_2 = 4  # 2 → 4
gs_n_layers = 5  # 3 → 5
mps_max_bond = 128  # 32 -> 128
mps_cutoff = 1e-8
# ── Step 1: Map ──────────────────────────────────────────────────────────────
x0 = np.tile([0.0, np.pi / 2], gs_n_layers) + rng.normal(
    gs_ansatz,
    x0,
    dmrg.state,
    cutoff=mps_cutoff,
    cutoff=mps_cutoff,
circuits = []
observables = [
# ── Step 2: AQC ──────────────────────────────────────────────────────────────
target_circuits = {
        qtn.CircuitMPS,
target_mps = {}
aqc_circuits = {}
aqc_params = {}
        obj.loss_function,
        x0,
        method="L-BFGS-B",
        jac=True,
        f"{elapsed:.1f}s"
all_circuits = []
full_depths = [
full_2q = [
aqc_2q = [
ax.plot(
plt.tight_layout()
# ── Step 3: Execute on IBM Quantum hardware ───────────────────────────────────
# (replaces StatevectorEstimator)
backend = service.least_busy(
    min_num_qubits=n_qubits,
    operational=True,
    simulator=False,
    filters=lambda x: x.configuration().processor_type["family"] == "Heron",
print(f"Backend: {backend.name}")
isa_circuits = pm.run(all_circuits, num_processes=1)
isa_2q_depths = [
    isa_circuit.depth(lambda inst: inst.operation.num_qubits == 2)
    for isa_circuit in isa_circuits
    f"Transpiled 2q depth (deepest, ISA on {backend.name}): "
    f"{max(isa_2q_depths)} "
    f"(2q gates: {max(isa_circuit.num_nonlocal_gates() for isa_circuit in isa_circuits)})"
estimator.options.environment.job_tags = ["TUT_SNS"]
estimator.options.dynamical_decoupling.sequence_type = "XY4"
estimator.options.twirling.num_randomizations = 1000
estimator.options.twirling.shots_per_randomization = 128
estimator.options.resilience.measure_noise_learning.num_randomizations = 32
estimator.options.resilience.measure_noise_learning.shots_per_randomization = 100
pubs = [
        isa_circuit,
        [obs.apply_layout(isa_circuit.layout) for obs in observables],
print(f"Job ID: {job.job_id()}")
# ── Step 4: Post-process ──────────────────────────────────────────────────────
spectrum = get_dsf(
    n_qubits,
    rgf_mat,
    time_step,
    n_steps,
    n_points_momentum,
    n_points_frequency,
plot_rgf(
    n_qubits,
    rgf_mat,
    time_step,
    n_steps,
    title=f"Retarded Green's function — {n_qubits} qubits (QPU)",
plot_dsf(
    spectrum,
    time_step,
    n_points_momentum,
    n_points_frequency,
    title=rf"KCuF$_3$ DSF — {n_qubits} qubits (QPU)"
    "\n(AQC + DD + Pauli twirling + TREX)",
Ground-state energy (DMRG): -21.972109
Finished optimizing ground state ansatz in 132.2076231740648 seconds.
Ground state ansatz fidelity: 0.645956
Ground state ansatz energy: -21.616744
Built 20 circuits, deepest 2q depth (uniform basis) = 307
Defined 50 Z observables.
  k=1: max bond = 44
  k=2: max bond = 46
  k=3: max bond = 53
  k=4: max bond = 62
  k=5: max bond = 75
  k=6: max bond = 96
  k=7: max bond = 118
  k=8: max bond = 128
  k=9: max bond = 128
  k=10: max bond = 128
Step 2c — one-layer ansatz: 2971 parameters, 2q depth (uniform basis) = 39
Step 2c — two-layer ansatz: 3412 parameters, 2q depth (uniform basis) = 45
  k=1: fidelity = 1.0000, 2q depth (uniform basis) = 39, 215.6s
  k=2: fidelity = 0.9676, 2q depth (uniform basis) = 39, 269.8s
  k=3: fidelity = 0.9014, 2q depth (uniform basis) = 39, 293.5s
  k=4: fidelity = 0.8755, 2q depth (uniform basis) = 39, 279.6s
  k=5: fidelity = 0.8450, 2q depth (uniform basis) = 39, 266.4s
  k=6: fidelity = 0.8146, 2q depth (uniform basis) = 39, 371.0s
E0626 02:59:07.229070 1508496 slow_operation_alarm.cc:73]
[Compiling module jit_MakeArrayFn for CPU] Very slow compile? If you want to file a bug, run with envvar XLA_FLAGS=--xla_dump_to=/tmp/foo and attach the results.
E0626 02:59:21.713796 1508477 slow_operation_alarm.cc:140] The operation took 2m14.484932074s
  k=7: fidelity = 0.7312, 2q depth (uniform basis) = 45, 10865.3s
  k=8: fidelity = 0.7720, 2q depth (uniform basis) = 45, 1450.3s
  k=9: fidelity = 0.7316, 2q depth (uniform basis) = 45, 3388.6s
E0626 07:21:05.148724 1508496 slow_operation_alarm.cc:73]
E0626 07:21:24.286095 1508477 slow_operation_alarm.cc:140] The operation took 2m19.137566498s
  k=10: fidelity = 0.6726, 2q depth (uniform basis) = 45, 3396.1s
Step 2d — assembled 20 circuits
  At step 20 (uniform basis): Trotter 2q depth = 307, AQC+Trotter 2q depth = 171; 2q gates: Trotter = 3775, AQC+Trotter = 1913
Backend: ibm_fez
Transpiled 2q depth (deepest, ISA on ibm_fez): 105 (2q gates: 2574)
Job ID: d8v39vhropqc738biotg
The hardware results reproduce the key features of the two-spinon continuum: the scattering intensity is concentrated near the antiferromagnetic wave vector q=πq = \pi at low energy and is bounded from below by the sinusoidal spinon dispersion, with a broad continuum of spectral weight above it rather than a single sharp mode. This is the same structure measured by inelastic neutron scattering on KCuF3_3, and it validates the full workflow of ground-state preparation, perturbation, AQC-compressed Trotter evolution, and error-mitigated measurement at the 50-qubit scale.
Next steps
Recommendations
Was this page helpful?
