Migrate from NoiseLearner to NoiseLearnerV3
This guide walks you through migrating from IBM Quantum® NoiseLearner to NoiseLearnerV3. Both classes perform experiments that characterize noise processes based on a Pauli-Lindblad noise model, but the inputs and outputs are slightly different.
Background
The NoiseLearner class was created to allow users to perform explicit noise learning. The resulting noise model can then be passed to IBM Quantum Estimator for applying error mitigation techniques such as PEA and PEC.
NoiseLearner was designed to work with Estimator, and therefore it implicitly employs the same layer finding strategy as Estimator. This strategy cannot be changed; otherwise, the subsequent mitigation steps would not work correctly.
Starting with qiskit-ibm-runtime v0.47.0, there is a new NoiseLearnerV3 class that is compatible with the Executor primitive and the directed execution model. This new model delivers a white-box experience by providing the pieces to capture design intent on the client side, and a single server-side primitive (Executor) processes those inputs exactly as directed — it makes no implicit decisions on your behalf. Unlike the original NoiseLearner, you control how to stratify your circuits when you useNoiseLearnerV3, and the class simply takes a list of boxed circuit instructions (for example, unique layers) as its input.
NoiseLearnerV3 also supports measurement noise learning. For each instruction in the input list, it runs the Pauli-Lindblad learning protocol if the box contains one- and two-qubit gates, and the TREX protocol if the box contains measurements.
Should you migrate?
NoiseLearner only works with the legacy server-side Estimator, and NoiseLearnerV3 only works with Executor and the client-side Estimator. You must migrate to NoiseLearnerV3 if you are using Executor or client-side Estimator. The legacy server-side Estimator is deprecated and replaced by the client-side equivalent in qiskit-ibm-runtime v0.50.0.
Note
If you are using qiskit-ibm-runtime v0.50.0 or later, read the Migrate from server-side to client-side Sampler and Estimator guide to migrate to client-side primitives first.
Migration steps
Step 1: Change the imports
NoiseLearner:
from qiskit_ibm_runtime.noise_learner import NoiseLearner
NoiseLearnerV3:
from qiskit_ibm_runtime import NoiseLearnerV3
Step 2: Update the inputs
The NoiseLearner run() method takes a list of circuits or PUBs, whereas the NoiseLearnerV3 run() method takes a list of instructions, each of which must be a twirling-annotated BoxOp containing ISA operations. Convenience methods are available for generating the annotated boxes, depending on which primitive you plan to use.
NoiseLearner:
learner = NoiseLearner(mode=backend)
# `circuits_to_learn` is a list of ISA QuantumCircuit
learner_job = learner.run(circuits_to_learn)
NoiseLearnerV3, when working with client-side Estimator:
If you are planning to use client-side Estimator for circuit execution, you can use the find_unique_layers method from Estimator to create annotated boxes (layers):
pubs = [...]  # Your PUBs
estimator.options.resilience.pec_mitigation = True  # or zne_mitigation + pea amplifier
# Identify the unique layers to learn.
layers = estimator.find_unique_layers(pubs)
# Learn the noise model for those layers (runs as a separate job).
learner = NoiseLearnerV3(backend)
learner_job = learner.run(layers)
NoiseLearnerV3, when working with Executor:
If you are planning to use Executor for circuit execution, consider using the generate_boxing_pass_manager function from Samplomatic to create annotated boxes:
from qiskit_ibm_runtime.noise_learner_v3 import NoiseLearnerV3
# Run the boxing pass manager to group instructions into annotated boxes.
# `isa_circuit` is an ISA QuantumCircuit.
boxing_pm = generate_boxing_pass_manager(
    enable_gates=True,
    enable_measures=False,
    inject_noise_targets="gates",  # no measurement mitigation
boxed_circuit = boxing_pm.run(isa_circuit)
# Find unique boxed instructions.
unique_box_instructions = find_unique_box_instructions(boxed_circuit.data)
# Instantiate a NoiseLearnerV3 object and execute the noise learning program.
learner_job = learner.run(unique_box_instructions)
Step 3: Convert the options
Most NoiseLearnerOptions fields map directly to NoiseLearnerV3Options, except the following:
  • max_layers_to_learn: With NoiseLearnerV3, the number of layers to learn is based on the number of layers passed in.
  • twirling_strategy: With NoiseLearnerV3, the twirling strategy is defined by how the instructions are boxed and annotated (such as when using generate_boxing_pass_manager()).
NoiseLearner:
from qiskit_ibm_runtime.options import NoiseLearnerOptions
# Instantiate a NoiseLearnerOptions object
learner_options = NoiseLearnerOptions(
    max_layers_to_learn=3, num_randomizations=32, twirling_strategy="all"
learner = NoiseLearner(mode=backend, options=learner_options)
If you are planning to use client-side Estimator for circuit execution, you can set the twirling.strategy Estimator option:
from qiskit_ibm_runtime.options_models import NoiseLearnerV3Options
estimator.options.twirling.strategy = "all"  # set twirling strategy here
learner_options = NoiseLearnerV3Options(num_randomizations=32)
learner = NoiseLearnerV3(backend, options=learner_options)
# Learn just the first 3 layers.
learner_job = learner.run(layers[:3])
If you are planning to use Executor for circuit execution, you can pass the twirling_strategy option to the generate_boxing_pass_manager function.
