翻訳情報
このページの追加言語翻訳は近日公開予定です。
Pauli correlation encoding to reduce max-cut requirements
Usage estimate: 35 minutes on an Eagle r3 processor (NOTE: This is an estimate only. Your runtime might vary.)
Learning outcomes
  • Understand the theoretical principles behind Pauli Correlation Encoding (PCE), including how multi‑body Pauli strings enable polynomial compression of classical optimization problems.
  • Implement PCE in practice to encode and solve large‑scale optimization tasks on near‑term quantum hardware.
Background
This tutorial presents Pauli Correlation Encoding (PCE) [1], an approach designed to encode optimization problems into qubits with greater efficiency for quantum computation. PCE maps classical variables in optimization problems to multi-body Pauli-matrix correlations, resulting in a polynomial compression of the problem's space requirements. By employing PCE, the number of qubits needed for encoding is reduced, making it particularly advantageous for near-term quantum devices with limited qubit resources. Furthermore, it is analytically demonstrated that PCE inherently mitigates barren plateaus, offering super-polynomial resilience against this phenomenon. This built-in feature enables unprecedented performance in quantum optimization solvers.
Overview
The PCE approach consists of three main steps, as illustrated in Figure 1 from [1] in below:
  1. Encoding the optimization problem into a Pauli correlation space.
  2. Solving the problem using a quantum-classical optimization solver.
  3. Decoding the solution back to the original optimization space. The PCE approach is adaptable to any quantum optimization solver capable of processing Pauli correlation matrices.
Overview of PCE.
In Figure 1 from [1], the max-cut problem is used as an example to illustrate the PCE approach. The max-cut problem with m=9m=9 nodes is encoded into a Pauli correlation space, representing the optimization problem as a correlation matrix — specifically, two-body Pauli-matrix correlations across n=3n=3 qubits (Q1,Q2,Q3)(Q_1, Q_2, Q_3). Node colors indicate the Pauli string used for each encoded node. For example, node 1, which corresponds to binary variable x1x_1, is encoded by the expectation value of Z1⊗Z2⊗I3Z_1 \otimes Z_2 \otimes I_3, while x8x_8 is encoded by I1⊗Y2⊗Y3I_1 \otimes Y_2 \otimes Y_3. This corresponds to compressing the problem's mm variables into n=O(m1/2) n = O(m^{1/2}) qubits. More broadly, kk -body correlations enable polynomial compressions of order kk, with k>1k>1. The chosen Pauli set comprises three subsets of mutually-commuting Pauli strings, allowing all mm correlations to be experimentally estimated with only three measurement settings.
A loss function L\mathcal{L} of Pauli expectation values that imitates the original max-cut objective function is constructed. The loss function is then optimized using a quantum-classical optimization solver, such as the Variational Quantum Eigensolver (VQE).
Once the optimization is complete, the solution is decoded back to the original optimization space, yielding the optimal max-cut solution.
Requirements
  • Qiskit SDK v1.0 or later, with visualization support
  • Optimization Mapper Qiskit addon (pip install qiskit-addon-opt-mapper)
Setup
import rustworkx as rx
import networkx as nx
from scipy.optimize import minimize, OptimizeResult
def make_cut_evaluator(problem):
    """Return a function that maps a 0/1 node assignment to its cut value.
    The objective of the max-cut ``OptimizationProblem`` is the cut value
    itself, and ``problem.objective.evaluate`` computes it for one
    assignment. The swap search in Step 4 evaluates one candidate
    assignment per edge, so pull the objective's coefficients out once
    and evaluate them as a sparse matrix product instead.
    quadratic = problem.objective.quadratic.coefficients.tocsr()
    linear = problem.objective.linear.to_array()
    constant = problem.objective.constant
    def evaluate_cut(bits):
        x = np.asarray(bits, dtype=float)
        return int(round(constant + linear @ x + x @ (quadratic @ x)))
    return evaluate_cut
Small-scale simulator example
real_backend = service.least_busy(
backend = AerSimulator.from_backend(real_backend)
print(f"We are using the {backend.name}")
We are using the aer_simulator_from(ibm_pittsburgh)
The max-cut problem
The max-cut problem is a combinatorial optimization problem that is defined on a graph G=(V,E)G = (V, E), where VV is the set of vertices and EE is the set of edges. The goal is to partition the vertices into two sets, SS and V∖SV \setminus S, such that the number of edges between the two sets is maximized. For the detailed description of the max-cut problem, please refer to the Quantum approximate optimization algorithm tutorial. The max-cut problem is also used as an example in the Advanced techniques for QAOA tutorial. In those tutorials, the QAOA algorithm is used to solve the max-cut problem.
Graph → optimization problem
Let us first consider a random graph with 100 nodes.
num_nodes = 100  # Number of nodes in graph
seed = 42
graph = rx.undirected_gnp_random_graph(num_nodes, 0.1, seed=seed)
mpl_draw(graph)
Model the max-cut problem with the Maxcut application class from the Optimization Mapper Qiskit addon. It returns an OptimizationProblem with one binary variable per node whose objective is the cut value to maximize. In the QAOA tutorials, this problem is converted to a QUBO and translated to a cost Hamiltonian with one qubit per variable. PCE instead encodes each binary variable into the sign of a Pauli expectation value, so here the problem defines and evaluates the objective, and the encoding into qubits follows below.
maxcut = Maxcut(graph)
maxcut_problem = maxcut.to_optimization_problem()
evaluate_cut = make_cut_evaluator(maxcut_problem)
print(f"Binary variables: {maxcut_problem.get_num_vars()}")
    "Quadratic terms (one per edge):",
    len(maxcut_problem.objective.quadratic.to_dict()),
Binary variables: 100
Quadratic terms (one per edge): 508
nx_graph = nx.Graph()
Initial cut size: 345
We encode the graph with 100 nodes into two-body Pauli-matrix correlations across nine qubits (see the explanation below). The graph is represented as a correlation matrix, where each node is encoded by a Pauli string. The sign of the expectation value of the Pauli string indicates the partition of the node. For example, node 0 is encoded by a Pauli string, ∏0=I8⊗...I2⊗X1⊗X0\prod_0 = I_{8} \otimes ... I_2 \otimes X_1 \otimes X_0. The sign of the expectation value of this Pauli string indicates the partition of node 0. We define a Pauli-correlation encoding (PCE) relative to ∏\prod as
xi≔sgn(⟨∏i⟩),x_i \coloneqq \textit{sgn}(\langle\prod_i \rangle),
where xix_i is the partition of node ii and ⟨∏i⟩≔⟨ψ∣∏i∣ψ⟩\langle \prod_i \rangle \coloneqq \langle \psi |\prod_i| \psi \rangle is the expectation value of the Pauli string encoding node ii over a quantum state ∣ψ⟩|\psi \rangle.
Now, let's encode the graph into a Hamiltonian using PCE. We divide the nodes into three sets: S1S_1, S2S_2, and S3S_3. Then, we encode the nodes in each set using the Pauli strings with XX, YY, and ZZ, respectively.
We need to extract a relationship between the number of nodes and qubits that we will need to encode all the nodes. Using all possible permutations for the encoding yields to:
m=3(nk).m=3\binom{n}{k}.
In this example we consider k=2k=2, hence,
m=32n(n−1).m = \frac{3}{2} n(n-1).
Therefore, the number of qubits nn needed to express a certain number of nodes mm read as:
n=⌈1+1+83m2⌉.n = \left\lceil \frac{1 + \sqrt{1 + \tfrac{8}{3}m}}{2} \right\rceil.
Note that the ⌈⋅⌉\lceil \cdot \rceil symbol represents the ceiling function, which rounds any real number up to the next integer. This ensures that the number of qubits is an integer.
num_qubits = int(np.ceil((1 + np.sqrt(1 + (8 / 3) * num_nodes)) / 2))
list_size = num_nodes // 3
print(f"Number of qubits: {num_qubits}")
print("List 1:", node_x)
print("List 2:", node_y)
print("List 3:", node_z)
Number of qubits: 9
List 1: [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32]
List 2: [33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65]
List 3: [66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99]
        if idx >= len(node_list):
            break
        paulis = ["I"] * n
    hamiltonian = []
    return hamiltonian
    "X", node_x, num_qubits
    "Y", node_y, num_qubits
    "Z", node_z, num_qubits
Quantum circuit
Here, the state ∣ψ⟩|\psi \rangle is parameterized with θ\mathbf{\theta}, and we optimize these parameters θ\mathbf{\theta} using a variational approach. This tutorial employs the efficient_su2 ansatz for our variational algorithm due to its expressive capabilities and ease of implementation. We also use the relaxed loss function, which will be introduced later in this tutorial. As a result, we can address large-scale problems with fewer qubits and shallower circuit depths.