Note that with generate_boxing_pass_manager(), the twirling_strategy values use underscores ("active_accum", "active_circuit"), whereas NoiseLearnerOptions.twirling_strategy values use hyphens ("active-accum", "active-circuit").
    enable_gates=True,
    twirling_strategy="all",  # twirling strategy can be specified here
learner_job = learner.run(unique_box_instructions[:3])
Step 4: Inspect the results
The outputs of NoiseLearner and NoiseLearnerV3 contain similar information but are in different formats. Update your code if it inspects the output explicitly.
Result attribute mapping:
(learner_result is the output of the learner job)
Attribute
NoiseLearner
NoiseLearnerV3
Result typeNoiseLearnerResultNoiseLearnerV3Results, a sequence-like container of NoiseLearnerV3Result
Number of learned layerslen(learner_result.data)len(learner_result)
Data for the first layerlayer_error = learner_result.data[0]noise_map = learner_result[0].to_pauli_lindblad_map()
Result type of each layerLayerError (type(layer_error))PauliLindbladMap (type(noise_map))
Generators for the error channellayer_error.error.generatorsnoise_map.generators()
Error rateslayer_error.error.ratesnoise_map.rates
Step 5: Input noise model to a primitive
NoiseLearner only works with the legacy server-side Estimator, and NoiseLearnerV3 only works with Executor and the client-side Estimator. How a noise model is specified varies slightly based on which primitive is used.
NoiseLearner, when working with legacy server-side Estimator:
from qiskit_ibm_runtime import Estimator as LegacyEstimator
learner_result = learner_job.result()
# Pass the noise model to the `estimator.options` attribute directly
estimator = LegacyEstimator(mode=backend)
estimator.options.resilience.layer_noise_model = learner_result
job = estimator.run(pubs)
Reuse the same Estimator that produced layers in step 2. The noise maps returned by the learner are positionally matched to those layers, so they must be assigned to the Estimator they came from. PEA/PEC was already enabled on it in step 2.
Note that while NoiseLearnerV3 supports both Pauli-Lindblad and TREX protocols, Estimator only accepts noise models for two-qubit layers learned with the Pauli-Lindblad protocol.
# Convert results to Pauli-Lindblad noise maps.
pauli_lindblad_maps = learner_result.to_pauli_lindblad_maps()
# Assign the learned noise maps so PEA/PEC uses them.
estimator.options.resilience.layer_noise_model = zip(layers, pauli_lindblad_maps)
# Now execute the target PUBs.
from qiskit_ibm_runtime import Executor
# Generate a quantum program
program = QuantumProgram(shots=1000)
# Convert the NoiseLearnerV3 result to a dictionary
noise_maps = learner_result.to_dict(
    instructions=unique_box_instructions, require_refs=False
# Append the samplex item and execute
program.append_samplex_item(
    template_circuit,
    samplex=samplex,
    samplex_arguments={
        "pauli_lindblad_maps": noise_maps,
executor = Executor(backend)
executor_job = executor.run(program)
Full examples
NoiseLearnerV3 and client-side Estimator
from qiskit_ibm_runtime import QiskitRuntimeService, NoiseLearnerV3
# 1. Account + backend
# 2. Circuit + observable
circuit = QuantumCircuit(2)
circuit.h(0)
circuit.cx(0, 1)
observable = SparsePauliOp("ZZ")
# 3. Transpile to ISA
pm = generate_preset_pass_manager(backend=backend, optimization_level=1)
isa_circuit = pm.run(circuit)
pubs = [(isa_circuit, isa_observable)]
# 4. Initialize Estimator with options
# 5. Extract the unique boxed layers from PUBs
# 6. Learn the noise model for those layers
# 7. Convert the result to Pauli-Lindblad maps and pass them to Estimator
# 8. Execute the target PUBs
result = job.result()
NoiseLearnerV3 and Executor
from qiskit_ibm_runtime import QiskitRuntimeService, Executor, NoiseLearnerV3
from samplomatic import build
circuit.h(0)
circuit.cx(0, 1)
circuit.measure_all()
# 4. Run the boxing pass manager to group instructions into annotated boxes
    enable_gates=True,
# 5. Find unique boxed instructions (layers)
# 7. Convert the NoiseLearnerV3 result to a dictionary
# 8. Build the template circuit and samplex pair
template_circuit, samplex = build(boxed_circuit)
# 9. Prepare a quantum program
    template_circuit,
    samplex=samplex,
    samplex_arguments={
References
Was this page helpful?