# Build the quantum circuit
qc = efficient_su2(num_qubits, su2_gates=["ry", "rz"], reps=2)
qc.draw("mpl")
# Optimize the circuit
qc = pm.run(qc)
Loss function
For the loss function L\mathcal{L}, we use a relaxation of the max-cut objective function as described in [1], which is defined as V(x)≔∑(i,j)∈EWi,j(1−xixj)\mathcal{V}(\mathbf{x}) \coloneqq \sum_{(i, j) \in E} W_{i, j}(1-x_i x_j). Here, Wi,jW_{i, j} denotes the weight of the edge (i,j)(i, j), and xix_i represents the partition of node ii. The loss function L\mathcal{L} is given by:
L≔∑(i,j)∈EWi,jtanh(α⟨∏i⟩)tanh(α⟨∏j⟩)+L(reg)\mathcal{L}\coloneqq \sum_{(i, j) \in E} W_{i, j} \text{tanh} (\alpha \langle\prod_i \rangle) \text{tanh} (\alpha \langle\prod_j \rangle) + \mathcal{L}^{(\text{reg})},
where the max-cut objective function is replaced by the smooth hyperbolic tangents of the expectation values of the Pauli strings encoding the nodes. The regularization term L(reg)\mathcal{L}^{(\text{reg})} and the rescaling factor α\alpha, proportional to the number of qubits, are introduced to improve the solver's performance.
The regularization term is defined as:
L(reg)\mathcal{L}^{(\text{reg})} is defined as L(reg)≔βν[1m∑i∈Vtanh(α⟨∏i⟩)2]2\mathcal{L}^{(\text{reg})} \coloneqq \beta \nu \lbrack \frac{1}{m} \sum_{i \in V} \text{tanh} (\alpha \langle\prod_i \rangle)^2 \rbrack ^2
where β=1/2\beta=1/2, ν=∣E∣/2+(m−1)/4\nu = |E|/2 + (m -1) /4, ∣E∣|E| is the number of edges, and mm is the number of nodes in the graph.
    Calculates the specified loss function for the given ansatz, Hamiltonian,
    and graph.
    The expectation values of each Pauli string in the Hamiltonian are first
    obtained by running the ansatz on the quantum backend. These
    expectation values are then passed through the nonlinear function
    tanh(alpha * prod_i). The loss function is
    job = estimator.run(
            (ansatz, hamiltonian[0], x),
            (ansatz, hamiltonian[1], x),
            (ansatz, hamiltonian[2], x),
    result = job.result()
    # calculate the loss function
    node_exp_map = {}
    idx = 0
    for r in result:
        for ev in r.data.evs:
            node_exp_map[idx] = ev
            idx += 1
    loss = 0
    alpha = num_qubits
            alpha * node_exp_map[edge1]
    regulation_term = 0
    beta = 1 / 2
    loss = loss + regulation_term
    global experiment_result
    return loss
In this tutorial, we set max_iter=50 in the optimization loop for demonstration purposes. If we increase the number of iterations, we can expect better results.
pce = []
pce.append(
pce.append(
pce.append(
max_iter = 50
counter = {"i": 0}
last_x = {"value": None}
last_fun = {"value": None}
    experiment_result = []
    def loss_func(x):
        last_x["value"] = x.copy()
        if counter["i"] + 1 > max_iter:
            return last_fun["value"]
        counter["i"] += 1
        val = loss_func_estimator(
        last_fun["value"] = val
        return val
    np.random.seed(seed)
    result = minimize(
        loss_func, initial_params, method="COBYLA", options={"rhobeg": 1.0}
    if counter["i"] >= max_iter:
        result = OptimizeResult(
            message=f"Return from COBYLA because the objective function "
            f"has been evaluated {max_iter} times.",
            success=False,
            status=3,
            fun=last_fun["value"],
            x=last_x["value"],
            nfev=counter["i"],
print(result)
Iter 0: 152.06331779109445
Iter 1: 126.93132569244693
Iter 2: 55.00651109478942
Iter 3: 33.21667439735082
Iter 4: 19.167189700765054
Iter 5: 30.426875553389127
Iter 6: 13.906354614925815
Iter 7: 27.668686100172614
Iter 8: 28.194600411380772
Iter 9: 24.899677141564936
Iter 10: 22.10858041608358
Iter 11: 8.096210209030176
Iter 12: 8.761240650022913
Iter 13: 9.43332962472133
Iter 14: 7.559669820210062
Iter 15: 13.023860357384214
Iter 16: 11.953653163007987
Iter 17: 10.434221292269214
Iter 18: 4.871246922225549
Iter 19: 10.303826533395856
Iter 20: 16.40225843511339
Iter 21: 10.852469442638652
Iter 22: 9.314666066331633
Iter 23: 6.082358010011717
Iter 24: 10.982893700414476
Iter 25: 4.575556036893407
Iter 26: 6.844995727798197
Iter 27: 8.695229718011293
Iter 28: 3.730227705075576
Iter 29: 4.285479467758721
Iter 30: 4.219714169314187
Iter 31: 0.21125608131726548
Iter 32: 4.22820465672552
Iter 33: 13.67513152473414
Iter 34: 10.388838701884863
Iter 35: -0.5400153834163355
Iter 36: 5.310281742761159
Iter 37: -0.5430772019249082
Iter 38: -4.47820293096989
Iter 39: -3.4832056790567467
Iter 40: -0.5087341672330172
Iter 41: -2.488777859669888
Iter 42: 0.34945469121089356
Iter 43: -0.8544299675507805
Iter 44: -3.5902371208579344
Iter 45: 2.6609573847203216
Iter 46: -4.336467834641085
Iter 47: 0.10158504073828034
Iter 48: -1.3506458813942084
Iter 49: -2.1794894170194192
 message: Return from COBYLA because the objective function has been evaluated 50 times.
 success: False
  status: 3
     fun: -2.1794894170194192
       x: [ 1.375e+00  1.951e+00 ...  9.395e-01  8.948e-01]
    nfev: 50
The partitions of the nodes are determined by evaluating the sign of the expectation values of the Pauli strings that encode the nodes. A non-negative expectation value assigns the node the value 1, and a negative expectation value assigns 0. The interpret method of Maxcut then decodes this assignment into the two node sets.
# Decode the node assignment from the iteration with the lowest loss.
# If the expectation value is non-negative, the node is assigned 1,
# otherwise it is assigned 0.
def get_bits(experiment_result):
    best_index = min(
        range(len(experiment_result)),
        key=lambda i: experiment_result[i]["loss"],
    exp_map = experiment_result[best_index]["exp_map"]
    bits = [1 if exp_map[i] >= 0 else 0 for i in range(len(exp_map))]
    return bits, best_index
cur_bits, best_index = get_bits(experiment_result)
partition = maxcut.interpret(np.array(cur_bits))
print("Partition 0:", partition[0])
print("Partition 1:", partition[1])
Partition 0: [0, 1, 3, 5, 6, 7, 9, 11, 12, 14, 15, 17, 22, 24, 25, 28, 31, 32, 33, 35, 37, 38, 39, 40, 41, 43, 49, 53, 54, 56, 59, 61, 63, 65, 67, 68, 69, 77, 78, 79, 80, 88, 92, 93, 94, 95]
Partition 1: [2, 4, 8, 10, 13, 16, 18, 19, 20, 21, 23, 26, 27, 29, 30, 34, 36, 42, 44, 45, 46, 47, 48, 50, 51, 52, 55, 57, 58, 60, 62, 64, 66, 70, 71, 72, 73, 74, 75, 76, 81, 82, 83, 84, 85, 86, 87, 89, 90, 91, 96, 97, 98, 99]
We can calculate the cut size of the max-cut problem by evaluating the objective of the OptimizationProblem on this assignment.
cut_size = evaluate_cut(cur_bits)
Cut size: 278
Once the training is complete, we perform one round of single-bit swap search to improve the solution as a classical post-processing step. In this process, we swap the partitions of two nodes and evaluate the cut size. If the cut size is improved, we keep the swap. We repeat this process for all possible pairs of nodes connected by an edge.
def swap_partitions(graph, cur_bits, evaluate_cut):
    best_cut = 0
    best_bits = []
            swapped_bits[edge1],
        cut_size = evaluate_cut(swapped_bits)
        if best_cut < cut_size:
            best_cut = cut_size
            best_bits = swapped_bits
    return best_cut, best_bits
best_cut, best_bits = swap_partitions(graph, cur_bits, evaluate_cut)
print(best_cut, best_bits)
287 [0, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 0, 0, 1, 0, 0, 1, 0, 1, 1, 1, 1, 0, 1, 0, 0, 1, 1, 0, 1, 1, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0, 1, 0, 1, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1]
Large-scale hardware example
num_nodes = 1500  # Number of nodes in graph
print(f"We are using {num_qubits} qubits")
backend = real_backend
qc = pm.run(qc)
pce = []
pce.append(
pce.append(
pce.append(
# Run the optimization using a session.
max_iter = 50
counter = {"i": 0}
    estimator.options.environment.job_tags = ["TUT_PCEFQ"]
    def loss_func(x):
        counter["i"] += 1
        return val
    result = minimize(
            success=False,
            status=3,
            x=last_x["value"],
            nfev=counter["i"],
print(result)
# Print final solution
    f"The best max-cut value achieved for a graph with {num_nodes} nodes "
    f"on {num_qubits} qubits is {best_cut}"
print(f"and the specific partition we obtained is {best_bits}")
We are using 33 qubits
We are using the ibm_pittsburgh
Iter 0: 62192.56098951446
Iter 1: 54325.76340818571
Iter 2: 42933.215216568526
Iter 3: 35721.92960658595
Iter 4: 35947.69927402131
Iter 5: 38563.731543582166
Iter 6: 32552.97070835923
Iter 7: 34730.314616527576
Iter 8: 27032.920190652876
Iter 9: 27126.107795624957
Iter 10: 25268.853826648774
Iter 11: 23521.1489346676
Iter 12: 21658.585394613096
Iter 13: 15154.765728388778
Iter 14: 14826.985321939152
Iter 15: 16199.811009055386
Iter 16: 14328.589985020852
Iter 17: 13542.67789354434
Iter 18: 11737.341026421902
Iter 19: 10986.431644208033
Iter 20: 9780.61657788984
Iter 21: 8555.757154943312
Iter 22: 10465.489221259657
Iter 23: 8577.158776664453
Iter 24: 8950.176436175909
Iter 25: 7395.8803219317215
Iter 26: 7228.1129297581765
Iter 27: 6881.076354027118
Iter 28: 6626.8983738084835
Iter 29: 7302.433279572058
Iter 30: 6995.735525608492
Iter 31: 6176.828001182083
Iter 32: 6299.8061884979725
Iter 33: 6498.921256598082
Iter 34: 6184.684072713035
Iter 35: 5707.720358527108
Iter 36: 5414.328928670104
Iter 37: 5771.80573980932
Iter 38: 5620.64903695431
Iter 39: 6285.735849503706
Iter 40: 5894.367571492991
Iter 41: 6079.275064349491
Iter 42: 5267.448536682269
Iter 43: 4789.7281459863325
Iter 44: 5109.106057200384
Iter 45: 5060.248865782273
Iter 46: 5064.786713246322
Iter 47: 5474.433264995371
Iter 48: 4675.6138719238015
Iter 49: 5081.660754434205
 success: False
  status: 3
     fun: 5081.660754434205
       x: [ 1.375e+00  1.951e+00 ...  7.260e-01  8.971e-01]
    nfev: 50
Cut size: 55507
The best max-cut value achieved for a graph with 1500 nodes on 33 qubits is 55567
and the specific partition we obtained is [1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 0, 1, 0, 1, 0, 0, 0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 1, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 0, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 0, 0, 0, 1, 1, 1, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 1, 0, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 0, 0, 0, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 0, 0, 1, 1, 1, 1, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 1, 0, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 0, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 0, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 0, 0, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 1, 1, 0, 0, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 0, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0, 1, 1, 0, 1, 0, 1, 1, 1, 0, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 1, 1, 0, 1, 1, 0, 0, 1, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 0, 1, 0, 1, 0, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 0, 1, 1, 0, 1, 0, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 1, 0, 1, 0, 1, 0, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0, 1, 0, 0, 1, 0, 1, 1, 0, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 0, 1, 0, 1, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 1, 0, 1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 1, 1, 0, 1, 1, 1, 0, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0, 1, 0, 1, 0, 1, 0, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 0, 1, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 0, 0, 1, 1, 1, 0, 1, 1, 1, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 1, 0, 0, 1, 0, 1, 1, 1, 0, 0, 1, 0, 0, 0, 0, 1, 0, 1, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 0, 1, 1, 0, 1, 0, 1, 1, 1, 1, 0, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 1, 0, 1, 0, 0, 1, 1, 1, 0, 0, 1, 0, 1, 0, 1, 1, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1]
Next steps
Recommendations
References
[1] Sciorilli, M., Borges, L., Patti, T. L., García-Martín, D., Camilo, G., Anandkumar, A., & Aolita, L. (2024). Towards large-scale quantum optimization solvers with few qubits. arXiv preprint arXiv:2401.09421.
Tutorial survey
Link to survey
© IBM Corp. 2024-2026
このページは役に立ちましたか?
